WS binding vs. propagated WS binding [message #499840] |
Tue, 24 November 2009 06:00  |
Originally posted by: michael.gebhart.googlemail.com
assuming, I have one SCA assembly with one component. Now, I wanna
expose the functionality of the component as web service. I have two
ways to do this:
1. Creating a WS binding for the component
2. Creating a WS binding for the component and propgating it as service
for the entire SCA assembly.
What is the difference between these two possibiliites? In both cases
the component functionality can be accessed via a web service interface.
Usually, interfaces that should be accessible from external, the service
should be propagated to the SCA assembly. But when using a WS binding,
this is not necessary. So, what is the difference at a logical level?
Best regards
Michael
Re: WS binding vs. propagated WS binding [message #500198 is a reply to message #499840] |
Wed, 25 November 2009 05:37   |
Hi Mickael,
Michael Gebhart a écrit :
> ways to do this:
In SCA, what is inside the composite is not visible from the outside.
So, if you component service is not promoted, no matter which binding
you attached on it, it is not accessible from the outside of the composite.
So your first assumption (1.) is wrong.
The only exception is if the component is in fact a composite (a
component with a composite implementation) with the same service
available as a web service. Which brings you to 2.
Vincent.
Re: WS binding vs. propagated WS binding [message #500206 is a reply to message #500198] |
Wed, 25 November 2009 06:35  |
Hi Vincent,
thanks for your answer. Helped me pretty much!
Michael
> Hi Mickael,
>> Hi,
>> ways to do this:
>> service for the entire SCA assembly.
> Regards,
> Vincent.
Re: WS binding vs. propagated WS binding [message #576519 is a reply to message #499840] |
Hi Mickael,
> ways to do this:
Vincent.
Re: WS binding vs. propagated WS binding [message #576578 is a reply to message #500198] |
Hi Vincent,
Michael
> Hi Mickael,
>> Hi,
>> ways to do this:
> Regards,
> Vincent.
FUDForum. Page generated in 0.03910 seconds
