Home » Modeling » EMF » [CDO] Support for external proxies
[CDO] Support for external proxies [message #498727] Wed, 18 November 2009 07:16 Go to next message
Hi!
I'm currenty experiencing problems concerning references from cdo
objects to external (non-cdo) proxies.
What I'd like to do is to set a reference from a cdo object to an
external (non-cdo) object. But as the object graph of the external
object is rather large, and I do not have an instance of that object
(I'd have to load it from another, non-loaded resource first), I only
want to create a proxy manually (I know the object's uri) and simply set
the proxy.
The problem is that when I commit the transaction, CDO throws a
DanglingReferenceException because the external proxy is not contained
in a resource, which seems strange as proxies are never contained in any
resource.
The last part of the StackTrace:
org.eclipse.emf.cdo.util.DanglingReferenceException: The object
"com.dgr.profi.offert.impl.OffertKopfImpl@1494cc8 (eProxyURI:
profi://laspalmas:1099/Offert?id=193#/)(com.dgr.profi.offert.impl.OffertKopfImpl)"
is not contained in a resource
org.eclipse.emf.internal.cdo.view.CDOViewImpl.provideCDOID(C DOViewImpl.java:922)
org.eclipse.emf.cdo.spi.common.revision.AbstractCDORevision. writeValues(AbstractCDORevision.java:653)
org.eclipse.emf.cdo.spi.common.revision.AbstractCDORevision. write(AbstractCDORevision.java:168)
org.eclipse.emf.cdo.internal.common.io.CDODataOutputImpl.wri teCDORevision(CDODataOutputImpl.java:160)
org.eclipse.emf.internal.cdo.net4j.protocol.CommitTransactio nRequest.writeRevisions(CommitTransactionRequest.java:307)
org.eclipse.emf.internal.cdo.net4j.protocol.CommitTransactio nRequest.requestingCommit(CommitTransactionRequest.java:209)
Is this a bug or simply a limitation?
Mario
Re: [CDO] Support for external proxies [message #498957 is a reply to message #498727] Thu, 19 November 2009 05:38 Go to previous messageGo to next message
Hi Mario,
I believe external proxies were actually supported in CDO. I would say
it is a bug... maybe the others can clarify.
Could you reference that object instead of manually setting the proxy
URI and see what happens?
I'll try to create a test case anyway to try to reproduce your problem.
I think Eike is at the Modeling Days so he isn't showing around, but he
will jump in as the trip finishes ;)
Víctor.
Mario Winterer escribió:
> Hi!
> the proxy.
> resource.
> at
> at
> at
> at
> at
> at
> Mario
Re: [CDO] Support for external proxies [message #498978 is a reply to message #498957] Thu, 19 November 2009 07:17 Go to previous messageGo to next message
Victor,
thanks for your response.
I've tried two possible scenarios:
(1) Manual proxy without resource
a) Create new shallow instance that represents the external object
b) Set the proxy URI
c) Add the object to a CDOObject (so the CDOObject references the
external object after this step)
d) Commit the transaction.
Result: DanglingHrefException, saying the external object is not
contained in any resource (which seems wrong as a proxy should never be
contained in any resource).
(2) Manual proxy contained in a resource
a) Create a new resource and add it to the CDOTransaction's ResourcSet
b) Create new shallow instance that represents the external object
c) Set the proxy URI
d) Add the object to the contents of the newly created resource
e) Add the object to a CDOObject (so the CDOObject references the
f) Commit the transaction.
Result: Changes are saved. If the proxy is navigated afterwards, proxy
resolution is performed but does not change anything, because the proxy
resolution mechanism simply loads the external resource using the proxy
URI. But because this resource is already loaded (it is the resource
that was created in step a), no additional loading takes place and the
proxy itself is returned from that resource instead.
I think, maybe the last lines of CDOViewImpl.provideCDOID(Object) should
be modified:
Now:
if (eObject.eResource() != null)
return CDOIDUtil.createExternal(uri);
throw new DanglingReferenceException(eObject);
Suggestion:
if ((eObject.eResource() != null) || eObject.isProxy())
Mario
Víctor Roldán Betancort schrieb:
> Hi Mario,
> Cheers,
> Víctor.
>> Hi!
>> set the proxy.
>> any resource.
>> at
>> at
>> at
>> at
>> at
>> at
>> Mario
Re: [CDO] Support for external proxies [message #499005 is a reply to message #498978] Thu, 19 November 2009 09:02 Go to previous messageGo to next message
Hi Mario,
To me that sounds reasonable and I'll further clarify this with Ed. Can
you please file a bugzilla?
Cheers
/Eike
Mario Winterer schrieb:
> Victor,
> be contained in any resource).
> proxy resolution mechanism simply loads the external resource using
> the proxy URI. But because this resource is already loaded (it is the
> resource that was created in step a), no additional loading takes
> place and the proxy itself is returned from that resource instead.
> should be modified:
> Now:
> Suggestion:
> Mario
>> Hi Mario,
>> say it is a bug... maybe the others can clarify.
>> he will jump in as the trip finishes ;)
>> Cheers,
>> Víctor.
>>> Hi!
>>> only want to create a proxy manually (I know the object's uri) and
>>> simply set the proxy.
>>> contained in a resource, which seems strange as proxies are never
>>> contained in any resource.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Mario
Re: [CDO] Support for external proxies [message #499006 is a reply to message #498978] Thu, 19 November 2009 09:14 Go to previous messageGo to next message
Hi Mario,
Your fix is good. Please file a bugzilla.
Cheers
/Eike
> Victor,
> should be modified:
> Now:
> Suggestion:
> Mario
>> Hi Mario,
>> Cheers,
>> Víctor.
>>> Hi!
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Mario
Re: [CDO] Support for external proxies [message #499015 is a reply to message #499005] Thu, 19 November 2009 09:32 Go to previous messageGo to next message
Thanks Eike.
I've filed bug #295590
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=295590)
Mario
Eike Stepper schrieb:
> Hi Mario,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Victor,
>> should be modified:
>> Now:
>> Suggestion:
>> Mario
>>> Hi Mario,
>>> Cheers,
>>> Víctor.
>>>> Hi!
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Mario
Re: [CDO] Support for external proxies [message #499016 is a reply to message #498978] Thu, 19 November 2009 09:35 Go to previous messageGo to next message
Hi Mario,
thanks for your deep analysis. By looking at the current code and the
two scenarios that you described, I would you've identified a bug :P
Could you please submit a new bug for this? The description you provided
should be enough :D You can also provide a patch if you want. I'll try
to execute the whole test-suite to see if things keep working as
expected with your change proposal.
Thanks!
Víctor.
> Victor,
> be modified:
> Now:
> Suggestion:
> Mario
>> Hi Mario,
>> Cheers,
>> Víctor.
>>> Hi!
>>> set the proxy.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Mario
Re: [CDO] Support for external proxies [message #499017 is a reply to message #499006] Thu, 19 November 2009 09:40 Go to previous message
I've attached a patch to bug 295590
Mario
> Hi Mario,
> Cheers
> /Eike
>> Victor,
>> should be modified:
>> Now:
>> Suggestion:
>> Mario
>>> Hi Mario,
>>> Cheers,
>>> Víctor.
>>>> Hi!
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Mario
Previous Topic:[CDO - H2] Invalid value for parameter url [90008-114]
Next Topic:[CDO] how to register package ?
Current Time: Sat Nov 08 00:03:02 EST 2025
Powered by FUDForum. Page generated in 0.04482 seconds
