Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Change IModelElement icons (in outline, explorer, completion)
Change IModelElement icons (in outline, explorer, completion) [message #500932] |
Mon, 30 November 2009 05:43  |
I would like to change IModelElement icons displayed in outline,
explorer and completion, but with no success :-(
I've tried to look around ModelElementLabelProvider class, but I still
have problems with icons size (those I changed are not displayed with
the right size), and I'm not sure to go the right way...
If someone could help ... (thanks in advance)
David
Re: Change IModelElement icons (in outline, explorer, completion) [message #501667 is a reply to message #501101] |
Thu, 03 December 2009 06:13   |
Andrei Sobolev a écrit :
> Hi David,
> Please look into org.eclipse.dltk.ui.modelLabelProvider extension point.
> It's allow any customization of outline, etc by providing custom label
> provider.
> You could check example implementation in TCL in class
> TclModelLabelProvider.
> If you need to add some additional elements you also could use following
> extension points ( for customization of outline, script explorer content
> and element ordering)
> org.eclipse.dltk.ui.modelCompareProvider
> org.eclipse.dltk.ui.modelContentProvider
> Best regards,
> Andrei.
Hi Andrei,
Thank you for your answer.
I’ve tried to use org.eclipse.dltk.ui.modelLabelProvider extension
point, as in Tcl project. It works very well for all explorer part, but
I still have problems with icons size in Outline view : they are
displayed bigger than they are in explorer part.
In Tcl project, the only custom objects that are displayed are Tcl
Packages (tcl_packagefolder_obj.gif), and this kind of object is not
displayed in the Outline, so I can’t compare the behavior.
I also noticed that IModelElement objects displayed in completion
proposals do not react the same way : I mean that modelLabelProvider is
not used in this case (I need to override
CompletionProposalLabelProvider to do what I want). I think
modelLabelProvider extension point should also be used by completion.
Thanks in advance for your help,
David
Current Time: Tue May 13 10:24:06 EDT 2025
Powered by FUDForum. Page generated in 0.06297 seconds
