| Could not write metadata for '/someproject'. [message #499972] |
Tue, 24 November 2009 10:53  |
EDIT:
Solved it by deleting the .metadata directory (D:\Programming\Java\.metadata).
Hey there,
I recently encountered the following error on my laptop:
D:\Programming\Java\.metadata\.plugins\org.eclipse.core.reso urces\.projects\someproject\.markers.snap (The system cannot find the path specified)
Odd, I though and reinstalled Eclipse. Today, however, I encountered the exact same error on my desktop. I've never seen the error message before (been using Eclipse for quite a while), and the installations on both laptop and desktop were brand new. My laptop is even newly formatted. Both machines run Windows 7 (32 bit on laptop, 64 bit on desktop), and D: is the second out of two partitions on each of the computer's drives whereas C: is the first and system drive. I'm synchronizing data between the machines (entire D: drive with a few exceptions not including D:\Programming), and I figure this somehow affects Eclipse. However, I just successfully removed read-only and hidden attributes on all files on my laptop's entire D: drive and still got the error on project load!
Any help would be appreciated. Thanks!
EDIT:
The failure occurs upon periodic save and, apparently, project load and manual save.
[Updated on: Tue, 24 November 2009 18:30] by Moderator
FUDForum. Page generated in 0.06640 seconds
