Re: Dynamically adding barcode - how to extract info from birt? [message #498003 is a reply to message #497538] |
Fri, 13 November 2009 16:14 |
Tobias,
No sure what you are looking for but you can add an embedded image to a
table and then change its content on the onCreate script. See attached
example. Note that you will need to replace the image that I used in
the script.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.20"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.1.v20090903 Build <2.5.1.v20090917-1447></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 <<Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">auto layout</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="pl" id="8">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">PRODUCTLINE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">TEXTDESCRIPTION</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">HTMLDESCRIPTION</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">IMAGE</property>
<property name="dataType">blob</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">PRODUCTLINE</property>
</structure>
<structure>
<property name="nativeName">TEXTDESCRIPTION</property>
</structure>
<structure>
<property name="nativeName">HTMLDESCRIPTION</property>
</structure>
<structure>
<property name="nativeName">IMAGE</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from productlines]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">1in</property>
<property name="leftMargin">1.25in</property>
<property name="bottomMargin">1in</property>
<property name="rightMargin">1.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="10">
<property name="width">100%</property>
<property name="dataSet">pl</property>
<list-property name="boundDataColumns">
<structure>
<text-property
name="displayName">PRODUCTLINE</text-property>
<expression
name="expression">dataSetRow["PRODUCTLINE"]</expression >
</structure>
<structure>
<text-property
name="displayName">TEXTDESCRIPTION</text-property>
<expression
name="expression">dataSetRow["TEXTDESCRIPTION"]</expression >
</structure>
<structure>
<text-property
name="displayName">HTMLDESCRIPTION</text-property>
<expression
name="expression">dataSetRow["HTMLDESCRIPTION"]</expression >
</structure>
<structure>
<text-property name="displayName">IMAGE</text-property>
<expression
name="expression">dataSetRow["IMAGE"]</expression>
</structure>
</list-property>
<column id="34"/>
<column id="37"/>
<header>
<row id="11">
<cell id="12">
<label id="13">
<text-property
name="text">PRODUCTLINE</text-property>
</label>
</cell>
<cell id="18">
<label id="19">
<text-property
name="text">IMAGE</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="20">
<cell id="21">
<data id="22">
<property
name="resultSetColumn">PRODUCTLINE</property>
</data>
</cell>
<cell id="27">
<image id="39">
<property name="height">18px</property>
<property name="width">18px</property>
<method
name="onCreate"><![CDATA[importPackage(Packages.java.io);
importPackage(Packages.java.lang);
var pl =this.getRowData().getColumnValue("PRODUCTLINE")
if( pl == "Ships" ){
var file = new File("c:/temp/test.png");
var ist = new FileInputStream(file);
var lengthi = file.length();
bytesa = new ByteArrayOutputStream( lengthi);
var c;
while((c=ist.read()) != -1){
bytesa.write(c);
ist.close();
this.data = bytesa.toByteArray();
}]]></method>
<property name="source">embed</property>
<property
name="imageName">esmall.bmp</property>
</image>
</cell>
</row>
</detail>
<footer>
<row id="29">
<cell id="30"/>
<cell id="33"/>
</row>
</footer>
</table>
</body>
<list-property name="images">
<structure>
<property name="name">highlightstyle.PNG</property>
<property name="data">
iVBORw0KGgoAAAANSUhEUgAAA5EAAALOCAIAAAC/HwB+AAAAAXNSR0IArs4c 6QAAAARnQU1BAACxjwv8
YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpR PAAA7ldJREFUeF7svQmc
E1W6vx/1qjj3P/ObGed6dRa9zozOjDqOMIzOqDhuKCogLijuqAMi7gguyKLi Lu4b7qgoCMi+I/vWQENv
dNMN3dD73k1vSbo7Sef/Vk5zKKoqlVOVSlKVfPm8n1CpnDrn1FNVJ0+/Oakc 0dxc73K5jnC5gvSfK/j/
bi094oijpCXfsdKKo+iV0L9jekjLxx7l+q+jXP4APR5x1FHBQNDl73IdeaTr SJerq7ugy09P8A8EQCB6
AtKViH8gAALREjiiM9oasD0IgEBQ/pZEy4HDkHSwZ3StHePq9LuOCUlh55Gu Y/5LWufyS+ELKeXR5Jv/
FSr8Xy5f0NVRHVz7V1G65KwULc31R/TPpDjmvrZjRwWOHxv89fNS/OHF4J/e CPacHOz5fvD8d6To84EU
//4obLACCBAAgSgJ6FxleAkEQECcQJRXIjYHARDQdD9aybSQPzJRVIekkYcH 6SUF2eYxD/pd/8529dwc
FPjnYs5KtnrkHTUkrEc+2Hzs6C6qhWvrqa8GKchcz3z7UJDCspCvxDIIgAAI gAAIgAAIgEDyESAPZMF2
jS0z9WT5TaaLPGil/CnLhPJgnklx7CMBCteQVtcF2RGtVXJW1yXbXINKXTfs OWJYHYXrvgYW5K9HPew+
6pFOsljX44GjRgUp2DI98pVsga085rEuStOykggQAAEQAAEQSDiBIx7sQoAA CERJgC5kqoHZILM+FkeM
7DxyWMdRI9qOGtZ8xFC3664W162hx9ta6Gn3mqGNLha310uP9OrgWteQOilo DcWNZa7Lclx9CvW19aCz
XrPDdev+Q3FnleueGuavZK4sJH8NE9Kr1F0ew5qp6wgQAAEQAAEQAAEQAIHk JHBv/VEUd9cdcXctfVZP
4bq1yjWkUorBFd1BMsrihhIpBhVTHDGg0HU1Rb7ryt1S0AIJ63nbXSfOiuCs rl7rpC3JWW/Y0x1MXkPa
ys21O/l6f4uLx8F0LL0k2a1copk1I0AABKIiUOO6HQECIAACIAAC9iBASqoI pqcqJT1opQfdlKyUBZNU
MlQKmsbaJ707SFhJRyn+Z6qOtrq6C12yjaa0hnNWNmdAPm2Aeaq0htKxd9e6 7qyRgt5f2c4wy0aAAAiA
