Home » Modeling » EMF » Attribute of an EAttribute?!
Attribute of an EAttribute?! [message #499043] Thu, 19 November 2009 10:59 Go to next message
Hi all,
I am trying something not very common:
A client using the software I am developing with EMF would like to use
the XML file (of the resource) being produced by my application for it's
own purposes: a certified validation. I am generally interested in this
information and would like to apply the tag internally. He suggested to
"simply" add a tag to each attribute in the XML resource as he's not
using EMF, not even Java and this would be most convenient in fact.
So basically I would like to change my Resource XML file from:
<namespace:attr_name>attr_value</namespace:attr_name>
to:
<namespace:attr_name tag="checked">attr_value</namespace:attr_name>
....for certain attributes or (if that is simpler to do) for every attribute.
I though I could "model" this in a way directly with Ecore to
auto-generate the getter and setter for this tag (visibility I would
take care of). But surely this does not work as this would mean to do an
"attribute for an EAttribute".
In addition it does not really belong to my data model as it should just
trigger a flag in the *one* specific view on my data model.
Any idea / hint / advise how I can achive this efficiently?
With best regards, Morten.
Re: Attribute of an EAttribute?! [message #499122 is a reply to message #499043] Thu, 19 November 2009 18:19 Go to previous messageGo to next message
Morten,
The only way to achieve this via a schema would be to make attr_name a
complex type with an attribute and simple content; that would map to an
EClass with to features in Ecore. So there's really no way to make two
attributes of a class come out like this. I think you'd need to
specialize XMLSaveImpl and XMLHandler...
Morten MacFly wrote:
> Hi all,
> to:
Re: Attribute of an EAttribute?! [message #499145 is a reply to message #499122] Fri, 20 November 2009 01:04 Go to previous messageGo to next message
Hi Ed,
Ok, I thought about that way, too.
BTW: I figured out something strange while lookinh into this. As
mentioned my XML file looks like below:
When I played with an example model I realised that it stores it's
attributes like:
<Object attr1="xxx" attr2="yyy" />
and so on. I created that sample from an XSD.
When I compared the Ecore models I realised 3 tags missing in my model:
1.) an ExtendedMetaData at the root node with a child "qualified" set to
false.
2.) an EStringToStringMapEntry at the "DocumentRoot" called
"xMLNSPrefixMap" with two ExtendedMetaData attributes "kind"="attribute"
and "name="xmlns:prefix".
3.) an EStringToStringMapEntry at the "DocumentRoot" called
"xSISchemaLocation" with two ExtendedMetaData attributes
"kind"="attribute" and "name="xsi:schemaLocation".
When I apply these to my model, too the persitence file (XML file) looks
now like the sample one. Thus, attributes are now XML node attributes
and not XML nodes. I wonder where this comes from and where I can read
about such advanced "control mechanisms"...?!
>> Hi all,
>> to:
>> attribute.
Re: Attribute of an EAttribute?! [message #499243 is a reply to message #499145] Fri, 20 November 2009 09:33 Go to previous message
--------------020807060609070608040602
Morten,
Comments below.
> Hi Ed,
> attributes like:
By default EAttributes will tend to be saved as XML attributes, but
extended meta data can be used to force out an element instead.
> false.
These are good things to read:
Binding XML to Java
< http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava>
XML Schema to Ecore Mapping
< http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf>
>>> Hi all,
>>> to:
>>> attribute.
<html>
<head>
</head>
Morten,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:he5bh2$a5k$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
</pre>
<blockquote type="cite">
<pre wrap="">I think you'd need to
</pre>
</blockquote>
<pre wrap=""><!---->Ok, I thought about that way, too.
</pre>
<pre wrap=""> &lt;namespace:attr_name&gt;attr_value&lt;/namesp ace:attr_name&gt;
</pre>
</blockquote>
</blockquote>
attributes like:
&lt;Object attr1="xxx" attr2="yyy" /&gt;
</pre>
</blockquote>
extended meta data can be used to force out an element instead.<br>
<pre wrap="">
false.
</pre>
</blockquote>
These are good things to read:<br>
<blockquote><a target="_out"
href=" http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava">Binding
XML to Java</a><br>
<a
href=" http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf">XML
Schema to Ecore Mapping</a><br>
</blockquote>
<pre wrap="">
</pre>
<pre wrap="">Morten MacFly wrote:
</pre>
<pre wrap="">Hi all,
to:
&lt;namespace:attr_name tag="checked"&gt;attr_value&lt;/namespace:attr_name&gt;
attribute.
</pre>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------020807060609070608040602--
Previous Topic:EMF 2.2 missing OPTION_ELEMENT_HANDLER
Next Topic:Advanced Drag & Drop
Current Time: Sat Nov 08 00:02:57 EST 2025
Powered by FUDForum. Page generated in 0.06618 seconds
