Home » Modeling » EMF » [CDO] Using 3.0(How to obtain or build the development stream)
[CDO] Using 3.0 [message #503255] |
Fri, 11 December 2009 15:56 |
I would like to give CDO 3.0 a try and I have a few questions:
1. Are there built releases available for download yet or do I need to get the source from CVS and build it?
2. What are the dependencies? Can I stay with Eclipse 3.5 or is it dependent on other 3.6 project streams, e.g. EMF?
3. There is a wiki CDO Source Installation That appears to be for setting CDO 2.0 source in a pre-release Eclipse 3.5 environment. Is this article at all applicable to setting up 3.0?
Any advice on getting this together as painlessly as possible would be much appreciated
Joel
Re: [CDO] Using 3.0 [message #503308 is a reply to message #503255] |
Fri, 11 December 2009 18:07 |
Victor Roldan Betancort Messages: 524 Registered: July 2009 |
Joel,
comments below:
Joel Rosi-Schwartz escribió:
No, releases available yet, sorry.
As far as I know, no Eclipse 3.6 runtime dependencies yet, nor EMF 2.6 :)
> 3. There is a wiki http://wiki.eclipse.org/CDO_Source_Installation
Yes, this document is applicable to setting 3.0. The only thing you
would need to change is the API baseline, but you can skip that step if
you want.
It might be the case that the script misses some source plugins. I case
you find some of those, please report us and we will fix it.
I experienced some problems with HibernateStore sources, but since I
didn't need it, I skipped it. Martin would jump in, in case you are
interested :)
> much appreciated :)
I'm just going to try this tutorial, so I'll probably find problems if any.
We would kindly assist you whenever needed :)
> Cheers,
> Joel
Cheers!
Re: [CDO] Using 3.0 [message #503311 is a reply to message #503309] |
Fri, 11 December 2009 18:33 |
Victor,
Thanks for both replies. I also ran into a post for nightly builds from Hudson at Project cbi-emf-net4j-cdo-3.0. Would using this be more more straightforward to get an environment set up to test out 3.0?
Joel
Victor Roldan Betancort wrote on Fri, 11 December 2009 18:19 | I just checked, and I beleive Eike took the trouble to keep those
updated, so the PSF should work fine Let us know if you find any problem.
Re: [CDO] Using 3.0 [message #503399 is a reply to message #503359] |
Sat, 12 December 2009 22:42 |
--------------030608070105080203060709
Eike Stepper schrieb:
> Hi guys,
> The "nightly" builsd on Hudson are in fact CI builds and they're fully
> tested. They'd differ from I, S or R builds mostly in that they're not
> signed or packed.
I can confirm that the N-Builds work well
I always use the latest "green" Build, download the update-site and use
this as Local Updatesite in IDE or TargetPlatform
you dont have to unzip - simply choose the archive
works using Galileo or Helios
ekke
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
> Víctor Roldán Betancort schrieb:
>> Joel,
>> from
>> > Hudson at
>> https://build.eclipse.org/hudson/view/Modeling/job/cbi-emf-n et4j-cdo-3.0/
>> set
>> > up to test out 3.0?
>> I haven't tried out the new build system, so I didn't think of this
>> alternative, neither I can't confirm how "straigforward" is to deploy
>> these builds, but I guess it is as easy (or hard :P) as our former
>> build system.
>> Hope Eike can jump in for this.
ekke (ekkehard gentz)
independent software-architect
senior erp-consultant
eclipse | osgi | equinox | mdsd | oaw | emf | uml
max-josefs-platz 30, D-83022 rosenheim, germany
mailto:ekke@ekkes-corner.org
homepage (de): http://gentz-software.de
blog (en): http://ekkes-corner.org
twitter: @ekkescorner
skype: ekkes-corner
Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID: DE189929490
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
<blockquote cite="mid:hfvk4i$j9h$2@build.eclipse.org" type="cite">Hi
guys,
<br>
<br>
signed or packed.