AAiAAAiAAAhYTeDoWyuGf1BX0eCLOAdUUYC2om2ZoZmv5P3ao28KZU8HlR59 ffHwd6oq6o335OX9R1+Q
LqVXe26WXPSMpa7TZ0dy1j9+JxVVOmu5PM/KnZV7qkxVq6SS3LsVOWGeHMYC CICAUQL8IxUsgAAIREOA
fSiJAIEkIjD8vZrCisDjn7QPnewd/IJnwARPv7HuS59wX/6U+6LHpbjgMSn+ /mAbxTkj2/78n7ZT7jjQ
+77i7L0ttC27HKKthL4KNUgS1s6SwrrXH695ZmjVY4MrRw6oGN6v/O5Ly++9 vPyuiyjKbr+AovSmv0tx
wznFA/5c2PeUzBt6H8jPHv7yfklYmbP+frmLjPRn43XzrCfOkor2ST+yrzzP KjmrlEANpVGPuFea2yoF
LR9ceVhiVZ5bjWZkwbYgAAIgAAIgYC2BJDIVmDcIMAIkdk981v723I73F3S8 OL19zGftD3/UPuJd7/C3
vfe86b1rsvfO1723vOK56UXPoOc9V41z/3uMu9cDLX+4veyc2zdRTtSaSkKT U6kn9W88ceCbt5u+e7/x
kxfr3hhT+/LDtc+NqJk4vGbcPdVP31X99J3VY26pGnVT5cODKkZcVT7038WD e2Ve8Ycl15xTUdvZnWc9
K82Ys0ozDGhKqzSZNZRkvTNkqweDzbFl02wPTQbQnA9gNJmE8iAAApoErH3b Rm0gkLIE4KwgkHQEyBSH
ve39aFHHJ0s7X53ZMXZq+6hP2h/6gLS1fdhbkrbe/Yb3jte8t7zsuX6Sp/8E z2VPus97uOXPd5X9zxXL
aVvurFFVQs56jeSsNROHNX3/UfPsTxo/f7X+nbF1r4+qffGhmudGVE8YRtpa 88zd1U/eUT36lspHrq8Y
2b/83stKbjkv++o/z/z7/0g9obkBFOSs/5cmlmelrCzNhKW5sdQ8DWqUNL29 5qihNddOLF34bf6OWZlb
pmd8+Nyq559ZMXb00jsfWPW3u3f89PYS7Twr5AMEQAAEQAAEQAAEQCCWBMj2 hrzkIVt944eOid+0P/Zx
+8j32v/zpvdO8tSXvDc+77nuWc8149xXj5NmC1CS9fxRbb0fbDnj7rIT+62U TDHUt2grGVDGnLV69BCy
1QNfvdHwwcS61x6rnTSyZvx/qp+6s+rxW6oeubHyoesqRlxTMeJqabbA0H+X 3X5+8U29s/ufMfvcE6We
nJstBXNWms8aeW6AlrOOf6uwaMP+svTSjYt3f/L+1mfHrhw7esnjD88bed+s u4dO63PLwl/cmnfoS1fq
uxvE8lAduocCWgEBEAABEAABEACBFCNAtnf9856nv2wf95UkrPe90z6UJgO8 6L3hOc+AZzxXPOm+5HH3
+Y+0/fNhUtW2Xg+29Xyg7Zz7m8+6p/x3/X+UO6u8kohf51JWctBZqx65vv6d p+vfG0fC6k1fT/VUjbql
6qEbKkYMKP/PFeV3XVJ22/llt/yT1reu/KF0cM/9N5yTM/CsH87/nXFn/fWP Ulb2AsqzFkq54sEVR9xW
9e/H9ucuyqvOLi/ZU7/mx6Kvv9z5dEhYH7hv5j1Dpw25+fNrB35wTv/vewzZ p/j2lXyHmz1dq3LaE+KX
vBvtnV2ZxZ0m+lDTFKAwsaHIJgpK8h6aa9cm2OX7PuKTJupVQaWP/SXHrxAR PobK8IbUrcjXRARbUuen
s0XdtHy96UoU1dIRp7Y4H/H9DddJ8RpMlDTRaERQJroh30QxsOrUZujwmeuV +miGG3/kJ+Snq9wmTgBz
PcRWrusqECCQZARoAKHvXdEc1kdDGdZ7JrffRunVZ70krFc+6bl4FAmru/dD bec80PbX+9vOut/91/vd
Z9/fcta9Fd3OGrooFJVEdFZlJQedlb53Vffyw3WvPUoZVl5JSFivLL/rYhLW 0pt68/Wl1/91//Vn5wzQ
ctbI38EiZ6Ws7MWhe2jRxIDBFUfeWj39/ay9czNz1hZu2ViydFH+xx9sGcWE 9a5pt9z8GQlr3yvevLDP
SydcvUK6hewt1d0xpJL16ScnTqLYml5Oy1lFntiNmFv2dJAZq+vn3Xj4iSUt reQHhu2T3nRrGzuOO3dh
LDovp7RkxR56WlrTLff67Ubc38Ril7NamO6l/Zo1d9dxfdbw/dWBGW7XIvLn Dalbka+JeEC7C5/5laJF
+XrTlcj3jiyK6nz28+J3p+a2d/j3lHZfICIEwnUyIqWIBXRaN9FoRFAR+6Nf QH4FsdEmXHlDh89ErzSP
ZrjxR35C0h8tFNRzukBMtItNQAAEUpwAjSdXPO2m2askrMPear/zVe/Nk7yD Jniuftpz2Rh3n8fc5z7c
9rcH3Gfe7/7zfe4/DXefMcJ91v0tZ9xT/tv+q2hbRk9RSURnVVZy0Fkrhl1B s1elKQEThlU/eSevp/zu
y8rv6FM25NxDwjrwT6WDzii+7qycAWf88K/fSj35Z75koX/JFJsbIHdW8u7B FUfdVp0+LT3r002Lvs2Y
O3vXF59um/jMUpoSEBLWz6+9loT1DRLWXr0nnvyvKUfdUU8hTRIImavCG9jT HhdviNG51d1cz1nanhF6
J/t8ZSsVy85vNNoHEtZYOys/aaiHx52/nD3VaVdkf9lZmBDscsLsvZz+Zjj2 6hy1TYb9M0N1KCMeNd6Q
uhXFGv0DGq6TVlYS2jte4dGDio4ZWPCTM79i1hLu4MoJiJCMSEyzgE7r5hqN 3eUjZxhxZw0dvoi1hT1v
T5wkP5ryRuXjD19Pnz/Q8pez99DRN9EoNgEBEAABGkPIWelGV/e8Ic0KuO1l msPqHTjOc+VTnktGu89/
zN374ba/PuD+8/3uP97n/v1w92n3uf8youUv95b/5hqls/JKqE6dSuhVZSXX dM9nJWetHju0mu4SQI+j
b6t6+EY23NE/mr3Kl0sH/LH0mt+XDjiteNBfdvX/y5x//YZekpz1H/nGnZXu s0V3VyX1vL0m7/sdK9Iq
KZZtqVy8qWLhhvK5a0tnry6ZsXL/t8v2fb143xcLCj+Zt+fNr3YcdNZ66Udj D3PWWvoxWeoNZZJCWZDa
zOLu+83SgvQ7s6Fge0K5UnosqaNsaPd6ncL0Uii32r0tq4FvKK+WtctKtrS0 97h4s2Y3Pl3lpbQQ68a4
GW3ymtnm1DFpRzqDVGxVDs006K6zoJI+TZZapwJsQ8GQvaXVUoWse9Rbflzl e2Fuf+OGXU3vEPM2H+3U
f10vpdvpHzsctKDmxnecH0q2hu97uPOn++CGGpK3ojgNFGDDHVAqVlouTWng ZwI/GdRHR7wSxd6xsz17
V7X8bFGUYZWzk4oeaTk0U6X7nNe5oDQvBDlG1pDiilPz56c9K8kPn/rCjP/l o+DAd5kuJdZbeqRe6Z8D
mhw0T2bNsYg3qnM01eMPa/TLb3fSI+XXqcAx/fcKDhooBgIgAAKKd40LR7XR bQHo5gB3vCp974pmsg6c
4LlyrPuSp9znj3b3HuU+6xH3nx50/2Gk5//u9/x+hPu0+1tOu6fypGtWy99q 5ZXQep1K6FVlJZRnHVBG
68vuuJBuCyDdHOCJO2gma+UjN1Q8MFD+zkLL5df9qfzaP5T1/7+yAb8vufa0 3KtPm3veSVJPmLOyVCv9
rECE72DRF7VogyvKpakeZF2knrfX536/Y/Obq559guawzqcpAXff9c2Qm6Q5 rH37vnlBn5d69p7457Oe
POWPj/3P759gzhpKtUraeujtbUjdql2Sja3dsP8nZ33Dxv0lWxrZeJ1V6JYa kpVfsr5KeiPf20ort+yR
Cs9cXc8Kb82VVvLC9HHzF4trftJrjnxz6e0hVEZR7WFPe83R7EZ7yKUffnVX bV0bdePoG8jdD+0Is4d3
ZpS+OyWNFkqrvT36ZfICz31W/O5XeWw921AkFAeSntJOKfbI9P7GGbsmvemb 2qUDl14ebqfU3PiZww4l
e8qPdbhTQt6Qmqr8bOTLEQ7oK2voWFPh2oZ2xZlg4KwIXwnt3aerve0d0knV 4vbTsvqkZWUYwKMHlWzZ
I11HNIfkuHMX873oPpM3yy4orT+ZDmFcVPOTnj/Ibe/QFSf76/Hg5+zdf2Eu 2Vgn/2NAs1H2Z9vDr+R0
Xz6DaE78Ibfupj29pPvyqfL06JvBCzz3KU2QOHj5hDYUDPmxZpuwv/225rlp N/cWNazdVst08NA5EGZZ
zkG9LxE5k+YeOpoqUT7Mm3v+wDpDf0/SIwE5rs96wf1FMRAAARBQpyTOe7jt uuc8N78oCSs9Xk/fviJn
fcZzydOeC5509x7tPmuU5/RHPL9/yHPyA55TRnpOHdl66j2VJ1x1mLPKK6Gh SacSelVZyXV1bFJs2S3n
VT10XfWom6vpRgGP3Vz58PXSLwvcdyUfqytuPqvihtMrBv2+YsDJFQNOKR14 at5Vp879xwlUwNWn0HV+
QXeqle4bcPzr4d7NpcLSBALurCFhdQ1t3PpVumiedWjzUUObXbe1SDGkUdHS 1t1ues/r0S+bmQ0tH3v1
bjZq97h0Ky8f0hRpW7b+UOH+0lxPaWXfnfLCx/bfc8y1+xSb01MeMlmRVvKn mt1gmRJ6C/mvwdXHnbeU
eijfhG97zHXSLXzp33EXrpYXOPqG7k912XqR4HXSjpPT01N6l6WdUgPphia2 vxx+PLFr0ssslt6V6U8O
xYHT4RbukLFjHe6UkDckp8rcS14nXzZwQM9bGu6IRFMJ1fngR/WllVL2lP59 v76NnTMKAs3ugPThQN+d
jHBoloV07bBTItwFpTj9eHnNS6b74lJdiVSJon6dRuN/+chZdUv2kEbWDWm0 CY0Vx/17Iw074Q5fuJFH
vS8inNVHM9zJzK9Q0lw6uDSkiAwXKAMCIAACagI0nvR6oO2a8e4bJ3luesE7 eJKX7gAw4FlPv/GeS8d5
