I wanted to use a FilteredTree in my outline view. [message #500141] |
Wed, 25 November 2009 08:15 |
jaykei Messages: 4 Registered: November 2009 |
Hi. everyone.
I need some help for my plug-in.
So I created a subclass of ContentOutlinePage and override default treeviewer to FilteredTree's treeviewer.
After that, all I got is "An outline is not available." message.
At least I wanted to know why, but here's no error log at all.
If I set the treeviewer as normal treeviewer as commented code, below, I can see outline view as normal.
My codes are below. (codes which are not related to this subject are omitted.)
Could anybody help me out?
Is it impossible to use FilteredTree on outline view?
public class TestOutlinePage extends ContentOutlinePage {
private TreeViewer treeViewer;
public void createControl(Composite parent) {
PatternFilter filter = new PatternFilter();
FilteredTree tree = new FilteredTree(parent, SWT.MULTI | SWT.H_SCROLL
| SWT.V_SCROLL, filter, false);
treeViewer = tree.getViewer();
// treeViewr = new TreeViewer(parent, SWT.MULTI | SWT.H_SCROLL | SWT.V_SCROLL);
treeViewer.addSelectionChangedListener(this);
treeViewer.setInput(Input);
protected TreeViewer getTreeViewer() {
return treeViewer;
public Control getControl() {
if (treeViewer == null) {
return null;
return treeViewer.getControl();
public ISelection getSelection() {
return StructuredSelection.EMPTY;
return treeViewer.getSelection();
public void setFocus() {
treeViewer.getControl().setFocus();
public void setSelection(ISelection selection) {
if (treeViewer != null) {
treeViewer.setSelection(selection);
[Updated on: Wed, 25 November 2009 08:17] Report message to a moderator
Re: I wanted to use a FilteredTree in my outline view. [message #500876 is a reply to message #500504] |
Mon, 30 November 2009 02:02 |
Hi, sorry to reply so late.
The reason I wanted to use outline view is, outline view is easy to use for my plug-in users.
My plug-in is used to edit special config file.
This config file belongs to Java project and is modified with other .java files.
As you know, we usually modify .java files with outline view opened.
So if my plug-in users want to modify config file with other .java files, they can just open my config file with my editor, then outline view is already opened, so they don't need to open another view.
So it is easy to use.
And If I use my own view other than outline view, I think java editor will show "this view is not available" when users switch to Java editor from my editor, because java editor don't know my view type. So this could be so annoying.
These two issues are the reason why I want to use outline view other than my own view.
If I misunderstood something, please let me know.
Thanks for reply anyway Pupier !!!
[Updated on: Mon, 30 November 2009 02:06] Report message to a moderator
FUDForum. Page generated in 0.03892 seconds