<br>
<br>
</blockquote>
I can confirm that the N-Builds work well<br>
this as Local Updatesite in IDE or TargetPlatform<br>
you dont have to unzip - simply choose the archive<br>
<br>
works using Galileo or Helios<br>
<br>
ekke<br>
<blockquote cite="mid:hfvk4i$j9h$2@build.eclipse.org" type="cite">Cheers
<br>
/Eike
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a>
<br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Joel,
<br>
<br>
from
<br>
> Hudson at
<br>
<a class="moz-txt-link-freetext" href=" https://build.eclipse.org/hudson/view/Modeling/job/cbi-emf-n et4j-cdo-3.0/"> https://build.eclipse.org/hudson/view/Modeling/job/cbi-emf-n et4j-cdo-3.0/</a>.
<br>
environment set
<br>
> up to test out 3.0?
<br>
<br>
build system.
<br>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
<div class="moz-signature">-- <br>
<p style="margin-bottom: 0cm;"> <font ,="" color="#808080"
face="Verdana, sans-serif"> <font size="4">ekke (ekkehard gentz)<br>
</font> <font size="3"> independent software-architect<br>
senior erp-consultant<br>
</font> <font size="2">eclipse | osgi | equinox | mdsd | oaw | emf |
uml<br>
max-josefs-platz 30, D-83022 rosenheim, germany<br>
<a class="moz-txt-link-freetext" href="mailto:ekke@ekkes-corner.org">mailto:ekke@ekkes-corner.org</a><br>
homepage (de): <a class="moz-txt-link-freetext" href="http://gentz-software.de">http://gentz-software.de</a><br>
blog (en): <a class="moz-txt-link-freetext" href="http://ekkes-corner.org">http://ekkes-corner.org</a><br>
twitter: @ekkescorner<br>
skype: ekkes-corner<br>
</font> <font size="1"> Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID:
DE189929490<br>
</font> </font> </p>
</div>
</body>
</html>
--------------030608070105080203060709--
ekke
independent software architect
blog: http://ekkes-corner.org
Re: [CDO] Using 3.0 [message #503526 is a reply to message #503309] |
Mon, 14 December 2009 15:34 |
Just in case anyone is interested. As Victor said, CDO 3.0 itself is not dependent on EMF 2.6. However the org.gastro.business sample does seem to be.
Joel
Victor Roldan Betancort wrote on Fri, 11 December 2009 18:07 | Joel,
comments below:
Re: [CDO] Using 3.0 [message #503558 is a reply to message #503526] |
Mon, 14 December 2009 16:53 |
> seem to be.
Although it's not too important, I'm curious: What exactly in the gastro
example is not compatible with pre-EMF-3.6?
Cheers
/Eike
> Cheers,
> Joel
>> Joel,
>> comments below:
>> it > dependent on other 3.6 project streams, e.g. EMF?
>> 2.6 :)
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Using 3.0 [message #503561 is a reply to message #503558] |
Mon, 14 December 2009 17:24 |
Three plugins have EMF 2.6 dependencies as below. The balance of the compile problems just seem to be overflows from these 3 not building.
Description Resource Path Location Type
Unsatisfied version constraint: 'org.eclipse.emf.edit: [2.6.0,3.0.0)' MANIFEST.MF /org.gastro.business.edit/META-INF line 13 Plug-in Problem
Unsatisfied version constraint: 'org.eclipse.emf.ecore: [2.6.0,3.0.0)' MANIFEST.MF /org.gastro.inventory/META-INF line 14 Plug-in Problem
Unsatisfied version constraint: 'org.eclipse.emf.ecore: [2.6.0,3.0.0)' MANIFEST.MF /org.gastro.business/META-INF line 14 Plug-in Problem
Eike Stepper wrote on Mon, 14 December 2009 16:53 | Joel Rosi-Schwartz schrieb:
> seem to be.
Cheers
/Eike
> Cheers,
> Joel
>> Joel,
>> comments below:
>> 2.6
Re: [CDO] Using 3.0 [message #503572 is a reply to message #503561] |
Mon, 14 December 2009 17:52 |
Hi Joel,
Thanks for letting me know. I fixed these dependencies to 2.4-3.0.
Cheers
/Eike
> 14 Plug-in Problem
>> > seem to be.
>> Cheers
>> /Eike
>> > Cheers,
>> > Joel
>> >> Joel,
>> >> comments below:
>> >> 2.6 :)
Cheers
/Eike
Current Time: Fri Apr 26 04:23:12 GMT 2024
Powered by FUDForum. Page generated in 0.04396 seconds