Lhzr6f2U569PeE5/3HvqY97fPuL57UOe345s++3dlb/st4a25e878kpovU4l 9KqyEslZpRxT6Y29Ku6/
purRG6seu6n60cF0G4HKBwfwEY8tVA0+ver6UysH/rZywG/L+v8274rfzvv7 L6WeXFDquqBYctY/5El5
1gjOekq2JLmUZ6XJlMxZ72r56r2c7Z9tmjJ24T2UYQ3dJaBv3ze6M6xnPvl/ f3z0xN898PMThh1z0aKj
7vZQHDHU7bpVCj5Ys68W0QegPa7MIp1VdF16d/nrt3y95KwHy9D6QyO+bKWi MLNkeclub1atHzdLyvlR
Ekj+8S7vDzVHBVraJKfeU+GjZUXN/G3sjSUdvB7tnof2Qt0N6ZBorWd7zas6 7pLNEauNuL/xx65Jj7/T
S+/Khx8mjYMrP/qHM1EgUpwnVLO8ITUczbaMHlDLK2EH/b9urqdPFahy+pPs WPoDTHUyT98snZOzlksz
K0qrpM+RaRPemXAXlP6ZFu6KU7euudeajcb/8jE9FEQ497SGAkHOiqMpb0g9 /tCfqew63ZrdqDheeBor
AkPowzoECCQVARpDzhzeRvdeHTjRQ6J5wyTPdeSsz3n7TfRcNtHTZ4LnH+M8 fx3rPf1J76mjvb95zHvi
w94TR7adcFfV/7tyraQloStCUQk91amEXlVWMrjZdZ00oa7k2jPp3quVDwwk W6165IbKh6/jg2fVsD5s
ucvdXH3jqdWDflM14MTyq0/cfekJC3r+P6knl1S7Li6RtPXsQslZ/+dd9cDL 17hc5KxUVHLWWiasFH2e
qF07NX3pW6vHDP9WPSXgf3838hcnDO9x5ltH3lZ15LAOpq3MXPlgTcultdKb 7hdL62mZuwXLi7BQlGfv
3/IcEivAVioK01PNNer1CzOlnB+9Txx3wcpw3Tjm1rolG6QvkNE3eWlZXvP4 H0KffYb+ldb5n3tlDdWj
7jm9yjqpCPnO8pfklHSqUhQT3N/4Y1fQe2OZdNz3FrdwIPIdEVlW7yk/cPJT QtGQPi7+qtEDqtnhaCqR
nyHdlZ/9nebBpVQrKxC6/cJ6+d+Emmcy+7tRHrzzfKV8Db+45DWzkrx+kUaP vrFuyfruy4eW5ZuMm6m6
fP65UtGcupO8t/zyibhf8g6HI6DYd3bNss50z/++1a3YF0HOh/3FftZ38oYW 7jw4/vxTuo83a7THVfns
On1ntoQLAQIgAAJGCdAActo9rX0eb+v3jHvgsx42vCj+/XWc9/Sn2//vSe9J j3tPeMR7/P1tP7+j+ieX
r6FifNRSVDLwOc81z3qunOi5dKLnwomecyd6eSW0lbISctbBzbS++JrTyu7s U3Ffv8oHB1Y+NIh3o2rE
pVXDLqy+59B9A2oGnVTd/4TyK4/P//fP5//1J1JPyFkpKNsq5KyUjJWctZYS vExYpffU/3QMn1T849T0
ee+sfXLkd5dd9lrP3hPYHNb/lTKsw487++1jbtp91IhOCtJWCtqE4tBgPbRj xFfSDS/pzeCYwVWr8qRP
7kgcF2YG6G1gS2GXa2gHBS9P62mZ8rI/OXs6vcrep9lKaVrk2dPlhdm2FIfe qA6uUVQ77gc/laltkqy3
x4A9mt0oqe9i/el+6zq8rRrpcEgzB9jb53EXbzz61gOKzsj3mvdNZ0FePrNU 2lmaGyC9fcqAmNtf2irO
2NX02OGT5l9evl1xOHR2UHEoFUg1TwlFQ+qjIF/Dl40eUHnHLKmEjjj1gVDQ ydl9zocOvfpkZqcr/ZMm
1dxQJi8T7oKimlnlavI6V5y6dXZa0kGUHzKbXD6alwbvG71aUNV9RSv2S/N8 kI886pM5HGdOWPNo8oYU
44/28Eifbh0+fOEpCIAACEQkQOPJyXe00g2tLn3CfdUz3RlDLots4a/jvaeN bT/5yfb/fbz9Fw95fzq8
7b9vqTrmklCe9aCDKSq5eoK33wRP34meS571XDDR8w9y1oOV0FbKSihZO1ia 57a/78mlQ84tv+fSivuu
4n2oHNG36r5Lqv5zQfU9/6i98698fc3Vv6i8/Ke7L/jv+WceI/XkygOSgjJt 7bUuUp6VOes1VdLEgJCw
UsZUyp6O6LxgbN1HH+TM/3TrjHfXXH3Za38588mT/zjqf8+Z3KPvsmPurT32 kcBRDwePHNlFccTITgrX
sO60kJRgCyns5+ukLAul3Gh5TbaHffmg2RN47oPsHgPyuOPS1C5an7W/QzLL qzNpfdY+aQ3921ogfaFe
XphXTsWmb+1ukTXHg6Np9gbX5Pp+cs704/qsYq+qu8ErqWkJUhqVCsvlu6C6 2xtYnVQhlZcXUCwreqL5
VH5Wkalk7ZM++T3uiu0Rq9Xf34RgV9MjRPRPmn95w37FXzI6O6jYNf7uzgGq TwlFQ+pN5Gv4stED+un6
AM0+JHuL5qyQ7934ef7SWum6oEOfVhj6ayp0zqsP7v3fHJJaxkHeGc0Lis5h 6b7CB8/2cEzUV5y6ddZJ
ulrlldjh8uEHgl9H/NJm+0UnxnNTy9mgoXn4wo08mkOBJmd+WmoezXDjj+Jw yIdHkXEDZUwTcA31I0Ag
yQjQeHLiLa1nj2g7/7G2S5/UdtYzxrX/cWz7755s/5/H23/2YPtx97YdfVPV kf9eI5li6KIQqURuLMpK
bu9w3SKNuvsuPrHkurPptlakre510teFK4ddVjnsksr/9Km655/VQ3vV3H5G 7S1/pPXeZV/V9PtZxcXH
7T736Hl/OlLqCTkrBTnrP2ulX3AVmBtQ6rqGvvDeyJyVCetRD/gojnnQT256 zGNdFMeOChw7ukuKUd1r
aCVpK8URD3ZRMH9l+Ui2THHsnfWSkF29k5Z7DN73k57fSwXOX3zMva20hg/i tEYqNnAX35CWWVU9ri/g
KxWVS/XfVqVeybvB2qJ2eQ2a3eCVHHfxGtYxXsP4hcGZaxtZE2S0kmp0Bqi8 Yk81+yBvVLHMP/SUFnp+
L99xeVVG9zch2NX02NE8erhX88CF20HFoVTvu/qUUDSk3kTdlokDKp3DPelX 38qiOSvke0fn2HF9t7BD
Lz+9FQTelG6iJ32VTX56yDujvqCoh3QOU4S7ZHSuOPWl1N3J0NHkF7W60fhf Podd4Iq+sd4eHGG6h6DD
D5/OyKO5L5qcOWHNo3noAj98/NEZHnWGC7wUJQHKpyBAIMkI0GD+q5taT7tH +lHWfz3W1me0u89ozwVj
3P96wn3ek+5eT3nOesp72pPeU57wnjTK+4uH2/97hPfooW1H3lB5RJ/QfQNC F0W0lZD43i59Rl104a9o
ekDJjT3LbvtX+Z19yu/qU37nBRV3/qvizvMq7+hVddtZ1TefVnPjKTQxgJKs 1Zf/d3mfo/P+fuTc04+Q
etK/tTvVSs7ac3MkZ/11hpSPDTmrPMkqCesjnRrCyrR1tGSxkrOOCnZHSF5Z iI8v/B1UfJM4lyxplPJh
by9po3YXhe6OL32dq+f3ce6Gtc3ZH7u1+yuvzZIDakkl+vvIjhF9Y4wshzzV KiBxPvRxAGWOTJw5mOsk
tgIBEACBcARoEPvZoIbf3nbgz/c2/W1E098faO79YHPPB1t6PtRy9iMtZzza ctqjrac80nrSQ23Hj2yj
WQHHDm098tYm14BS1/nLaVtWbZSV8GRt/nk/23vZb4v6/3nf9X/bP/jvxTf3 Lh7cs/imniU3nV06+Izy
G04rH3RKRf+TKvodX3HZT8svOrb4n0dm/c018w+ubmdl2krOGnluwOHOyrSV TVRlSVYpKMPKk6wHnVVf
W7m/6i/wdw7B8vEvNvL7YHaRm3KrkkB4g1klnVKm5NI18e+JhS3aH7uFO6uo ypIDakklES8NmuUsTVY5
f7GFo3acXe3+6aHLJ3Q/WunyKZYuH3ka2MJdM1RVnDkY6hsKgwAIgEBEAhWN gT/fuf/4a/f/ZvD+U28t
Pe32ktPvKP7j7SV/uLP01DtLT76z9Dd3VZxwZ8Xxd1T+7LaK44ZU/teNlUcM LHX1zTll4DLurFFWIiVr
h/orGgI7rvpz+j+PT7/oNxmXn5px5WkZV56eccUfM6/8Q9YVp2b3PTm3729y Lz0h7+Ljc/v8LO9fx+X+
47+yzjli/RmuWReeIjnrdW3dqVbmrBHudSVzVrrPCE+1shkCx4zsUJqrbGKA Zp41ImhFAaOfqhutP/ry
9Bm39Kn0wVkN8g9qo688UTXYH3vsyFhyQC2pRH8f2aQaPlnFKiBxPvRxAGWO TJw5mOsktgIBEAABTQL3
fe7O3NP855s2/PTfS35x+apf9l35q77Lf3n58uP7/nj8Fat+3nf1T/uu/Unf dT0u30Bfujrq32uP+PcG
1wWrTxm4PCO/gbZldUZTyfBP3cxZh3/sbszLXHz5n78786ezz/nFrJ6//L7X r74/55ezex3/Q6/j5/T8
+fxzfrrg7J8s+muP+WccM//PRy360xFz/uiafeEptbsyhr9Ld8sy7Kz0HazQ fNbQ7wLQI/1MgBRSwrWt
21xJXkP+yoLNdlUEQ8BytAgQAIEoCSTZ7CvsDgiAAAiAgFUEjh7uI2tkHxmJ /6OcKG1F27JumK/k49aj
7/ZKNx+4vePoO73DP5Ru9WroX0W9n4T16GtbDpvPKpZnDTkr/W7sjWWuIZWh 6P5BLPpW1lHDmrtD8lce
0o0CFEH7z77XGfEeDSgAAiAgQABfdgYBELCEAN6VQAAEoiZAdwkIfemK7hUg 3d6VbnR1s8c1hH6B3Cst
DG6TMqbskS3wuK7J1f8A/fpA96s0e5VNYFWE8NyA4tDtropdfdJdl2UccXnm kX2lcF2dz+KIAYUsXIOK
JbUdVNodN5QcWmYr6VUECIAACIAACNiHwBV0D3IECIBAdATIEq8p076ULit0 XRwK+l1VFhft6X7K1lOw
NfR4foEU/8yXHuknW2mBHslCDTvrZRmSs4a0lZsr81dFsAJS8PKyDQ+9yoth AQRAwCABuhgRIAAC0RPo
