Home » Eclipse Projects » Eclipse 4 » XWT + TableViewer + Retrieve Table Data(How to retrieve data that was modifed )
XWT + TableViewer + Retrieve Table Data [message #502600] Tue, 08 December 2009 21:15 Go to next message
Have used XWT.open to show a Collection in a TableViewer.
When the user clicks on a menu item, I need to have access to the data to persist.
What is the best way to achieve this ?
- Walter.
Re: XWT + TableViewer + Retrieve Table Data [message #502631 is a reply to message #502600] Tue, 08 December 2009 11:48 Go to previous messageGo to next message
You can give a name to the TableViewer, and use
XWT.findElementByName(context, "<name>") and then you can get the collection
by calling getInput().
Best regards
Yves YANG
"Walter" <kwchess@gmail.com> wrote in message
news:hfn181$8sp$1@build.eclipse.org...
> persist.
> Thanks
> - Walter.
Re: XWT + TableViewer + Retrieve Table Data [message #502724 is a reply to message #502631] Wed, 09 December 2009 09:34 Go to previous messageGo to next message
I have following questions
1) how can I get a context in the stand alone program.
2) in case of eclipse product I have IEclipseContext but when an menu is
clicked then a "Handler class" is called which has a method
public void execute(IWorkbench workbench) {
System.out.println ( "Save Invoked") ;
I am unable to find a way to get the IEclipseContext object thru
IWorkbench object.
-Walter
"Yves YANG" <yves.yang@soyatec.com> wrote in message
news:hfno4k$k8g$1@build.eclipse.org...
> collection by calling getInput().
> Best regards
> Yves YANG
>> persist.
>> Thanks
>> - Walter.
Re: XWT + TableViewer + Retrieve Table Data [message #504021 is a reply to message #502724] Wed, 16 December 2009 10:36 Go to previous messageGo to next message
Hi Walter. From one e4 newbie to another...
You can create a context: see
org.eclipse.e4.core.services.context.EclipseContextFactory.
> is clicked then a "Handler class" is called which has a method
> IWorkbench object.
e4 uses injection and dynamic method calling. It has a set of known
methods that it looks for (e.g., a method called "execute") and then
examines its signature to provide the requested values. So if you want
the IEclipseContext, then you simply ask for it :-)
@Inject
public void execute(IEclipseContext context,
System.out.println(...);
With e4 1.0M2, you have to annotate the methods with @Inject for e4 to
consider them. You can also annotate them with @Optional (will be set
to null if not available), and others. See the
org.eclipse.e4.demo.contacts for examples.
Brian.
Re: XWT + TableViewer + Retrieve Table Data [message #505153 is a reply to message #504021] Sun, 27 December 2009 23:38 Go to previous message
Thanks a lot. This solved my problem.
-Walter
"Brian de Alwis" <bsd@acm.org> wrote in message
news:hgbg50$2nb$1@build.eclipse.org...
>> IWorkbench object.
> @Inject
> consider them. You can also annotate them with @Optional (will be set to
> null if not available), and others. See the org.eclipse.e4.demo.contacts
> for examples.
> Brian.
Re: XWT + TableViewer + Retrieve Table Data [message #565685 is a reply to message #502631] Wed, 09 December 2009 09:34 Go to previous message
IWorkbench object.
-Walter
> Best regards
> Yves YANG
>> persist.
>> Thanks
>> - Walter.
Re: XWT + TableViewer + Retrieve Table Data [message #566170 is a reply to message #502724] Wed, 16 December 2009 15:32 Go to previous message
> IWorkbench object.
@Inject
Brian.
Re: XWT + TableViewer + Retrieve Table Data [message #566722 is a reply to message #566170] Sun, 27 December 2009 23:38 Go to previous message
-Walter
>> IWorkbench object.
> @Inject
> for examples.
> Brian.
Previous Topic:XWT + DataBinding +HashMap
Next Topic:XWT + DataBinding +DataContext +Replace
Current Time: Thu Nov 06 02:24:16 EST 2025
Powered by FUDForum. Page generated in 0.04672 seconds
