Cosmos Demo [message #502466] |
Tue, 08 December 2009 12:18 |
Yannis Makrydakis Messages: 4 Registered: November 2009 Location: Greece |
Hello all,
I'm trying to install the cosmos demo as described in installation guide, but i get an error unzipping birt into Reportviewer
My console output:
C:\cosmos\cosmos-demo\bin>configDemo "C:\cosmosTomcat 5.5" C:\cosmos\cosmos-demo "C:\cosmos\Tomcat 5.5\webapps\birt-runtime-2_3_0.zip" C:\cosmos\axis2-1.3-war\
axis2.war
This program will install the COSMOS web applications into the Tomcat web server. If you are using any other web server, you will need to modify this program or install the demo manually.
Unzipping C:\cosmos\axis2-1.3-war\axis2.war to C:\cosmos\Tomcat 5.5\webapps\axis2...
Installed axis2 on Apache Tomcat server.
Installed web application: COSMOSReportViewer
Installed web application: COSMOSUI
Unzipping C:\cosmos\Tomcat 5.5\webapps\birt-runtime-2_3_0.zip to C:\cosmos\Tomcat 5.5\webapps/COSMOSReportViewer...
Unzipped BIRT to COSMOSReportViewer
Error occurred when unzipping BIRT to COSMOSReportViewer.
Installed web service: Broker
Installed web service: ExampleMdr
Installed web service: LoggingDataManager
Installed web service: ServiceFinder
Installed web service: SMLMDR
Installed web service: StatDataManager
Installed web service: TestFederatingCMDB
Copied axis jar files to COSMOSUI.
Copied axis jar files to COSMOSReportViewer.
Copied axis jar files to cosmos client.
Updated axis2.xml.
Updated services.xml for SML MDR.
Updated services.xml for statistical MDR.
Installed broker database to C:\cosmos\Tomcat 5.5\webapps\axis2\WEB-INF\database
/brokerdb.xml
The COSMOSUI gets loaded but if i try to right click any of the components I get:
Server returned HTTP response code: 500 for URL: http://localhost:8080/COSMOSReportViewer/webcontent/report.j sp?func=list&__ptype=TomcatSet&func=list
and the following stacktrace:
java.io.IOException: Server returned HTTP response code: 500 for URL: http://localhost:8080/COSMOSReportViewer/webcontent/report.j sp?func=list&__ptype=TomcatSet&func=list at sun.net.www.protocol.http.HttpURLConnection.getInputStream(H ttpURLConnection.java:1241) at org.eclipse.cosmos.internal.dr.drs.service.outputter.ReportD eployment.sendRequest(ReportDeployment.java:95) at org.eclipse.cosmos.internal.dr.drs.service.outputter.ReportD eployment.generateReportList(ReportDeployment.java:71) at org.eclipse.cosmos.internal.dr.drs.service.outputter.ReportD eployment.render(ReportDeployment.java:47) at org.eclipse.cosmos.internal.dr.drs.service.handler.common.Ou tputterDelegator.delegateRequest(OutputterDelegator.java:72) at org.eclipse.cosmos.internal.dr.drs.service.handler.common.Ou tputterDelegator.doPost(OutputterDelegator.java:55) at org.eclipse.cosmos.internal.dr.drs.service.handler.common.UR LDelegator.doPost(URLDelegator.java:96) at javax.servlet.http.HttpServlet.service(HttpServlet.java:647) at javax.servlet.http.HttpServlet.service(HttpServlet.java:729) at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:269) at org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:188) at org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213) at org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:172) at org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:117) at org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:108) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:174) at org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:873) at org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:665) at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:528) at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:81) at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:689) at java.lang.Thread.run(Thread.java:619)
any idea how to solve this?
[Updated on: Tue, 08 December 2009 12:19] Report message to a moderator
FUDForum. Page generated in 0.02869 seconds