fp9ib1IIEAABswSivxjD1sB+uzXyfQNOyji2954TRjb2GFxUX5OPAAEQAAEQ AAEQAAEQAIG4EXD1a3Zd
sMd16veu4yfrzIt1ueCsMHUQAAEQAAEQAAEQAIEEEYCzImcMAiAAAiAAAiAA AiBgdwJwVrsfobil3NEQ
CIAACIAACIAACNiWQGyd1eVyxWjPY1dzjDocrtqk2ZE4c0NzmgRwOsX0xEgg 3gQ2HVOkqBwEQAAExAlY
46w0nsr/UfNshI1mnFXXKd8ref1GW+E1i2OyyjjDgYq+J2o44nUqjp1VO6uu R7Ah8Z7rlGRt8QLiJ0ks
Skbsp6K3pgmId15xwhi9KAQbEiwmP0xGeyLOKtz5ID5YGd0dkb4p6gzXRCya FukeyoAACICAfQhY5qya
uxTNOKu/rTkdMWEw+ofK6A6qyxutQeTUMVqnIEyj1Wo6q+WHQMewBfdLBKnl pzerMHqkio6ZqzB2oIz2
J3Y9UdA215DR3RE5teCsIpRQBgRAAASkYdyS+waEUzG+3kTuRPPtgdcjT41E U7miQm4SbH24p/z9z2jT
Os6qqEr+VN4Z1rRm90zTDveuqdMldTdELidNUVAzVB8Uo5zlB0hhh+qdUmi0 GqPOmaBznhgFIu9GxCMu
NzD1qaLYPGJP1MdFfn2FO+U0rw5FYaMHLtwZoj5GRmuO6Kx8l02ckPIzxOhf I+JXn5yteiSJeJRRAARA
AAScTsAyZ1V4hvw9T/N9KCI4TXHR1AsTw7f6PUZtOer3Hvm7mtF3JsUbvKID 4aRBoSaa77s620aErLkX
ap4Kg1FUK85f/0xQtxJujch+qa1Ls9sRdU3BXE4s3O6IA9HUQcVJLu92xDPQ 9LWmKYXhLgHNi0XzJDGE
IpxW6p/hhppQj0viV6LIXmsOLPqnq3ygY8s6l7m54ytyvaAMCIAACNifgGXO qiMEikFZEEo4c1JLg6E3
LcXbsObboWKlvP/h3laj3Ck1IvWbn9xXePmIFivSMQVAedPhGpLLljh/BUl+ LCLujuaGEVVA0y/VVSks
IZw0qHdZ/zwRIR/OR+VAIrarrkTtmhFZqVtUWKzmhaNz3hrtg+bJoK5E5+iI AJdvLnjcNYcIBRydaiP2
SvPqCwcWzhqRJwqAAAgkMYE4OasJgolyVvl7p8IIw72Diu9duJ3S2VmFvIpj Md2rcFoQ7v3SkLMqeiUu
BOK7E86uFEczHFjx3bdWINTtmjA2c10SOal0qIaTZs3LJ6I9619lqeOsmleK ueNr9NpBeRAAARCwJ4F4
O2ss/Ea8TkV2JJzEyN81RaRK/NCKOKtm+od3VaQ/RoFovhGKNKTWC0EjUR8I QzsoAlzRf33XEdlZkTJG
gahtT6QVHXEx5zSWOKumc8f5VDRxYihORdP8zZFXa73+n0ymWxEhgzIgAAIg YHMC8XBWNi6zf+I4+Cby
DeUr5cO9ocrlndF8i1LUpui8Yi/MNc234rWFa0VegCuRgommi4vTVlCV16bu lbrDhhpSnwDq1nXWGDp/
FDuioBfu7V9nB8N1TPO4iHRVk7yCufzyYX3TPAPVL0VzXHSaUHi5Tm/lWERo hBM4fQLiu6n+i0Lz8g93
NSkuOvUood5QZK/VqHUu83CXqkhDKAMCIAACTidgjbM6nQL6b08CRnUkRnth k27EaO/MVQsm5rhFuRWw
RwkQm4MACDiagDXOKv/rX5F+ME0nFnUqEhh2eAOwCpdpzookljptFk3NJra1 6rir6zF6uBOOQn26xuhs
McrcKEnx0yD6o6bTlmblCT/KhnY5duTFjxFKggAIgECiCFjjrInqPdoFARAA ARAAARAAARBIBQJwVunn
iBAgAAIgAAIgAAIgAAJ2JgBnhbCCAAiAAAiAAAiAAAjYnQCc1e5HyM5/8aBv IAACIAACIAACIBAfAmac
NYh/IAACIAACIAACIAACIBBHAmacNT42jVZAAARAAARAAARAAARAgBGAs2Ju AAiAAAiAAAiAAAiAgN0J
GHDW43rvOWFkY4/BRfB9EAABEAABEAABEEgggeYDpXH8UBpNJZjAoTxrn0LX 76a6jp+s0yGX66QMOGsC
L040DQIgAAIgAAIgIFdVWgaQlCIg5VnhrCl1yLGzIAACIAACIOBEAkxYoapO PHaW9BnOavfZG5YcZlQC
AiAAAiAAAs4lwNOrEFbnHsToew5nhbOCAAiAAAiAgB6BrVtWODeiF4XE1pAo W92emzdl7uqxU+Yi1ATe
nL583c6s+J8YcFaM1CAAAiAAAiAQwVndbbUJDxPfgiHVjr9YWNhioiYDkJB9 t2Lbvso6E8xTYZOaxhbi
E39thbNipAYBEAABEAABZzir19vW3FzX2FhVX19RV1dGUVtbWl29n6Kqah+L ysqi8vKC1tZGkidHO2ui
hJWcm/KIpGWpYJ+m95H4ECUL/z4RqQrOaseR2tPRsWNX+ua071ZuXTR5deEn W8rW72vs8AdEjijKpAKB
RW/30Y9UgBDTfVy/bh2L+LTCm9NciGkfULkIATI/lmQVKRyLMqx16etHzXWk rW53MylpS0sDRXNzfSjq
mppqKQ4cqAkZbTmZq6OdNYHCSkeQPg03LXOpsyFRisXZrlOnNc6al7F54bxZ B+qqouz9io9Oj7IGtrn+
G4Di1YgtqmuLuIlmAUFKtc2NW9a81bljZGHud8uyd32dXvnmuuKxC7Knrl5b 5/YZbVqwUV6t3ITmv/lv
itmTL6b49tVLWIh0wGijRTunD5i+feB3WwdNT7t+xtZB36fvy5op0pCJMuJ9 W5K9bPQPD17+9lUD3rhj
4JRbn5v7xtrc9SZaFN9EvG8ef1An6CDGotFwdTZ9e8Hbjwxc8PY9y6cM379q okjT4nvKarPkDBFvlC75
jg76y5HCG1Ntpcr9fv/K1RtY0LL6X0w7IHKwUqpMuJPEPs5KPkrCSqGwVVJV FlSgoaHS6c4aN2ENZx1w
VhHztspZXaF/bKiRL6sHH2ucdeG8b954ZSztYTSjG506XYEDlmhr6C1H+re7 oCCg9Y/WswIi7wfsfYX/
27JhubkEjAilurLtK5Z/sHvTKxm5Syi3urWslWJ2dh1pK6Vd563+gd5FDUEW aVReIemOzpn6+YuXi7Ru
qNFrZ2y76rv0LSveCwa7sms3L9ia9n769mtfnDFhyvcibRktI9g3MtSrP73t xZ1nz9k3asqahz5c8dxj
3913/ZQ7f9j+g9EWxcsL9u2iUdOXZpf/b687wmnrvLcusrxRHWGtmXuzr2kh xca1G0hbRZoW3FNWlVVn
iHijcXbWKV9+y4IGmf3FpfKgNSJjlAhzRT3mBjFFQ6teOIFCpHWryljSbZ3O hDtJ7OOsNCWAZVh5YpWl
V0OeWiGLcpok4NA8azyFNZx16Dur5sdcIpKXZGWsclaFqupoqzXOWlVVJR0J XwRnvfyJmVc8Oavf07Ov
GDPjhmcXPvjh2knf71ydU02x+J0/LH73D3T20CNFlAMcjWteb7u3vX312rWd Wv9oPSsg8n5AZTo7fTz2
7c3NztjMzNVQP0Uoka2umD/+043ZS/Mb8uu8lFjd39SxpvAATQ/Yt/uL+iWX krla3iiv0NPROevbJ7Zs
n0VzEl4/OCeh3Rfgl5mgs4rsKWv0mu/S5m/flrltRmPdjlArgZc2bSmo33rD zvRLX5332KeLDe2sSGGR
vm0v3DTgo5teXvTwivzvOrqaPs8d+tyiIe8uf+qlRQ+TttKrIg2ZKCPSN1at 2x90+4L0+M63W179Yh3F
hPeWP/bK/JHPzqKVlBcXb128UXWdlGFlwnrVQ1911sz07v+Csq0iTYs3auEZ It6oNIB4WlnMmf5J7D6v
p5p9Pr9+GB1n1PxZ/6d89jUXvtCYJjT66RzNH58/gUZsehQ54laVsaTnOp0J d5LAWa06giL1WOusZ970
xplD3jnjlvfPuP2TM+6cesXQN8d9vH5JZr2+dUR0Vrl97lpwP1nsvDcvSjIl jbg7FjqroLZa46wiZyGV
GbGw5KHFpY8vL3tiadmrG6q+yWxYvreluKljzmunBNoyA+6soDsz0JYVaMug NYJ1ahajcc3t9lBIbtou
uSkLT8hTmcuyAiLvB6GkSydFe3sHhbQQeiqyrdG9eG/Jj1OWTZ+3admKgrr8 mnpy1qUr10zZ+uHkZe9+
Pn/wx19c9sL7dxutU7A8/Z3O5iSQHK/MzgzNSShjcxJqWzukP0l8vg+fv0Kw NpFii7enXfH1FkqvNmyZ
8ezEYbU1GbUbp1NDC+u335iRfvX0/X+ctHTZgrdFqrK2zNDpj97x+ZBR391J kwFCf4t5SFuHfdPvkWlD
H/zmrlHzhD7+trZL8tp4nrXVF2z1B6VHvuAPtvmC01+7NHat85rlwtoRElZ3 7js0ScDCphN1htCl3dZ6
gMUP330cu8/r+d/Dc2d8yv4qZklW+UL04wwT1uWr1tNjZUUx074onXVlSFgp aMHCIx6xKks6H7EVdQH7
OCt940oxgZXlWUMZ1nJ5ODHPGovbWv3lkY3PrW54ed2BtzY3fby9dUauZ2tt MGQdGVK0hkJlHfrOOu/N
f/sCXa7BH/n80uOeVeNyF9xPzvrNK5dF9LxkKmChswpOD7DGWQUnih3Ks46e ccPzCx/4YN3z3+9cm1uz
Kb/22+d/TRGs/uq753/93XO/NjGmyDehca21zd3a2kZu2tLm5kEr2TKtp1cp RN4PqAzJ7rb0zE1b0let
3bRk+eo585fSGpFt5b2KSIlmst44NeOembvpe1eU6azZOaF4/5JVWdvPe+ac 0589+cTHTzrh/tP7PHeD
ITgRG2W18TkJeblz1hQ1HZqTsLZo/bZv5q2a3dza5vF4BZ1VsNGB36Xl1JKz Bmuq0xfNuve7tDe3bZ7c
