Adding column mappings using the Birt Engine API ? [message #501691] |
Thu, 03 December 2009 09:00  |
Originally posted by: ddd.asd.com
I have made an application that opens an already existing .rptdesign file
which uses a xml file as data source and a few data sets.
In this application I would like to add one or more new column mappings to
one of the data sets. Any ideas on how to do this using the Birt Engine API?
Re: Adding column mappings using the Birt Engine API ? [message #501756 is a reply to message #501691] |
Thu, 03 December 2009 12:12   |
Do you want to change the xml query? or just add columns to a table?
I am attaching an example of creating a report with an xml datasource.
Also attached is the sample xml data used.
Jason
import java.io.File;
import java.io.IOException;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.model.api.CellHandle;
import org.eclipse.birt.report.model.api.DataItemHandle;
import org.eclipse.birt.report.model.api.DesignConfig;
import org.eclipse.birt.report.model.api.DesignElementHandle;
import org.eclipse.birt.report.model.api.DesignEngine;
import org.eclipse.birt.report.model.api.ElementFactory;
import org.eclipse.birt.report.model.api.IDesignEngine;
import org.eclipse.birt.report.model.api.IDesignEngineFactory;
import org.eclipse.birt.report.model.api.LabelHandle;
import org.eclipse.birt.report.model.api.PropertyHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.RowHandle;
import org.eclipse.birt.report.model.api.OdaDataSetHandle;
import org.eclipse.birt.report.model.api.OdaDataSourceHandle;
import org.eclipse.birt.report.model.api.SessionHandle;
import org.eclipse.birt.report.model.api.StructureFactory;
import org.eclipse.birt.report.model.api.TableHandle;
import org.eclipse.birt.report.model.api.activity.SemanticException ;
import org.eclipse.birt.report.model.api.command.ContentException;
import org.eclipse.birt.report.model.api.command.NameException;
import org.eclipse.birt.report.model.api.elements.DesignChoiceConst ants;
import org.eclipse.birt.report.model.api.elements.structures.Comput edColumn;
import org.eclipse.birt.report.model.api.metadata.IMetaDataDictiona ry;
import org.eclipse.birt.report.model.elements.interfaces.IReportIte mModel;
import org.eclipse.birt.report.model.elements.interfaces.IStyleMode l;
import com.ibm.icu.util.ULocale;
public class XMLReport
ReportDesignHandle reportDesignHandle = null;
ElementFactory elementFactory = null;
IMetaDataDictionary dict = null;
ComputedColumn cs1, cs2, cs3 = null;
public static void main( String[] args ) throws SemanticException,
IOException
new XMLReport( ).createReport( );
void createReport( ) throws SemanticException, IOException
//Configure the Engine and start the Platform
DesignConfig config = new DesignConfig( );
config.setBIRTHome("C:/birt/birt-runtime-2_5_1/birt-runtime-2_5_1/ReportEngine ");
IDesignEngine engine = null;
try{
Platform.startup( config );
IDesignEngineFactory factory = (IDesignEngineFactory) Platform
.createFactoryObject(
IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY );
engine = factory.createDesignEngine( config );
}catch( Exception ex){
ex.printStackTrace();
SessionHandle session = engine.newSessionHandle( ULocale.ENGLISH ) ;
// Create a new report
reportDesignHandle = session.createDesign( );
// Element factory is used to create instances of BIRT elements.
