classpath problems [message #499317] |
Fri, 20 November 2009 18:39 |
Mauro Condarelli Messages: 428 Registered: September 2009 |
I'm writing an RCP app.
I need a fairly good Text editor, so I'm trying to included OOWriter in a frame and pack that into an EditorPart.
I have a wrapper for OOWriter that is (for now) fairly simple and works as expected using the include main().
package it.condarelli.swt.ooo;
import java.awt.BorderLayout;
import java.awt.Frame;
import java.awt.Panel;
import javax.swing.JPanel;
import javax.swing.JRootPane;
import org.eclipse.swt.SWT;
import org.eclipse.swt.awt.SWT_AWT;
import org.eclipse.swt.events.DisposeEvent;
import org.eclipse.swt.events.DisposeListener;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
import com.sun.star.comp.beans.NoConnectionException;
import com.sun.star.comp.beans.OOoBean;
import com.sun.star.comp.beans.SystemWindowException;
import com.sun.star.frame.XDesktop;
import com.sun.star.io.IOException;
import com.sun.star.lang.IllegalArgumentException;
import com.sun.star.util.CloseVetoException;
public class OOoEditor extends Composite {
public final String SWRITER = "private:factory/swriter";
private static final long serialVersionUID = -1408623115735065822L;
private OOoBean aBean;
public OOoEditor(Composite parent, int style) {
super(parent, style | SWT.NO_BACKGROUND | SWT.EMBEDDED);
try {
System.setProperty("sun.awt.noerasebackground", "true");
} catch (NoSuchMethodError error) {
/* Create and setting up frame */
Frame frame = SWT_AWT.new_Frame(this);
Panel panel = new Panel(new BorderLayout()) {
private static final long serialVersionUID = -5464002272885975878L;
public void update(java.awt.Graphics g) {
paint(g);
frame.add(panel);
JRootPane root = new JRootPane();
panel.add(root);
java.awt.Container contentPane = root.getContentPane();
JPanel p = new JPanel();
aBean = new OOoBean();
p.setLayout(new java.awt.BorderLayout());
p.add(aBean, java.awt.BorderLayout.CENTER);
contentPane.add(p);
public void setDocument(String url) throws IllegalArgumentException,
CloseVetoException, NoConnectionException, IOException,
SystemWindowException {
try {
aBean.loadFromURL(url, null);
// try {
// XPropertySet ps = (XPropertySet) UnoRuntime.queryInterface(XPropertySet.class, aBean.getFrame());
// try {
// XLayoutManager lm = (XLayoutManager) UnoRuntime.queryInterface(XLayoutManager.class, ps.getPropertyValue("LayoutManager"));
//// lm.hideElement("private:resource/menubar/menubar");
// lm.showElement("private:resource/menubar/menubar");
// } catch (UnknownPropertyException e) {
// e.printStackTrace();
// } catch (WrappedTargetException e) {
// } catch (NoConnectionException e) {
} catch (IllegalArgumentException e) {
} catch (java.io.IOException e) {
aBean.aquireSystemWindow();
* closes the bean viewer and tries to terminate OOo.
public void terminate() throws NoConnectionException {
setVisible(false);
XDesktop xDesktop = null;
xDesktop = aBean.getOOoDesktop();
aBean.stopOOoConnection();
if (xDesktop != null)
xDesktop.terminate();
* closes the bean viewer, leaves OOo running.
public void close() {
setVisible(false);
private static final String OFFICE_DOCUMENT = "file:///C:/Users/mauro/Downloads/TeX/Libro/yWriter/RTF5/RTF_00007.rtf";
private static final String NEW_WRITER_DOCUMENT = "private:factory/swriter";
boolean empty = false;
final Display display = new Display();
final Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
shell.setSize(900, 800);
final OOoEditor viewer = new OOoEditor(shell, SWT.NONE);
try {
if (empty) {
viewer.setDocument(NEW_WRITER_DOCUMENT);
} else {
viewer.setDocument(OFFICE_DOCUMENT);
} catch (Exception e) {
shell.open();
shell.addDisposeListener(new DisposeListener() {
public void widgetDisposed(DisposeEvent e) {
try {
viewer.close();
} catch (RuntimeException exception) {
exception.printStackTrace();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
Unfortunately when I try to use it in an EditorPart I get a runtime error.
I'm trying to use like this:
public void createPartControl(Composite parent) {
GridData gridData = new GridData();
gridData.horizontalAlignment = GridData.FILL;
gridData.grabExcessHorizontalSpace = true;
gridData.grabExcessVerticalSpace = true;
gridData.verticalAlignment = GridData.FILL;
top = new Composite(parent, SWT.NONE);
top.setLayout(new GridLayout());
oooE = new OOoEditor(top, SWT.NONE);
oooE.setLayoutData(gridData);
but it bombs out at the oooE = new OOoEditor(top, SWT.NONE); line with error:
/Users/mauro/Downloads/TeX/Libro/yWriter/RTF5/RTF_00004.rtf
!SESSION 2009-11-20 19:15:49.510 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_17
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Framework arguments: -product it.condarelli.rcp.yw.product
Command-line arguments: -product it.condarelli.rcp.yw.product -data C:\Users\mauro\workspace/../runtime-it.condarelli.rcp.yw.product -dev file:C:/Users/mauro/workspace/.metadata/.plugins/org.eclipse.pde.core/it.condarelli.rcp.yw.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.ui 4 0 2009-11-20 19:15:57.937
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NoClassDefFoundError: com/sun/star/comp/beans/OOoBean
at it.condarelli.rcp.yw.RTFEditor.createPartControl(RTFEditor.java:65)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:662)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1608)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:778)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:677)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:638)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2854)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2762)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2754)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2705)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2701)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2685)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2668)
at it.condarelli.rcp.yw.Scene$1.widgetSelected(Scene.java:114)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:228)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at it.condarelli.rcp.yw.Application.start(Application.java:20)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: java.lang.ClassNotFoundException: com.sun.star.comp.beans.OOoBean
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:494)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:398)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 57 more
Apparently it is unable to find the import com.sun.star.comp.beans.OOoBean; in OOoEditor.java that is obviousli found ok when running the frame standalone.
I tried several configurations, including copying all required libs into the workspace.
I think it's obvious I do not understand how to set-up Referenced Libraries for RCP.
I have no problem uploading the whole project, if that's useful.
Can someone help me?
TiA
Mauro
FUDForum. Page generated in 0.06807 seconds