Upd19fTZg3/IvPXtzCGPzp3y/iOG9jdiYZG+9X2j/63v3njjW9cuzVzKxpeu YPucwice/OaWB6c9RKnW
iK2YKyDSN1Zzc2ew2SeFlGf9fB3F+HeXj3p5HuVZaeXXr1wm3gHxRuV1cmGl JGtnzSwS1rbcd+sW3EHr
RZoWbNTaM0SwUeo/XdoNdRUsZk2bwvOgTCjpqdFrX4cJVRUS1nZ6ZH8bKyL6 tuTOuj1tTXu7m83WXTBn
qjqFLHL4lj/7P12dlQFfJT3SsjpEKhEpo+4e9ZkJd5TOHa51+89nDTlrHZsY sHXreoWw0hq6kwCZKz06
11mt/dWAUJ717TNvef/M2z6W51mZdfirvtG0DoWzvvbR83LXnPn6xe6OgLsz wB7bOgOkrbsWjJj1+sUK
JWUqxv5ZaKuatZlrK5qOWeWsgsJKl601zio4UWz1J9fktgYVUejuOuALNPt8 Xzx9QnD/s/RYueZRzQFF
fjz4dF3NkjTSNbe0NjW3kJs2NjWzONDcwh9pPb1KofN+wIfLjMzMNrdHHbSe lxEZfyNSeua78Vd/vuPG
r7PHLNpLKc9cmoNQUEbLv39iwapdleSsR9z9/105+cPKH5dvf/aZ7198zZJG WSV8TsKy/Dqak1Dr8Utz
Eoqa+JyEjeumNjc3vzPxSgsbvW761ty6LdurJG09kDbvpW2PzNz26IO3/ofH kMsHPD3msXAtip8P8hoi
HgUq3OuZq85/8qJznzj/h20/8FGGpgRc/coFN71772UfDY4IIXZ9o6Z5nvVA Z1AZvuABX/DzF/tG7CEv
IAJEXtsPb95FMeuNu2a8cjsXVveud8SFlWoTbFTzDPE07flk1ujBD1556/u7 bhk9X+cMUUAQaZRd0TO/
+ai2upgFLbOQTxDSGTdIGuQR8UBQVe1eN3kkBWkr+zCHT2ml5ejbYjtFSVYS Vnpk3+A5LNoOPY2oyEvH
/yrgLQh49tBjFy1Ij3sCHmkNPe3ySLF0wq+iHMPZXw5cT8MtRA9H8CSxT56V 7mlFnkrOyk8zmslKQZLK
17B7YDnOWa2dEsCP7BfP/ZNbx6ypY+QGQr7hK5pEj+rTVeGsr055Tq6t7z97 ZaPbRxlWCvnCe8/2Uzsr
XxONHepUq1m/hW3pqLZVzhpxnOQFrHFWwYliK6YMoNOlpuOwqO/savH52vzt 7Z01weLn/Z17K9aOiqgp
+ntIA1njgSYKclOafqoOyWVDBfSdlX1Pa8fOjJZWtyLPSmtovfgXuajDESld 8txVTy2cc93UNQ/OXj1n
1fNZuTtnrc0hi3XdOY0WWJ51zA/bDzzz/Opf/+XNW+8QOcwRG2WV0JyE9+Z9 T3MSJGetqW/0+tmchNfX
vMnmJDz/3lCaPDB53NUWNnrjjK3vbduaU7s1q3bHnO8emLfz8XkZT5Kwsivk vVffoWXSVp0WuRqK9IqV
EQHy12cu/9vEf5wxvhd944p1ZlnO8n+80Odv4/5JSVYRZ6WGYtQ3thcNnUEW LM/60qdreZ61oSP4kZEp
HCJAOF6y1W1p27Zu3rpx3abVy1d9Pv4moxlW8aNAJTXPkDd/uH7Zgsefeu/h Wz7MveWJBTffGHa4UJwV
IntKA0J5yW51fP/1h5T+ZCoZcV4QV4eIpyU1xychsAWaPutt75CHvkQaaqu+ rryhvoIFLbOnbIGHfnOL
x/0q0LItFFtDwRakNX7Z8uJntJ3V0HVBPXGTTEcKEW2NeCB4AfvPZ+XOqtBW hbDCWRXOysSDnFVhIB+P
Pn7r7BERnfW1KS9kl2W9NmUSe0eYPO6qyubOw6Kls6rZR2+Rgs6qSL5qpkjV ZahyJqOauVuFp/Kn6sLy
NepiiiZ09Nepzio4Iiz64Fpy1tqOYG1nsK4jWBd6rO+kOXkdXim/fiBYPKmr c9/2mXfpa0rE5mgUq6tv
pNhTuJ/0VB20nhXQd1a3R5rzuj09o7mlramljR5ZNDW30iOtF58UG7HPVIAm rV70xgXjltz9RfroxXte
Imeds35X77e3XTJ+btrECT8Mvq7XU/fR97G8z78p7qwi7da11N/4VRbNSaDv XfE5CTSlleYknDnpt+TK
vxpx8oXPXV9eUS7orCKNUpkbZmy77rutH2zb9n76joGz578/+bolC24mT+08 OENIUFsFmxMvRjNWL3yj
H93lat7O+TQ60E2vaLbARW9dfu0XN13y7vV0SwHBqvQ/DRCsRF2M51mli+hg 0GXFl9+Z2M905TobMmGl
2Lx+89qVa5YvWLbw+3nvjRpkKMNqqGOaZ8j779405rHrbn58yS1jFtz8xKKn xog6q2DTNCaU7tsljxlf
fcDSnzwiJiNJICI2R5U0NdawONBQTcGWSVvdHi/zY1qwpC3qTDgdVwi6fnNz R/8y0LDcHwq2wJ+yZRZz
xvwyyjGcdZjP0NBZiOj0EQ+ESAH75Fkpe8rmA7B7BSjy+izDyn5owFn3Z41R kpUO7pQJ55N4MOWY/vnT
3D34gEkFIjor5VnJWSVt/eg5elN48an++xra9zV07KvvcL2aEVqW4sWn+4s4 q9wCuSAq0qWaZeR+qU5/
ajqrfltyCY7YAXWLTnVWwYliP7x7HZ06jaH8ED2yoOU2f2dHoMXfVRcsftnn r1z15e0ig4hOGRrFqmvq
auj2z7X1tMCCPZUHrdR3VjZ/YPuOzG3pGdvTM2mBHmmZR8QJBvJORqREvxpA X8C6+5sHXlr1+PSdL9LP
CpCz9vwoZ+ykb/3X3fbhn//85vztt87bk/fopLTf/00wzxqxUeohzUno/+l2 0tYxC6U5Ce7dE3bmf/j6
itHXfdabOSvNSbjmtY+Liopeerq/yKERaZTqWbpj+/Uztg/eue2mzPSb3sh5 8pGBYx4fTM7a7PU3ewP0
uHLpj0xbRRoVLCPSN5oGQMnUflP6L8teShnW81/pc97kCwZ9Meiaz25sevbZ /BFDWdCyYKOCxUT6xqrS
yLO+t3zUK/Ok9R3ByeOF0uGsKsFG2ZQAii0bt6xbvW7l4uWLZi344ZtZ7zwy UHAOq6FrgRXWPEOeGHPj
02NGDXli8ZAnFj05+pEP3gs7e0SBXXBPmS0VF2ax+O7L91nWk39eT8sRPVLk iLOP7Gm+bGXZHhazpn1E
TylIVXlY0hbrj6Tj+3P1I2JzP4z6pb/6e3/1DH/NjO4FWu4OWi8FlREhoF+G elJRWqAfEXtrtBv2n89K
JspvxcoWDuXaQ/e6kjlrIUmGI34HK3bCSifA20/3kcTDJ/nGpNfe/+qT8Yqg AiLOuqs8Z1f5rl1lOZRt
nfjEwLxqb8Ovr6BHcta8Gu8/Ph1Cj7Re7aw6aU72EhdHtq34Gh0/Vmdk5W2Z k+bkcVaRiWJ0Tkx/80Y6
deg7Ik2hr4+wRwq3v9PX1dTlLw6WvNbhq5/5zk1GBxpFeRrIKqtrK6tq2eOC xSvkQSsrqmqkl6pr9Z2V
5WIjhuC4KUiJ7hVAc1gpvZq+o9tZR0/8uu2Sa8lZ//Pphr98kJ0+coK4s4o0 qpiT8P2mCW+vfWDcimu5
s554/9kPfLNud16eoLOKNEqHLDf9+2tn7LhpVvotc9JvXZB53TsLvvzpsWSo VS2dNEmoqkWaLUSP1jqr
YN9oVgBp6x3TRtw27d4bp94+eNptV3x8A7nsKyeeGKivZ0HLUZ6ois0F+xYx z/ryWKE/LVjrgo2Wf/2v
rrY36B1w+iu3r1ry45IfFs37dvbMz6e/9bDe5I1wfAQb1TxDbn5q2ZAnlwx5 cvFTYx4Z2P/R3FzRG6IJ
NsrcjlSVCatcH2PtkTRrls+bZ4pMTwWHF8FTUZ5FnvWdxm28ROqZ9dgv/GUf +8o/9pd/POvRX9DT7kda
CIVIJSJlmNbLg/rM/5ywloz+5WCfPGtlZSH9aoBcW+mplNevL6fcKo+ammIq 6QhnjcW9AuRn10ujL/34
w0kff/gCBTkrsw4WLX7p8eXRGjdaUX4Ha8qkvIrdr30yaXf57rzy3TS3dUX2 CnLWjAoPOWtmhYeclR41
nVVuourlcK+KaKWgs6pdk88uiEaRaVun5llFJorROfTlazeTs7bR7XgOj84u b6CrPlj2dlegzBMIUDGR
4UynjPQpWGV1WUUVPZKtym9VQ3NbaQ2tZ6HvrLyY/oLg0ClIifaLEq50r6v0 rF0sz0rO6rnienLWBz9f
b9RZRRqdPO8D+ZyEJcUvfJ3z4AvLr39u2oDH3nyg59jbKL5ek5WZkfnsE0KC ItIoO3yLZr163Q8ZN7+5
45b3Mm79aNctTy0kQy1qaC8KfeBCjxTWOqt438hQaZIATQagHxegPKs8w8pT rdZmW8X7xqdk0XzW8aEM
a2V78PbZ/7l+6l2XvX3zuc9dK34FiTTKhVW6g0Iw+MX4m+ZPnzvryxnTP5lm zllFGg13htzy1KKQsD46
aOCjCxe8a+2e8nwk6SkXVv4xvfjn9eK9kud0adasdMOTw0NweDHUYklRTnFR djQ1f//wL3zFk/3Fk2lB
vOnoS3Jc0XRepxv2n89aUbGXpgSQp8qD/fAVz7CSsNK0Vyppf2eNaYaVHehn HrmCxEO6pzXd0PrdV0k/
aIFJCFv5zMMaX1pV3TfguT2Ve1//8PnX3p9QULmXgmnr1hL31pK2raVuim0l bh1nlSdTRXxUpIy5eQia
cwBMNOdgZxUciaa8fCudOt5A0OuXoj0gRUeXPxBsDFZM6QpWdnZ10BoqJlhh uGI0nJWUVVKUlleSoWbm
5LNYtWYNBa2h9ayAvrPuKy5Tx/6ScsXKGI2ee/bsi95ZRUj6A/7P1kyjOQk0 H4DmJFCede6Ce9fPvHnO
tBH/emdz78kr7/ti8bbt6RSCzirSKC+zeO7rgx7MHvzonCFj5t/ypOSsOZXS Zy7krPSXa06lx1pnNdQ3
