| [CDO - H2] Invalid value for parameter url [90008-114] [message #498653] |
Tue, 17 November 2009 16:43  |
Hello all,
I already config a H2 database for CDO, but when i run it i get this
error :
[ERROR] org.h2.jdbc.JdbcSQLException: Invalid value for parameter url
[90008-114]
org.eclipse.net4j.db.DBException: org.h2.jdbc.JdbcSQLException:
org.eclipse.net4j.internal.db.DataSourceConnectionProvider.g etConnection
(DataSourceConnectionProvider.java:46)
at org.eclipse.emf.cdo.server.internal.db.DBStore.getConnection
(DBStore.java:180)
at org.eclipse.emf.cdo.server.internal.db.DBStore.doActivate
(DBStore.java:230)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycl e.java:
65)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate
(LifecycleUtil.java:94)
(LifecycleUtil.java:84)
at org.eclipse.emf.cdo.internal.server.Repository.doActivate
(Repository.java:581)
65)
at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository
(CDOServerUtil.java:73)
org.eclipse.emf.cdo.internal.server.RepositoryConfigurator.c onfigure
(RepositoryConfigurator.java:83)
org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplicat ion.doStart
(CDOServerApplication.java:51)
at org.eclipse.net4j.util.om.OSGiApplication.start
(OSGiApplication.java:61)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run
(EclipseAppHandle.java:194)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication
(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start
(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run
(EclipseStarter.java:368)
(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: org.h2.jdbc.JdbcSQLException: Invalid value for parameter
url [90008-114]
at org.h2.message.Message.getSQLException(Message.java:105)
at org.h2.message.Message.getSQLException(Message.java:116)
at org.h2.message.Message.getInvalidValueException(Message.java :172)
at org.h2.engine.ConnectionInfo.<init>(ConnectionInfo.java:66)
at org.h2.jdbc.JdbcConnection.<init>(JdbcConnection.java:89)
at org.h2.jdbcx.JdbcDataSource.getJdbcConnection(JdbcDataSource .java:
178)
at org.h2.jdbcx.JdbcDataSource.getConnection(JdbcDataSource.jav a:153)
(DataSourceConnectionProvider.java:42)
... 26 more
and here is my config :
<dbAdapter name="h2" />
<dataSource class="org.h2.jdbcx.JdbcDataSource" url="jdbc:h2:tcp://
localhost/test"
user="sa" password="" />
| Re: [CDO - H2] Invalid value for parameter url [90008-114] [message #498995 is a reply to message #498910] |
Thu, 19 November 2009 08:27  |
Hey guys,
There is a bugzilla for that, but it confused me and I was not sure
whether it's a Net4j DB problem or an H2 one. I'll look the bugzilla up
when I'm home...
Cheers
/Eike
Stefan Winkler schrieb:
> Whoops?!
> Is there a bug for that? (If not, could you please open one)
> 'cause that should definitely not be that way!
> Cheers
> Stefan
> Frank Froehlich schrieb:
>> please use 'uRL' for the attribute name, not 'url' (yes, looks ugly, but it
>> works). There seem to be some deficiencies in the mapping of attribute names
>> to the approptiate setter methods of a data source.
>> Rgards
>> Frank
>> "Rencana Tarigan" <rencana_tarigan@yahoo.co.id> schrieb im Newsbeitrag
>> news:hdv5e9$cdk$1@build.eclipse.org...
>>> Hello all,
>>> error :
>>> [90008-114]
>>> at
>>> (DBStore.java:180)
>>> (DBStore.java:230)
>>> e.java:
>>> 65)
>>> e.java:
>>> 65)
>>> at
>>> at
>>> at
>>> .runApplication
>>> .start
>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>>> at java.lang.reflect.Method.invoke(Unknown Source)
>>> 559)
>>> url [90008-114]
>>> :172)
>>> .java:
>>> 178)
>>> a:153)
>>> at
>>> ... 26 more
>>> url="jdbc:h2:tcp://
>>> localhost/test"
FUDForum. Page generated in 0.03773 seconds
