Re: hyperlink drilldown - loading one of two reports [message #501782 is a reply to message #501759] |
Thu, 03 December 2009 18:47 |
Ash,
You could always write your own client side js function in a text
element in a text element and use the invokeScript on the chart.
Take a look at this example.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.20"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.1.v20090903 Build <2.5.1.v20090917-1447></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 <<Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">auto layout</property>
<parameters>
<scalar-parameter name="CountryParameter" id="37">
<property name="valueType">dynamic</property>
<property name="dataSetName">Data Set1</property>
<expression name="valueExpr">dataSetRow["COUNTRY"]</expression>
<expression name="labelExpr">dataSetRow["COUNTRY"]</expression>
<property name="dataType">string</property>
<property name="distinct">false</property>
<simple-property-list name="defaultValue">
<value type="constant">Australia</value>
</simple-property-list>
<property name="paramType">simple</property>
<property name="controlType">list-box</property>
<property name="mustMatch">true</property>
<property name="fixedOrder">true</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="7">
<list-property name="parameters">
<structure>
<property name="name">param_1</property>
<property name="paramName">CountryParameter</property>
<property name="nativeName"></property>
<property name="nativeDataType">12</property>
<property name="position">1</property>
<property name="isOptional">false</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="name">CUSTOMERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNAME</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">CREDITLIMIT</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">COUNTRY</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
</structure>
<structure>
<property name="nativeName">CREDITLIMIT</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">COUNTRY</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select
CLASSICMODELS.CUSTOMERS.CUSTOMERNUMBER,
CLASSICMODELS.CUSTOMERS.CUSTOMERNAME,
CLASSICMODELS.CUSTOMERS.CREDITLIMIT,
CLASSICMODELS.CUSTOMERS.COUNTRY
from CLASSICMODELS.CUSTOMERS
where CLASSICMODELS.CUSTOMERS.COUNTRY = ?]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name></design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:nullability>Unknown</design:nullability>
<design:uiHints/>
</design:attributes>
<design:inputAttributes>
<design:elementAttributes>
<design:defaultScalarValue>USA</design:defaultScalarValue>
<design:optional>false</design:optional>
<design:masksValue>false</design:masksValue>
<design:dynamicValueChoices>
<design:dataSetDesign>
<design:name>Data Set1</design:name>
<design:odaExtensionDataSetId>org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet </design:odaExtensionDataSetId>
<design:dataSourceDesign>
<design:name>Data Source</design:name>
<design:odaExtensionId>org.eclipse.birt.report.data.oda.jdbc </design:odaExtensionId>
<design:displayName></design:displayName>
<design:publicProperties>
<design:properties>
<design:nameValue>
<design:name>odaDriverClass</design:name>
<design:value>org.eclipse.birt.report.data.oda.sampledb.Driver </design:value>
</design:nameValue>
</design:properties>
<design:properties>
<design:nameValue>
<design:name>odaURL</design:name>
<design:value>jdbc:classicmodels:sampledb</design:value>
</design:nameValue>
<design:properties>
<design:nameValue>
<design:name>odaUser</design:name>
<design:value>ClassicModels</design:value>
</design:nameValue>
<design:properties>
<design:nameValue>
<design:name>odaPassword</design:name>
</design:nameValue>
<design:properties>
<design:nameValue>
<design:name>odaJndiName</design:name>
</design:nameValue>
<design:properties>
<design:nameValue>
<design:name>OdaConnProfileName</design:name>
</design:nameValue>
<design:properties>
<design:nameValue>
<design:name>OdaConnProfileStorePath</design:name>
</design:nameValue>
</design:publicProperties>
</design:dataSourceDesign>
<design:query>
<design:queryText>select DISTINCT
from CLASSICMODELS.CUSTOMERS</design:queryText>
</design:query>
<design:properties>
<design:nameValue>
<design:name>queryTimeOut</design:name>
</design:nameValue>
<design:resultSets>
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>COUNTRY</design:name>
</design:resultColumnDefinitions>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:resultSets>
</design:dataSetDesign>
<design:enabled>true</design:enabled>
<design:valueColumn>dataSetRow[&quot;COUNTRY&quot;] </design:valueColumn>
<design:displayNameColumn>dataSetRow[&quot;COUNTRY&quot;] </design:displayNameColumn>
</design:dynamicValueChoices>
<design:uiHints>
<design:promptStyle>SelectableList</design:promptStyle>
</design:uiHints>
</design:elementAttributes>
</design:inputAttributes>
</design:parameterDefinitions>
</design:DataSetParameters>
<design:ResultSets derivedMetaData="true">
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:position>2</design:position>
<design:precision>50</design:precision>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:displaySize>50</design:displaySize>
<design:attributes>
<design:name>CREDITLIMIT</design:name>
<design:position>3</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:usageHints>
<design:label>CREDITLIMIT</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:position>4</design:position>
<design:usageHints>
<design:label>COUNTRY</design:label>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set
name="Data Set1" id="36">
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select DISTINCT
from CLASSICMODELS.CUSTOMERS]]></xml-property>
<model:DesignValues
<design:attributes>