eeG1/f7Z9PYrlFulRxZsmdabrtPchjzPWt0erJKFCWEV6cDhwkrOSrH1vVHX Tf/0W3PCKtKovIziDLn5
ycU0JeDaAY8uWvSe0apEytPlrHmfEPlKCy95hbOqM4sWtsV3nzUaZc3TH/w5 feeaHkWoWlXGkp6b6Ix9
8qxwVqOH77H7ryLxYL7x6htvSwv+YAfTj5CHUAF1ner7BhRVF7/6/rP+Lv+L b42l5aLq/aStz4y+lgcJ
q76zKrSVf1jPs57yNfKVmtlZReFwlWjWo2ia16/53SzF1AW5KDs1zyo4Ueyd 52/Paw12BkLRFfR1dQX8
B4I1XwVrvuwK1vq7OukXl2g9FTN6UirKS+NaaQULMtSS8moW6Tt3UNAa/qq+ sy5cumrBkh/pURGKlYJD
vyAlvi+FhcXRO6t4o/TDATSflST1tQ8eK/nst2PefoGWKWgm6/inbiBbZSFy aMQbZbXl5y748L2HKHNG
3wEnQ91W6ubOSsvWOqvRvvH9JTclSWWPLPgaESYiZcT7RllVdRjNsLIuRWy0 Ju9xktSQqnYLK00SoN8O
iEZYIzaqwCU/Q556YtQH7z+2e/cSEaTyMoKN0uVMdwXhv6dKy4rfU6U1gpe8 SA/lzmphtRGbZnIcsZh+
ge8e+DlFlJUY2tySbuu0aP/5rOSslFJl97fiwaexsm9fUZ6VvqpVXl5g8zxr HJKsdKzvHybdsMgnKYc0
n5UtdEdAWhgxTON9TeGskz+aVFJT/syE+8ZPuG/s+OHFNeX0lEJx31bNT+FF Vup8N19kc2vLiHfG1s7a
o2fBCSMbewwuUl/wghPFPnx1GMWn747csmlmW/G7wZrPgnXf11RsXzfzMVr/ 8oShPAyNYurCNK7xVCgZ
Kr/X1YxZc9ncAP6qvrPOW7Ri45YdG9NCwRbo8fAFKiM49AtS4ruTvSv/s0Xb zv44j76DRXMDPj33X/L5
rE/eJHRne0ON0s+0rtzT8Ma8RZRYpW9lPbOkcPXexg5/l9HDYahRReXy+7Py ZaMd0Clvum9kqGlD+rFH
FnyNVd0T79szj1/7zOOD6O/7sbTQ/Yf+IENTAnifIzZaWzyNTQlgGVYS1s49 46MRVmo6YqNWIZXXI9go
Xc50V5CVqzew4HcLkS8IXvIie5EoZxXpWwqWCXeS2CfPWlaWT1bKfjiAhXxK AJsVQMJKX9WiknZ21vgI
K53D99x9bcRQn+rqPGt5bU15nRQVtdXldSxqaKUl2iquidbqqbw29XfFIrbl VGcVn50Wn0FQ8/O1cCt1
uiRYj+BOGaX03ZzlL348d8jbi5956ctlI5/66KX3Rn26nJ5+88wbU+95fP5y oRyJ0UYF90W/WEIaFey5
6b7RfFaSVHVYePcA030T3HfNYmhUgcXaq17k0PAWRQqjTEwJRJzP6m6rTWCQ Q7S0NFCqlb5fJYsi+VN6
lYKElW7galtnjZuwmj5bVN/Beu6ZCcPGTrjvmfH3jRt33zjpcdi4CSMmjB8x bvyw8ePui6h3SVnAqc5q
+rTAhiAAAiAAAiBgcwI8z5pAYaWmTXiPDe91ZX9hpbPxla8XN7V5TABPnU2I D1GK85Vr4HewdOYGxLnT
aA4EQAAEQAAE4kaAzM+5ETdKERuK9W2tInZAvMCKrTu/W7FtX6WUq8Y/NYGa xhbiQ5TEkVpSEs4qfQ0F
AQIgAAIgAAIgECMCDrJVTmB7bt6Uuavp42+EmsCb05ev25kVo7NFp1o4K4QV BEAABEAABEAgVgQcMRkg
/vqFFk0QgLPG6io1cTCwCQiAAAiAAAgkAQGeWGUfK9PTJNgp7ELCCcBZ4awg AAIgkGoECuprChpqeexp
qJXH3oY6KRq7o7CxThb1hY31RRQHDsW+A/WhaGCxn0VTdxQ3NRQ3NfIoaWqU ork7SslmZFHWfKA7Wg6U
tTRRlB8eFS1NUrQ2s6g8PKpam6taW6Rok6L68Khpa+0Od2uNu7VWGW117oPh aavztNUfCne9x90gD6+7
sTs8jV4pDsij3dMkhZdHc7tXHi0d7Ypo7Wg/GB2tnR1th4e7syMUnSw8vsPC 6+v0+nw82v0+eXT4/Yro
DPhlEfAFDgs/3Ti9O7r8dBf1w6OL/gUpuu/WrDfVE56acMNLvg7AWVPtvQr7 CwIgAAIgAAIgAALOIwBn
dd4xS76/nLBHIAACIAACIAACIKBPwGJnzcvZMHvGxwgQSEECdPILDje4TFLw 9MAugwAIgAAIRCSg/05q
mbPyt2HBt237FOM9T6Z7sPHTQlyk7HNEzPWE7bK5bS3ZinVAH7hzLxNLECVT JQk/35IJZoz2hV9uZaVF
yTS8O2hfiHwKvhnF6HxOkWr130mtcVY2NDgRKOu5apq5Yta5g5+m2niR8PNQ R1ude5k48dKOaZ8TfprF
dO+So3J2ucFWbSK4kNfkuKzithfh3kktcFbnvhOzngcC/lQIkSxg3E7HmDaU cJ/QvNice5nE9GA5sfKE
n2BOhBbnPkNYbaKq6m5weU2dzwDjfPInTXOa76TROmu4d+L0RZdvnHYhix9/ vN2GELuFVX7LjxRYjvjh
tQ2PlIkuJdwqFJzVl8mit/uECxP7i03iRkBxauE4xo28eENqYdU5TLZ1u+Tu GDPXKLXVFfrHTgz5svip
gpI2J6A+SWLirJ99Jqmq3z+ZBS3TGruhYePa4fexa3/kiRfka/5915csFMUc /TQWCdcvF6631fHVd9bH
HvmPToTbEUNbiTir5nvSrgX30/urrWCiM3ICamfFcbTbGaLprDqHKbnt0LZ7 Z0nCFdqawKvP0Hsi76eh
rax3VrUcsAyrpKr/2cjC7x9Ha2h9AuEqmmaDmnQf5sODnJWvIVW9/f30j34s /mBhgcv1rLqwo9dE/zeu
z+f3tHeQrVL8pvf1bME+h1hHW+maCTeO00s6zmpoK3kH1J2Z99ZF3XfrDhy8 bXegKxDo2rNqXC60NZQ4
sWHgONrwoGiO7YpprBEvN9uKXdJ3LPqEK7Q1UVdl/N9JpYR6v2ZXn0LX76a6 jp+sc3W4XCdl9OhZcMLI
xh6Di3SyDvQSpVS706sHnTWkrZN/fL9/osiq22XO2v3LIuz3RUJBzsqXyVnH LyrNbApuKW0nZ1UXts8a
/oeLvEuaK+UFotRWpqoU/LxhT7m50s+lJPCIx8JZDWVn9Z119uSLO/2BS8/8 hzw6/IHitLdIW3ctGEEF
EkgPTWsSUJ9UOI52O1U0Z7KKHKakt8P47CAfJOXNaa7kBaLRVghrAi9A085q +p3UemflSVaFtjJnjTLV
ymeuRH+Q2Lh26LfyDv5oHjkrD3LWiUvKcj3B9JpOclZ1Yfus4acOLbBeqddo 9tactipUVT0UsgIih8nC
Y6poTt9ZDV0zrGaj16e+s05/7VJPp5+F++ACX6Y10165VASg6TKxIy/YpWg6 ILKtSBnBrvJi6pMqFsdR
3XNr98Xa2hQMY1q5yPHSdFaRwxSl0tGOK2pQr5EX0H/VaGesrS2afsrfelg9 6jXhvphldHorhFXkiohd
GUOf8vNuRPNOar2zslkBFxZe2H92/8kb+/MprZKz/ni7TqqVnXz606jDjYby 9YIjJhvX2r0tiiBh5WvI
WUd9W7A4p2l+ei05q7owWyPvebgyrJjOq/wleW2Cm9C28pOAnUZ8UKBl/XaN aqs8sao/sCq0VXFo2FPB
42XiqrP8a1jRXGnqznz9ymUt7T7X4I94NHs75ctTX7rMxF6LbxI78rwP+k1E 0wH1yRNrz2M7ZdVxNEpG
nJVISaOXnk6d8cEuflZTSU1nFbnc1KOZQgTZ03B2qF5vrjzvhvy9QKddVj5c r8TdV3y/9OvUfzPS2Taa
bKvmGSJyLRg6tVDYEgLRvJNa76xsYgAJKwu1to4bp/1lLBHvtN5ZPU3th4fk rLI1pKosFMUOL+PiTyXL
VNXJ1ui8FK42nUbVL2meB5KwhumPfL0hbWU5VMGQn+Kahy92w4rNnfXzF/s2 uDvq3R30KIvOek/3009f
iO3879iRT4izqgfTWOyg+qQydxxj56wibypGyRgqb6iwSG+NltF0VpHDJOis 4awrnLOaKx99beK2qm+9
Jmw43JtRxC5ZqK3M+I2ePCgfBwL2clbKpJKz/pf/v0hYKdvKnZWSrO+/fyFF uGyrprPyPzQZR15GvZ6f
oDovyQ8GG9e8nkZFkLOqV+qvoRblBfhT3hP2qv5TXoOiNkOdUZwK9FR8c3Ft Zd+1ijj6qL+SpRhB2FOO
RX5w9Y81f1XznOFH2ebO+tHzV1S3euV5VvlTWv7ouSvCJQ/kw3HEa4FfO4JX k/ygqFErKlEUVm8r0lXN
61qxocKDFSeP5gkTi3cs9Ull7jjqD1PhLgpN2ppkIh4XkeFUcLzVOcEU3iA4 OEf5rqnprCKHSdBZaS+4
5PE9YplO+VOe+zRUntWgmTdVtCVPx8rLK/og3yl5zZq95a2H2x15AfFsq3x6 QMQ3Dku0lY8PUZ5L2DwW
BOLnrMf2zI/4HSz5La7kEwPIVtnJSolY0lZ1tlX+BqN+s5GfguqS4bbVqZON ax53vSLIWeVr+L2u1CX5
GmpF/qriKb3E1qjXs63Um/PRRKdRzZfUzmqoBnFtVXzvig9DivWK011xWNXD Cl+jPgHk8sRf1T9nbO6s
70zsV9bk0Yn3Jl6pHi80ycj/olPD0eEsFxfNvwS4+ij+aNQpLO9zuN7qd0mh UzqdFB8KrBp51SeVtccx
moMVbpBUAFQcOxGGOhdaxEMpeKpYdYCoHk1nFTlMms7KR2Oua7SgcEr9NUbL y2WUN6rZojw/Gq4VhbOy
YoL9V9evn5GVt6V+M4poq7xAlNqq+QZh4QmGqqIkYI2znixw3wARZyUfZdra duGFLJi5yp2VzW2ddvhH
