Home » Eclipse Projects » Standard Widget Toolkit (SWT) » missing first column of a table(Show table with SetData event - missing first column)
missing first column of a table [message #499859] Tue, 24 November 2009 07:10 Go to next message
Hi, I create table like in the snippet below and the first column of the table is missing. Any suggestions will be appreciated. Thanks.
import org.eclipse.swt.*;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.widgets.*;
 * Displays a table
public class TableTest {
	private boolean isPacked = false;
	Table table = null;
    new TableTest().run();
  public void run() {
    Display display = new Display();
    Shell shell = new Shell(display);
    shell.setLayout(new FillLayout());
    table = new Table(shell, SWT.BORDER | SWT.SINGLE | SWT.VIRTUAL);
    for (int i = 0; i < 5; i++) {
      TableColumn column = new TableColumn(table, SWT.NONE);
      column.setText("Column" + Integer.toString(i));
	table.setHeaderVisible(true);
	table.setLinesVisible(true);
	table.setItemCount(10);
	table.addListener(SWT.SetData, new Listener () {
	      public void handleEvent (Event event) {
	          TableItem item = (TableItem) event.item;
	          int index = table.indexOf(item);
	          for (int j = 0; j < 5; j++) {
	              item.setText(j, "(" + index + "," + j + ")");
	          if (! isPacked) {
	        	  isPacked = true;
	        	  for (int i =0; i < table.getColumnCount(); i++) {
	        		  System.out.println("Pack column " + i);
	        		  table.getColumn(i).pack();
    shell.pack();
    shell.open();
    while (!shell.isDisposed()) {
      if (!display.readAndDispatch()) {
        display.sleep();
    display.dispose();
Re: missing first column of a table [message #499944 is a reply to message #499859] Tue, 24 November 2009 09:53 Go to previous messageGo to next message
Columns 0-4 all show when I run your snippet on Windows 2000. Which
platform and swt version are you using?
Grant
"Stella" <stella_levin2003@yahoo.com> wrote in message
news:hegifa$56d$1@build.eclipse.org...
> * Displays a table
> Table table = null;
> public static void main(String[] args) {
> public void run() {
> if (! isPacked) {
> isPacked = true;
> shell.pack();
> shell.open();
> display.sleep();
> display.dispose();
Re: missing first column of a table [message #499950 is a reply to message #499859] Tue, 24 November 2009 10:10 Go to previous messageGo to next message
I run on GNU/Linux x86_64. swt_3.4.1.v3449c.
Thanks, Stella
Re: missing first column of a table [message #500138 is a reply to message #499950] Wed, 25 November 2009 02:51 Go to previous messageGo to next message
> Thanks, Stella
I've verified that this problem is reproducible on Linux and opened Bug
296085 for addressing this issue.
Re: missing first column of a table [message #500229 is a reply to message #500138] Wed, 25 November 2009 08:01 Go to previous message
Thanks a lot for responce. Stella
Previous Topic:How to show another window when login button clicked?
Next Topic:HP-UX problem : unsatisfied link error
Current Time: Wed Nov 05 19:01:35 EST 2025
Powered by FUDForum. Page generated in 0.03218 seconds
