Home » Modeling » EMF » Ecore model of w3c ws-policy (Help to create an ecore model from ws-plicy schema)
Ecore model of w3c ws-policy [message #498644] Tue, 17 November 2009 15:50 Go to next message
I need to create a model of ws-policy framework except the attachhment part.
I'm thinking to create it (and i've just tried to make it) the ecore model from the schema (only a part of the schema) but probably to obtain a sensate model I need to adjust my schema.
Where are the problem in the translate to ecore model of this schema and how to resolve it:
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:tns="http://www.w3.org/ns/ws-policy"
xmlns:wsse=" http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wsse curity-secext-1.0.xsd"
xmlns:wsu=" http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wsse curity-utility-1.0.xsd"
targetNamespace="http://www.w3.org/ns/ws-policy" blockDefault="#all"
elementFormDefault="qualified">
<xs:import
namespace=" http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wsse curity-secext-1.0.xsd"
schemaLocation=" http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wsse curity-secext-1.0.xsd" />
<xs:import
namespace=" http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wsse curity-utility-1.0.xsd"
schemaLocation=" http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wsse curity-utility-1.0.xsd" />
<xs:element name="Policy" >
<xs:complexType>
<xs:complexContent>
<xs:extension base="tns:OperatorContentType" >
<xs:attribute name="Name" type="xs:anyURI" />
<xs:anyAttribute namespace="##any" processContents="lax" />
</xs:extension>
</xs:complexContent>
</xs:complexType>
</xs:element>
<xs:element name="All" type="tns:OperatorContentType" />
<xs:element name="ExactlyOne" type="tns:OperatorContentType" />
<xs:complexType name="OperatorContentType" >
<xs:sequence>
<xs:choice minOccurs="0" maxOccurs="unbounded" >
<xs:element ref="tns:Policy" />
<xs:element ref="tns:All" />
<xs:element ref="tns:ExactlyOne" />
<xs:element ref="tns:PolicyReference" />
<xs:any namespace="##other" processContents="lax" />
</xs:choice>
</xs:sequence>
</xs:complexType>
<xs:element name="PolicyReference" >
<xs:complexType>
<xs:sequence>
<xs:any namespace="##any" processContents="lax" minOccurs="0" maxOccurs="unbounded"/>
</xs:sequence>
<xs:attribute name="URI" type="xs:anyURI" use="required" />
<xs:attribute name="Digest" type="xs:base64Binary" />
<xs:attribute name="DigestAlgorithm" type="xs:anyURI" default="http://www.w3.org/ns/ws-policy/Sha1Exc" />
</xs:complexType>
</xs:element>
<xs:attribute name="Optional" type="xs:boolean" default="false" />
<xs:attribute name="Ignorable" type="xs:boolean" default="false" />
</xs:schema>
Re: Ecore model of w3c ws-policy [message #498731 is a reply to message #498644] Wed, 18 November 2009 07:32 Go to previous messageGo to next message
Comments below.
M. wrote:
> part.
What do you mean by that?
What problem are you having? It works fine for me...
> <xs:import
> <xs:import
> <xs:complexType>
> <xs:complexContent>
> </xs:extension>
> </xs:complexType>
> </xs:element>
> <xs:sequence>
> </xs:choice>
> </xs:sequence>
> </xs:complexType>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:schema>
Re: Ecore model of w3c ws-policy [message #498765 is a reply to message #498731] Wed, 18 November 2009 10:14 Go to previous messageGo to next message
Actually from this schema (deleting line about "import from oasis")I create the ecore and genmodel, thus I'm able to generate the code and run as eclipse plugin.
In the second eclipse instance when i test the plug-in, I don't understand the mean of child (first child of resource) called "DocumetRoot false", and the impossibilty to add a child "policy" that should be my "element root" (mor external tag <policy ..all the doc ..</policy>).
I've tried to select "policy" in the last window of "policy model" creation wizard thinking tht it will be apper as first child of my resource, but nothing..
Re: Ecore model of w3c ws-policy [message #498837 is a reply to message #498765] Wed, 18 November 2009 13:26 Go to previous message
--------------020901000102010604030402
Content-Type: text/plain; charset=UTF-8; format=flowed
Have a read through
Binding XML to Java
< http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava>
You might want to use this option (and note the comment about needing an
element handler during load).
* When {@link #OPTION_EXTENDED_META_DATA} is used,
* this load option set to Boolean.TRUE will direct the
deserializer to suppress creating a document root instance.
* This option is typically used in combination with {@link
#OPTION_ELEMENT_HANDLER}.
* @since 2.4
String OPTION_SUPPRESS_DOCUMENT_ROOT = "SUPPRESS_DOCUMENT_ROOT";
> ..</policy>).
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Have a read through<br>
<blockquote><a target="_out"
href=" http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava">Binding
XML to Java</a><br>
</blockquote>
an element handler during load).<br>
<blockquote>  /**<br>
   * When {@link #OPTION_EXTENDED_META_DATA} is used, <br>
   * this load option set to Boolean.TRUE will direct the deserializer
to suppress creating a document root instance.<br>
#OPTION_ELEMENT_HANDLER}.<br>
   * @since 2.4<br>
   */<br>
  String OPTION_SUPPRESS_DOCUMENT_ROOT = "SUPPRESS_DOCUMENT_ROOT";<br>
</blockquote>
<br>
<br>
M. wrote:
<blockquote cite="mid:he1325$mbi$1@build.eclipse.org" type="cite">Actually
eclipse plugin.
<br>
<br>
should be my "element root" (mor external tag &lt;policy ..all the doc
...&lt;/policy&gt;).
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------020901000102010604030402--
Previous Topic:Re: [EMF Compare] Move of an element
Next Topic:[solved] XML Schema Definition Editor with KEY and KEYREF
Current Time: Sat Nov 08 00:03:03 EST 2025
Powered by FUDForum. Page generated in 0.03106 seconds