<design:usageHints>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab-cell" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">1in</property>
<property name="leftMargin">1.25in</property>
<property name="bottomMargin">1in</property>
<property name="rightMargin">1.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<grid id="44">
<property name="width">100%</property>
<column id="45"/>
<row id="46">
<cell id="47"/>
</row>
<row id="48">
<cell id="49">
<text id="52">
<text-property name="content"><![CDATA[<script>
function jump(cat) {
alert(cat);
if( cat == 114 ){
window.location = "http://www.google.com";
}else{
window.location = "http://www.yahoo.com";
</script>
]]></text-property>
</text>
</cell>
</row>
<row id="50">
<cell id="51">
<table id="8">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<property
<expression
name="expression">dataSetRow["CUSTOMERNUMBER"]</expression >
<property
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["CUSTOMERNAME"]</expression >
</structure>
<structure>
<property
<expression
name="expression">dataSetRow["CREDITLIMIT"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["COUNTRY"]</expression>
</structure>
</list-property>
<property name="pageBreakInterval">50</property>
<column id="32"/>
<column id="33"/>
<column id="34"/>
<column id="35"/>
<header>
<row id="38">
<cell id="39">
<property name="colSpan">4</property>
<property name="rowSpan">1</property>
<extended-item
extensionName="Chart" name="NewChart" id="43">
<xml-property
name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Version>2.5.1</Version>
<Type>Bar Chart</Type>
<SubType>Side-by-side</SubType>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Visible>true</Visible>
<Label>
<Caption>
<Value>Bar Chart Title</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<ItemType>Series</ItemType>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>435.74999999759996</Width>
<Height>155.25</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<ExtendedProperties>
<Name>enable.area.alt</Name>
<Value>false</Value>
</ExtendedProperties>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>5.0,4.0,12.0</DataSetRepresentation >
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>5,4,12</DataSetRepresentation>
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
</SampleData>
<Interactivity/>
<EmptyMessage>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</EmptyMessage>
<Axes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>X-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>Y-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series xsi:type="type:BarSeries">
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["CREDITLIMIT"]</Definition >
</DataDefinition>
<SeriesIdentifier></SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Outside</LabelPosition>
<Stacked>false</Stacked>
<Triggers>
<Condition>onclick</Condition>
<Action>
<Type>Invoke_Script</Type>
<Value xsi:type="attribute:ScriptValue">
<Script>jump(categoryData);</Script>
</Value>
</Action>
</Triggers>
<Triggers>
<Condition>onmouseover</Condition>
<Action>
<Type>Show_Tooltip</Type>
<Value xsi:type="attribute:TooltipValue">
<Text></Text>
<Delay>200</Delay>
</Value>
</Action>
</Triggers>
<Riser>Rectangle</Riser>
</Series>
<Grouping>
<Enabled>false</Enabled>
<GroupingInterval>2.0</GroupingInterval>
<GroupType>Text</GroupType>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
<Sorting>Ascending</Sorting>
</SeriesDefinitions>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
Re: hyperlink drilldown - loading one of two reports [message #501972 is a reply to message #501920] |
Fri, 04 December 2009 15:52 |
Ash
Are you using BIRT 2.5.1? Can you set the chart output to an image type
instead of SVG?
Jason
Ash wrote:
> Hmm, this doesn't work for me. In my report it can't see the "jump()"
> function (gives a JavaScript error to that effect). I know my
> client-side script block is being executes (if I put an alert() in it
> gets executed) however when I click on the plot in the chart it gives a
> javascript error that it can't find jump(). I have a feeling that as the
> script is invoked from within a SVG it can't see the script within the
> HTML page.
> I've tried putting the text-box-script in various positions in case that
> affects thing but to no avail.
> (Btw, the report XML you posted is incomplete so doesn't parse)
> thanks!
Re: hyperlink drilldown - loading one of two reports [message #502849 is a reply to message #502799] |
Wed, 09 December 2009 22:44 |
Ash,
These are the chart context sensitive information that can be passed
through the invokeScript interactivity item:
evt,categoryData, valueData, valueSeriesName, legendItemText,
legendItemValue, axisLabel
but not all events will have all items. In the case of axis scripts you
can pass axisLabel. Ie jump(axisLabel);
Jason
Ash wrote:
> Setting the output format to something other than SVG does work. Ifound
> I can also leave as SVG but call jump() using window.parent.jump().
> Btw, if I want to make the axis labels interactive - so that clicking on
> one of the axis labels has the same effect then calling
> jump(categoryData); doesn't work. It seems the axis don't assign
> categoryData - why is that?
Re: hyperlink drilldown - loading one of two reports [message #503253 is a reply to message #503203] |
Fri, 11 December 2009 15:51 |
Ash,
You are correct. You can log an enhancement to improve this you would
like. Just use bugzilla and mark it as an enhancement.
Jason
Ash wrote:
> Thanks, that works.
> One interesting thing is that the in the "interactivity" options for
> axis labels, you can't set a tooltip text to a JavaScript expression
> (say, on mouse-over event) only to plain text, whereas tooltips on graph
> plots do allow expressions (essentially, dynamic text).
FUDForum. Page generated in 0.03632 seconds