elementFactory = reportDesignHandle.getElementFactory( );
dict = new DesignEngine( null ).getMetaData( );
createMasterPages( );
createDataSources( );
createDataSets( );
createBody( );
//OdaDataSourceHandle dataSourceHandle =
(OdaDataSourceHandle)reportDesignHandle.findDataSource("myxmldatasource ");
String outputPath = "output";//$NON-NLS-1$
File outputFolder = new File( outputPath );
if ( !outputFolder.exists( ) && !outputFolder.mkdir( ) )
throw new IOException( "Can not create the output folder" );//$NON-NLS-1$
reportDesignHandle.saveAs( "output/desample/XMLReport.rptdesign"
);//$NON-NLS-1$//$NON-NLS-2$
System.out.println("finished");
private void createDataSources( ) throws SemanticException
elementFactory.newOdaDataSource("Data Source",
"org.eclipse.birt.report.data.oda.xml");
dataSourceHandle.setProperty("FILELIST", "C:/temp/xmltest2.xml");
reportDesignHandle.getDataSources( ).add( dataSourceHandle );
private void createDataSets( ) throws SemanticException
// Data Set
OdaDataSetHandle dsHandle = elementFactory.newOdaDataSet( "Data Set",
"org.eclipse.birt.report.data.oda.xml.dataSet" );
dsHandle.setDataSource( "Data Source" );
dsHandle.setQueryText(
" table0#-TNAME-#table0#:#[/people/person/name]#:#{name;String ;} " );
reportDesignHandle.getDataSets( ).add( dsHandle );
private void createMasterPages( ) throws ContentException, NameException
DesignElementHandle simpleMasterPage =
elementFactory.newSimpleMasterPage( "Master Page" );//$NON-NLS-1$
reportDesignHandle.getMasterPages( ).add( simpleMasterPage );
private void createBody( ) throws SemanticException
TableHandle table = elementFactory.newTableItem( null, 3, 1, 1, 1 );
table.setProperty( IStyleModel.TEXT_ALIGN_PROP,
DesignChoiceConstants.TEXT_ALIGN_CENTER );
table.setWidth( "80%" );//$NON-NLS-1$
table.setProperty( IReportItemModel.DATA_SET_PROP, "Data Set"
);//$NON-NLS-1$
PropertyHandle computedSet = table.getColumnBindings( );
cs1 = StructureFactory.createComputedColumn( );
cs1.setName("Name");
cs1.setExpression( "dataSetRow[\"name\"]" );//$NON-NLS-1$
computedSet.addItem( cs1 );
// Header
RowHandle header = (RowHandle) table.getHeader( ).get( 0 );
CellHandle tcell = (CellHandle) header.getCells( ).get( 0 );
LabelHandle label = elementFactory.newLabel( null );
label.setText( "Name" );//$NON-NLS-1$
tcell.getContent( ).add( label );
DataItemHandle data = null;
// Detail
RowHandle detail = (RowHandle) table.getDetail( ).get( 0 );
tcell = (CellHandle) detail.getCells( ).get( 0 );
data = elementFactory.newDataItem( null );
data.setResultSetColumn( cs1.getName( ) );
tcell.getContent( ).add( data );
reportDesignHandle.getBody( ).add( table );
//xml data
<people>
<person>
<name>Jonathan</name>
<nicknames>
<nickname>John</nickname>
<nickname>Jon</nickname>
</nicknames>
</person>
<person>
<name>Steven</name>
<nicknames>
<nickname>Steve</nickname>
</nicknames>
</person>
</people>
> file which uses a xml file as data source and a few data sets.
> to one of the data sets. Any ideas on how to do this using the Birt
> Engine API?
Re: Adding column mappings using the Birt Engine API ? [message #501893 is a reply to message #501756] |
Fri, 04 December 2009 05:36   |
"Jason Weathersby" <jasonweathersby@windstream.net> wrote in message
news:hf8rgb$2pl$1@build.eclipse.org...
I only need to add a column to an existing data set not to the table. I
current get the query text like this:
DataSetHandle dsh = reportDesignHandle.findDataSet(dataSetName);
System.out.println(dsh.getProperty("queryText"));
which gives me (for the already existing parameters):
table0#-TNAME-#table0#:#[/root/section/subsection]#:#{Name;S TRING;[@id= "Name"]/@value},{Year;STRING;
[@id="Year"]/@value}, ....
Now if I would like to add the column: "Address" it should end up looking
like this in the updated queryText:
{Address;STRING;[@id="Address"]/@value}
One way to do this is to manually update the queryText (insert the xml
formatted expression to the already existing queryText) but maybe there is a
more elegant way to do this?
> Jason
> import
> IOException
> try{
> createDataSets( );
> createBody( );
> "output/desample/XMLReport.rptdesign" );//$NON-NLS-1$//$NON-NLS-2$
> // Data Set
> Set" );//$NON-NLS-1$
> // Header
> // Detail
> //xml data
> <people>
> <person>
> <nicknames>
> </nicknames>
> </person>
> <person>
> <name>Steven</name>
> <nicknames>
> </nicknames>
> </person>
> </people>
>> Engine API?
Re: Adding column mappings using the Birt Engine API ? [message #501974 is a reply to message #501893] |
Fri, 04 December 2009 10:57   |
I do not think there currently is another method to do this. Modifying
the query text is the most direct way.
Jason
> looking like this in the updated queryText:
> is a more elegant way to do this?
>> Jason
>> import
>> import
>> IOException
>> try{
>> createDataSets( );
>> createBody( );
>> // Data Set
>> );//$NON-NLS-1$
>> // Header
>> // Detail
>> //xml data
>> <people>
>> <person>
>> <nicknames>
>> </nicknames>
>> </person>
>> <person>
>> <name>Steven</name>
>> <nicknames>
>> </nicknames>
>> </person>
>> </people>
>>> mappings to one of the data sets. Any ideas on how to do this using
FUDForum. Page generated in 0.04511 seconds