n/KhQZ454OsV1qJer/m2Kq/2vGfOOXPSb098/KRfjTj5wueud12z44j+mRSu K3dLcXV+dwwqdt1Q4rq1
3HVnFXs84u5a1501rlurXLfXSAv0yGJIHQIEYkmg0TUEAQKxIXBLtQsBAjEi cNibI53Ah79XXlfnkqJC
erymKrRQEVqgp6E115S5riiXghakpxR1ritqXf/O5trNzFvzD3tNnYjStLC5 VQTs5ay0V2xKK3dWpq0k
qbSeJVmZxU77z2/1UzLhEgDq0zRcGkBR8rrPejNnZap6zH1tx44KHD82+Ovn pfjDi8E/vRHsOTnY8/3g
+e9I0ecDKf79UdhgBRAgECMCOuceXgKBKAnE6KRFtSCg+dZJK9m7Kn9k77Pq kN6FDw96d6agN+tjHvRL
2tpzszxpFc6ldD6Vskq/UI8JAkbvNqD4dKv7/qxW5VmZs0qTVn+8nedZ+7+Q 3rt3ff8XpLu0stDMsyp2
XsRZw30ypZlzZc5KtnrkHTUkrEc+2Hzs6C66DLi2nvpqkILM9cy3DwUpLAv5 SiyDAAiAAAiAAAhoEqC3
URbsVbbM1JOlh9i7LQ9aKX/KEkk82Ns0xbGPBChcQ1pdF2SzuQQ6zgRnNSGU Ntwk5s7KtZUb6u2f/UjO
SkELmsKqnnHFpVNzDoD6byy2Rr6VogZ6+ty0Aa5LtrkGlbpu2HPEsDoK130N LMhfj3rYfdQjnWSxrscD
R40KUrBleuQr2QJbecxjXZSmZSURIAACIOAsAkc82IUAgRgRoGuBamZvpuxN k8URIzuPHNZx1Ii2o4Y1
HzHU7bqrxXVr6PG2FnravWZoo4vF7fXSI706uLZ7dgGtobixzHVZjvRjSLgz gC1/L9Ba8Y2Hs1KP6QYC
UhycCUC2euG4H6X06n9+q5jJau3u6dQ2Z9oIyVmv2eG6df+hoEmr99QwfyVz ZSH5a5iQXqXrjcewZrr2
ECAAAiAAAiAAAmEJ3Ft/FMXddfT9EPqok0L6isiQSikGV3QHySgL+koJBX23 ZFDxEQMKXVdT5B/65gkJ
63nbXSfO0s+zxk0t0FBMCcTJWdk+kLZKknowwt2cNaY7zCt39VonnfrkrDfs 6Q4mryFt5ebanXy9v8XF
42A6ll6S7Fb+VyD7sw8BAjEhIPvCH//mHxZAAARAwP4ESEkVEdLTo28qG/5e TUW9T/xOAqzk8FeLj754
h6tPuiSs9G5O8T9T4yMPaCWBBOLqrAncT3XT3Wf5JdukewUwbVU5K5szIJ82 wDxVWkPpWHYDAXbrAHY1
sj8TESAAAiAAAiAAAowAz5iyHCp7ShPzBhUPf6eqs6Sw7vXHa54ZWvXY4MqR AyqG9yu/+9Lyey8vv+si
irLbL6AovenvUtxwTvGAPxf2PSXzht4H8rOHv7xf+gIW2eoZS12nz4az2kqx YtSZFHbWP34nnetKZw3d
0yqUZz1yeLewHjJXln/tVtWq0N2vDobiQw3+6QYWQMAqAnzcxwIIWE6AffyK AIGYEuCf9YeElT7olz7Q
f+OJA9+83fTd+42fvFj3xpjalx+ufW5EzcThNePuqX76ruqn76wec0vVqJsq Hx5UMeKq8qH/Lh7cK/OK
Pyy55pyK2o5uZ/39che9of9sfIw8CdXah0AKO+uJsyRn7ZN+ZF95nvXgHViZ m4bmtkpxd233UyasPLEq
z61a/i6CCkEABEAgPgRiaiqoHASk2aj0jWealkq2Kgkrd9aaicOavv+oefYn jZ+/Wv/O2LrXR9W++FDN
cyOqJwwjba155u7qJ++oHn1L5SPXV4zsX37vZSW3nJd99Z9n/v1/pHuyUp71 rDTXQWeln5Cwj12hJ7Eg
AGdNl6Zyd08MKD9qaNW1E0sXfpu/Y1bmlukZHz636vlnVowdvfTOB1f/7e4d /9/Qku7JAJrzAaxKp6Ee
ENAkEB93QSupSQBSBQKxI9DtqcxWDzrrNcWua4rJO6tHDyFbPfDVGw0fTKx7 7bHaSSNrxv+n+qk7qx6/
peqRGysfuq5ixDUVI66WZgsM/XfZ7ecX39Q7u/8Zs889UXJWmsxKzvp/aSzP SkLDAvIaC1+0Q53WOys/
aWy+QF8zlP5EozsS0zcQ6W8+eqO6tWr8m4VFG/aXpZduXLz7k/e3Pjt25djR Sx5/eN7I+2bdPXRan1sW
Hn9LnnaeFZoFAiAAAiAAAiCgJkC/ayXX1gFlLoqDzlr1yPX17zxd/944ElZv +noy0apRt1Q9dEPFiAHl
/7mi/K5Lym47v+yWf9L61pU/lA7uuf+Gc3IGnvXD+b+TnPXc7G5npfmsPxvP vp7Ffu4VkawE5Ops/W8K
2EHMNfvg+vWP0p9oF5CzFtIHFkfcVPHvR4pyF+VVZ5eX7Klf82PR11/ufDok rA/cN/OeodOG3Pz5tQM/
OKf/9z2G7Ou+MYfse1eK7zweulvHwau3pM7f3tnF1tc0BSjUZeRrun/KWXbx y9dErEHenLxaQ90IV4l+
z/EqCICA8wiwH8xEgEBMCTBbPdxZ6XtXdS8/XPfao5Rh5e+kIWG9svyui0lY S2/qzdeXXv/X/defnTNA
5ayhPKvRmw+gvOMIWJ9nta2kKjomOSv9iXZx6GZvN5YdeVPF9Pez9s7NzFlb uGVjydJF+R9/sGUUE9a7
pt1y82ckrH2vePPCPi+dcPWK7vvJ8Z9mHlLJDvxPTpzEQ/Gm1V3gzK+Ys9Y2 dhx37kJa3rKno9nT7bJq
Z6Xa+ErehKIGzXdHeXMa1aq6YaiScH123vs0MiIgAAIgAAKxJsA9WMtZK4Zd QbNXpSkBE4ZVP3knt6jy
uy8rv6NP2ZBzDwnrwD+VDjqj+Lqzcgac8cO/ftudZ/1LpjQ3QJZndZyHocPi BGLlrOI9SFTJw5z1uoqj
bq5In5ae9emmRd9mzJ2964tPt018ZilNCQgJ6+fXXkvC+gYJa6/eE0/+15Sj 7qhnIX0ZK2SucqHU87+D
DkrCypy1e8Oes7QdN4yzUmFeg0hzmuIbbSWqPsNZQQAEQAAEQECbAJnroSTr obkB5KzVY4dW010C6HH0
bVUP38itgGavHhLWAX8sveb3pQNOKx70l139/zLnX7+RnPUf+S44a6IsKhHt wlkLpXk2dKeqW6rzvt+x
Iq2SYtmWysWbKhZuKJ+7tnT26pIZK/d/u2zf14v3fbGg8JN5e978aofMWeul H5E7zFlrpV+WOxgldQE6
rJRJ5VLLjzKVkR9x+Vb8pVCetbs2zRroVdZEe2eQ0rercjpZeVa4tLyJtT5u Rpt8PVUr74ahSnT6rNgF
PAUBEAABEACBbgI823pN1cHpAWX0hlJ2x4V0WwDp5gBP3EEzWSsfuaHigYEK HSq/7k/l1/6hrP//lQ34
fcm1p+Vefdrc807qdlb6vJS0lW7RirkBiZDIOLfpDGfd8vp5PKwCJH2a8M98 1xXl0hSu0O8X536/Y/Ob
q559guawzqcpAXff9c2Qm6Q5rH37vnlBn5d69p7457OePOWPj/3P7584amiz QlsPMzmy2FBkFku/7bFk
Ux13RMlBh9QdSsrKltlLPMLtpqIGJqzvzCh9d0qaJKnV3h79MnkTz72yhl6i 9bUN7UffQGqu3bTpShR9
lvcfy9YTkP0thHdBEAABEHAYgevqXIeFlHaVnPWW86oeuq561M3VdKOAx26u fPh66ZcF7ruSvwlW3HxW
xQ2nVwz6fcWAkysGnFI68NS8q06d+48TJGc9v6A71UpzA45/3So9QD22JeAA Z1346OlyfIqnpske5qwk
i7fXb/06XTTPSs4aCtdtLVIMaeQayuaz0hqK9tDP0dHTY6/eLfPUQ4XlG7JN eCgqPNx6D9XAix1zXQlb
Pu7C1fJqj76he/rBcectVTTHt42mEkW38RQEQAAEQAAElAQGN7t4yMxVSrXc 2Kvi/muqHr2x6rGbqh8d
TLcRqHxwgOKdvWrw6VXXn1o58LeVA35b1v+3eVf8dt7ffyk56wXFkrP+IU/K szrKWV2hf6YFJrk3ZHA0
EcXVWeetz3lqymJ10PpwB4DSq501X1B49n9Yn/V62brxBQsek6ddadncwXOd ku3qUyjlWWn6echZv3ov
e/tnm6aMXXgPZVhDdwno2/eN7gzrmU/+3x8fPfF3D/z8hGHHXLToqLs9LI4Y 6nbdKsUhJWUWGwr5SpFl
vqFiW53a2KwDSrK+saRDyqfWtUnGbLDpaCqR9xnLIAACTiUwpNWFAIE4EDhk rk2u66TZayXXnkn3Xq18
YCDZatUjN1Q+fB1/T68a1octd7mbq288tXrQb6oGnFh+9Ym7Lz1hQc//Jznr xSWStp5dKDnr/7xrTgbi
vxVsVZC5GlRcnZVsVbOj4dZTYUlJ3en6oamtOp7O+iA5K53rkrPWkrC67mq5 cFTF2qnpS99aPWb4t+op
Af/7u5G/OGH4cWe9ddQd1UcO66CQmytXUrJYHjzPSmvkBcIty7dVV6i51fgf OjnS0jo/TQY47oKVgs3x
CqOpRN5nLMeUAPvrCAECIAACDibAtPigudLbUPE1p5Xd2afivn6VDw6sfGjQ IWEdcWnVsAur7zl034Ca
QSdV9z+h/Mrj8//98/l//Yn0Pn5JteuCUkFntY8p2qcnciWzW680+xNvZ/X7 fYGAFNQbWvb7O72e1gjO
2rw+KIvLRs8fMmHhAy8tGfryMrY+nLPyg6G559KnCZKz1kozbO5qoSDhGPZ8 8Y9T0+e9s/bJkd9ddtlr
PXtPYHNY/1fKsA4/7uy3j7lp9zEP+o8a0UnBzPWI/0hxKI06tMN1MDJLpSTo khV7aI28gHyZey3fii2o
K9SsoaZZWk15VjYn4biLNx596wHB5niF0VSi6DaeggAIgAAIgMBhBG7vcPFg f3hL2krfDG6jt6H9fU8u
HXJu+T2XVtx3FX/XrhzRt+q+S6r+c0H1Pf+ovfOvfH3N1b+ovPynuy/47/ln HiM5K72DM22lX2KPlGcV
