Re: Multiple EditorPart stack. [message #502547 is a reply to message #501822] |
Tue, 08 December 2009 18:41 |
Mauro Condarelli Messages: 428 Registered: September 2009 |
Wim Jongman wrote on Thu, 03 December 2009 17:47 | Hi Mauro,
Can you rephrase this? What exactly do you want?
Sorry.
I will try.
I am writing an application that essentially is an editor:
It opens an XML file, shows it in a few different views and/or editors and saves it back.
The XML file contains, among other things, pointers to other text files.
The XML editor can open one or more of those files for editing.
My problems:
- I would like to have the central editorArea disappear when all files have been closed; I have found that setting layout.setEditorAreaVisible(false); will hide the editorArea at startup. It will appear as soon as I open an editor. I have found no way to make it disappear again when I close the editor. How can I do that?
- In case (often!) i do not need to actually modify the XML file itself, but I need to edit only the text-files, I would like to close the XML editor and to leave only one of the views active (similar to an Outline View); is this possible?
- If I set configurer.setSaveAndRestore(true); the system will try to reopen all files that were open last time; In case I closed the XML editor (see above) I would like to prevent this and I would like to force the user to manually reopen the XML file or, alternatively, reopen it in the non-editing mode (just the outline shown). Again: I do not know how to achieve this.
I hope this is a bit clearer.
Thanks for Your understanding
Mauro
Quote: | > The Description says it all.
> What is the RightWay(TM) to handle editor tabs and make EditorArea vanish
when last one is closed?
> I also have a problem with the initial configurer.setSaveAndRestore(true);
because it remembers all my open Views and also the EditorArea visibility
status,
> But that doesn't make any sense because there's nothing to view or to edit
till I actually open a file.
> I should either automatically open last visited file (but it might not
exist!) or just display some kind of blank background (or an image) till the
user opens a file.
> I have no idea about how to do that.
> Can someone suggest a strategy?
> TiA
> Mauro
FUDForum. Page generated in 0.03890 seconds
