Task view not showing TODO tags [message #500798] |
Sat, 28 November 2009 20:55 |
A Hunt Messages: 4 Registered: November 2009 |
Junior Member |
Today I wanted to look at tasks on my eclipse project -- and found none were shown. I updated to Galileo (3.5) from 3.4 which brought no change.
The "Task" view settings are correctly configured to show all tasks, with no filtering, similarly all workspace and project settings are at their default, yet no TODO tags in the code will show in the tasks list.
Does anyone know what I am doing wrong / whether this is a bug? (I have done considerable searching, but most of the problems were to do with mylyn which has nothing to do with the standard task list in eclipse.)
Also, a possibly related problem is that the error label annotations in the package explorer view are no longer showing, which has been the case ever since I installed subversive.
AHunt.org
Simple rowLog -- the java based free and open source rowing logbook
Re: Task view not showing TODO tags [message #500851 is a reply to message #500847] |
Sun, 29 November 2009 17:23 |
Junior Member |
No Real Name wrote on Sun, 29 November 2009 11:51 | A Hunt wrote:
> I have been doing some testing, and completely reinstalled eclipse from
> scratch etc:
> I have Eclipse 3.5, with subclipse svn client.
> For a project I have checked out from SVN neither the error labels in
> the Package Explorer tree are showing nor the Tasks in the task view.
> However if I make a new project in the same workspace everything works
> fine -- both TODO tags and errors showing (Note: in the editor view both
> tasks and errors are shown with their usual symbols at the left hand
> side). The strange thing is that there are NO project specific settings,
> meaning eclipse shouldn't be doing anything differently for my svn
> project. Could this be a subclipse bug?
Have you checked to make sure that the project is a Java project. If
the SVN project didn't include the .project or .classpath file, you may
have a plain project with no natures.
It is a java project: I originally created it in Eclipse, put it on svn, then checked it out again. However I managed to "solve" the problem by cleaning out all settings file (.project, .classpath, the directory .settings), and making a completely new project into which I only imported the sources: it seems some setting in one of these files had broken the tasks view, but there wasn't a gui option to change this. I'm still doing diffs between the files, but can't find anything obvious.
AHunt.org
FUDForum. Page generated in 0.08301 seconds
