Home » Language IDEs » PHP Development Tools (PDT) » select code between braces with double-click(select code between braces with double-click no longer available?)
select code between braces with double-click [message #502044] Fri, 04 December 2009 16:44 Go to next message
In my previous installation of ECLIPSE + PHP, I used the double-click to select code between matching braces. In my recently installed version (Galileo Eclipse for PHP Developers Build id: 20090920-1017 on Windows XP) it no longer works.
Any idea why this useful feature is no longer available?
Re: select code between braces with double-click [message #508717 is a reply to message #502044] Tue, 19 January 2010 18:16 Go to previous messageGo to next message
Did this ever get any attention? I'm noticing similar problems.
Re: select code between braces with double-click [message #555376 is a reply to message #502044] Thu, 26 August 2010 09:07 Go to previous messageGo to next message
BUMP anyone? maybe a newer version of ECLIPSE has solved this problem?
Re: select code between braces with double-click [message #558393 is a reply to message #555376] Sun, 12 September 2010 04:11 Go to previous messageGo to next message
Fixed in the Helios distribution (2010).
Thanks!
Re: select code between braces with double-click [message #1800828 is a reply to message #502044] Tue, 08 January 2019 14:25 Go to previous message
Joseph Rezeau (Dr.) wrote on Fri, 04 December 2009 21:44
Previous Topic:Tab with distance
Next Topic:I removed Java
Current Time: Mon Nov 10 10:54:58 EST 2025
Powered by FUDForum. Page generated in 0.63504 seconds
