Home » Modeling » EMF » EMF 2.2 missing OPTION_ELEMENT_HANDLER
EMF 2.2 missing OPTION_ELEMENT_HANDLER [message #498941] Thu, 19 November 2009 04:43 Go to next message
Hello newsgroup,
I'm using EMF 2.2 for Java 1.4 compatibility reason and I have to handle
an abstract type. I know about the mighty solution from
http://ed-merks.blogspot.com/2007/12/winters-icy-grip.html
but I have an issue in EMF 2.2 that I cannot found a solution for, I
hope you can give me a hand.
-I have added ecore:ignoreSubstitutionGroups="true" to XSD and created
the model and generated code.
-I cannot add the line
result.getDefaultSaveOptions().put(XMLResource.OPTION_ELEMEN T_HANDLER,
new ElementHandlerImpl(false));
as it seems not available in this version of EMF runtime
-Using the setter present (due to first point) I still get an xsi:type
in my XML output.
-I cannot use anymore the code like (due to first point also)
folder1.getMembersGroup().add
(ResourcePackage.Literals.DOCUMENT_ROOT__FILE, file1);
What could I do, in order to remove the xsi:type ?? Is the only solution
for this version of EMF is to not use the ignoreSubstitutionGroups and
old style code ???
Philippe Weber
Re: EMF 2.2 missing OPTION_ELEMENT_HANDLER [message #498972 is a reply to message #498941] Thu, 19 November 2009 06:40 Go to previous messageGo to next message
Philippe,
Sorry, the newer support simply isn't available in older releases so
yes, you're stuck with the more complex substitution group APIs.
Philippe Weber wrote:
> Hello newsgroup,
> handle an abstract type. I know about the mighty solution from
> in my XML output.
> solution for this version of EMF is to not use the
> ignoreSubstitutionGroups and old style code ???
> Thanks
> Philippe Weber
Re: EMF 2.2 missing OPTION_ELEMENT_HANDLER [message #499219 is a reply to message #498972] Fri, 20 November 2009 07:58 Go to previous message
Thanks Ed for the quick reply as always.
Ed Merks wrote:
> Philippe,
>> Hello newsgroup,
>> in my XML output.
>> Thanks
>> Philippe Weber
Previous Topic:Customizing standard EMF editor Drag & Drop behavior
Next Topic:Attribute of an EAttribute?!
Current Time: Sat Nov 08 00:03:01 EST 2025
Powered by FUDForum. Page generated in 0.03807 seconds