cbL4lAn3wbc6qRef/nQn8gTmKiS8P/F2Vq/XHYo22nOPp625qa6iZI+Os254 9dxg3UIev7l6yk1Tct5b
XbEqs3bqtpozBs+ml6Qyqn8Ksvzpofwrc1b6AiNNDAgJK+VNyUEveKruow9y 5n+6dca7a66+7LW/nPnk
yX8c9b/nTO7Rd9kx99Ye+0iA4qiHg0eO7KI4YmQnhWuY9EUo+T8mshSltVIe tNnTXYC0Ui64tDx9a/dL
fBOFBPP1h/KsMkUuqO6+IwF7tdkbpAoVTcg3/HR9oL0jQBotL2O0knB9VuwC noIACDiFgGuoHwECMSPA
Ujl0joUWmL/e0u4a4qW3p30Xn1hy3dl0WyvSVvc66cPYymGXVQ67pPI/faru +Wf10F41t59Re8sfab13
2Vc1/X5WcfFxu889et6fjpSc9coDkrP+s1b6NSxHOaugJibcERVuE7f+hGso 3s7qdjfLP7Wn5f17s5mz
UlcUj/R09Qu9gxXTePx9+Ix+L2++69nlw15cedPLa3rft4JeWjXp0I9kcL7h nPVQAWluQKnrGvqqfiNz
VunjfkqgPuCjoGQquekxj3VRHDsqcOzoLilGda+hlaStFEc82EXB/FX+gwK0 zFZSHNd3i/TS+YtZAXlh
tnzsbVXyl/iG6pXqGsYvDM5c28jW08QA2rv2zgBVyPuj0dyd9T/pSb/mVcbL mKkkTJ9557EAAiDgIAL0
hzcCBOJBgP91FDJXes8quvBXND2g5MaeZbf9q/zOPuV39Sm/84KKO/9Vced5 lXf0qrrtrOqbT6u58RSa
GEBJ1urL/7u8z9F5fz9y7ulHdDsrpVrJWemX2K1wVnX+KxZr5Em0WNRvrk4R HzVXs4mt7OKsLS2NTU31
DQ1V1KHamrKy4oK9eek6edZl43sF93/Io9fwGRM2t2bV+HbX+WcU+fo9mx7c /8GyCb3URCLnWX+dwZ2V
J1mZsx7zSKeGsDJtHS1ZrOSso4LdEZJXFvF/iyppDNLsgreXtFHTi0LfZJO+ htXze0M9saQSQy2iMAiA
AAiAQEoROEyID5orvWfln/ezvZf9tqj/n/dd/7f9g/9efHPv4sE9i2/qWXLT 2aWDzyi/4bTyQadU9D+p
ot/xFZf9tPyiY4v/eWTW31wz/yB96d7Vv1VKtZKzCswNMGFOsdtE80vxsWvO WTXr2HO886zlJQWF+Rn5
OVupT3lZm7PT12akrdRx1oVPnxPc8yqPXsO/e3rNgS3Fnp3l3q92e/qO2xbc 8/ICKqP6p+ms8pWuw52V
aSubqMqSrFJQhpUnWQ86q762cn+Nz8LI74PZRW7KrRIAmhiQVdIp5VwvXWOo dUsqMdQiCpsgkFJvb9hZ
EACB5COg1taKhsCOq/6c/s/j0y/6Tcblp2ZceVrGladnXPHHzCv/kHXFqdl9 T87t+5vcS0/Iu/j43D4/
y/vXcbn/+K+sc45Yf4Zr1oWnKJ3VUfe6cpZE2qe38XbW7PQ1m1fPWb9sxrpl 0ynWLv1uw4qZOs46d8zf
glljePQa9q3SWbNHS2V0nVUzDy93Vro9DU+1shkCx4zsUJqrbGKAZp41UePL 0cO9xw3cRblVNgOBlk30
xJJKTLSLTUAABEAABFKBgHLiQSjVOvyj1sa8zMWX//m7M386+5xfzOr5y+97 /er7c345u9fxP/Q6fk7P
n88/56cLzv7Jor/2mH/GMfP/fNSiPx0x54+u2ReeUrsrY/i7zYflWeGs9lHL mPUkrs5q4v6stOOkpDzO
uvPLsWsObA7lWadSnnX8Nk1hlf78kv2T0zu0Wsqz0newQvNZQ78LQI/slwJC Cde2bnMleQ35Kws221UR
bLhhOVoECMSIQDymmmFSIwiAAAjEiED3fICDt9YJzWc9+jbP8A+672Uu7jkV 9f7hbzcffW2LNDGAzWel
uQFwVnGCji0ZV2eNntKZ9819KbM9vzVY7AnOqQ0OfC3LdJ2hPGvIWQeUuW4s cw2pDIX04wKuodK3so4a
1twdkr/ykG4UoAiSCfbtYNzfBARiSQDf7AaB2BHA8AUCMSNAekrCyu4VwG50 dbOHbhogBS3QTa+uk+57
JT2yBR7XNbn6H6CfHuh+lWavsgmsijjorPU1+YhkJcBkL2HOyu4SYOLfr/7y 6Vm9v/jbP778v15fmNic
b9LtrJK2Frv6pLsuyzji8swj+0rhujqfxREDClm4BhVLajuotDtuKDm0zFbS qwgQAAEQcCiBK+hm1QgQ
iA0BepO9pkz7BLus0HVxKOhnKVlctKf7KVtPwdbQ4/kFUvwzX3qkn2ylBXqk N3E4awrIeoKdNRrdtGTb
w5z1sgzJWUPays2V+asiWAEpeHnZhode5cWwAAIWEaBTFAECMSLQPaCx0QwB AlYTiNF5K1XLfrs1dN8A
yoUhkpVAqjvrsb33nDCyscfgomRNpGO/QAAEQAAEQCDpCbgu2OM69XvX8ZOf xT+HEGhsqAgEDv3yfMRE
JJVPsLOanhsQcd8EC8BZk34gww6CAAiAAAgkPQE4q0NM9VA3mYNWNvoz9/u3 5XdszPauzfSu2ulducO9
bLtn6Tb34jTvwi3uuZvaCiulH57YX1qSYGcVNMvYFYOzJv1Ahh0EARAAARBI egJwVoc6KwlrSW3Xnsqu
XSX+rOJAZpF/597AtoJAWr5vU55/fY7/x52dy7e2kgdm7C5KsLMayrNuef08 HlZZLJw16Qcy7CAIgAAI
gEDSE4CzOtRZKcNKwppf5s/aF2C2ujXfvynXvylHEtbVmf4fd3SuSG8j61u1 fU+CnVVcPRc+erq8sOKp
eD2KknDWpB/IsIMgAAIgAAJJTwDO6lBn3bjLyzKsO/b6yVYp0nJ9pKordwZY UJ71x3Qpzzp/fW4CnNXE
bwpQerWz5gsKz/4P67NeL1s3vmDBY/K0Ky2b09Zwzpqs37nDfoEACIAACIBA EhBQWDh3VnMygK3iT4DN
Z12d2S7NBygKzQfI81EMuPtFUtUVO/zLd/jokYI564yVuxLgrOF+o1Xnt1sl JXWn64emtob7HSx+bHSc
Nf7HDy2CAAiAAAiAAAhEJKC4qzz5K5w1IjS7FWDOSl+6ogzrjj3dSVYSVhYk rEtD2krBnHXaspzEOKvf
7wsEpCCnpGW/v9PraY3grM3rg7KY2LfPqht/sfY/J25++g+Zb5759bA/hHNW fpCoLfUBg7Pa7SRGf0AA
BEAABEBAnwCcNQnOEOasdIsAmg+wLT9AwYWVLSzZ2a2tK7ZL81mnLk6Qs3q9 7lC0kUd6PG3NTXUVJXt0
nHXDq+cG6xbK4/Fb+ues3ZS1etPuTZsaDuTnFGdKZVT/FJ7Kn/L8K5w1Cc57 7AIIgAAIgEBKEYCzJsHh
Zs5K97TiUwKYqq7LkaYHcG1dQqnW7VKeNWHO6nY3yz+1p+X9e7OZs7I7Ccgf 6enqF3oHK6axePr8vy2/
7qcrbvnlkrt/tuaJE16+0PXFu59s2VeyalJvcWflJeGsSXDeYxdAAARAAARS igCcNQkON3PWRWkeuksA
l1RaXp/rXyXT1sU7OheH7nX15eJstteKo+/q1yz93u/JU+kXJXSwuFwnZRzb M1/9O1K8Os2NyU1bWhqb
muobGqrIVmtrysqKC/bmpevkWZeN7xXc/yGLx2+6avf6zbnrN+/duqWlbe+W 7PXvffvxhqLSZRN6iTsr
8qxJcLpjF0AABEAABFKTAJw1CY47c9b5Wzx0Tyu6FStpKz1uyA2Qs67Y5V+Q IWVb6XH+9s6Fae5EOmt5
SUFhfkZ+zlZyx7yszdnpazPSVuo468KnzwnuefWh3/9m9sWuuVcfO2PQEUse +uWz/3B9PeXLDbtzB42Z
1H/sewuojOqf5twA+UrTeVZuveHOG1ZAs0vy9c3NzSNGjKBiisRzxG3D1S9v UVFG/tTE5rxmq+rRR8eB
vPHGG0RJ//oU2Z0kuMKxCyAAAiAAAupMG76D5cSzgjnrDxs8dGcr0tYNOZKt UqzL9ZGzLs3xL8zyz93p
m7Otc35aQvOs2elrNq+es37ZjHXLplOsXfrdhhUzdZx17pi/BbPGvPHivcHg gQNNecGgu7Vj78b05VO+
/2zjnn3fT7kjmD1aKqPrrPLJrLygOWctKCjgRkXLmueKoLNu2bJl4cKF3FnF zUxef0lJCYldRD+2yjWt
qkek2wz1p59+Kk7GiZcu+gwCIAACICBOAHlWcVa2LcmcdfZ6N93NirR1XbZv dZafgiYGkLAuyfJRknVu
uu+HrR3zNyXOWU3cn5X2ipR0woShlf7g5j1Z5e3Bbfuylm/dcsPYVwaNfe+F 4f/UFFYugmp9jHJuwPTp
06kG0kR6pOVonJUqIXUz4azyRgX92GgyUrDaiNeD0Xp00sPh2jK6axH7jAIg AAIgAAK2JQBnte2hEe8Y
c9aZa1uXbu9YvtMn/XbAzs6VOzuWZ/joe1cLdvjmbe8gYZ2T5p23qYVKWvAd rB7G57OK74+i5GvvPlfS
EdyQm7avncx124qs7tm4piukDc3lWQcOHEiSRB9Y0yMtyztADkqf9WdmZios Ktx6vrmOdWluy8vLJxUo
UIjPDaAmqCerVq1S51BpX+gl+kcLrH6dPKt4PdF3W6cblJdlr7IcNv6BAAiA AAgkEwE4axIcTease8va
l25uXra1ZfnWVha0TBNYKRaktc3f3DpvY0tBmYdKzllLH7NL/zS+g3VRoet3 X0X+DlaUzsruDyD479Gx
w0Z8smjkJ0tHfLTg4S9WDBr7luCGOsVMOKv802rmRnx6AMu/0sf9bIH+sabD rScL5GlaucOJbKtjbHx/
1XXyLok3QT2sqamh8mzerY6zhttN1pZ+PfJjJO8bwaSnfG5AuL3W3B32lwOJ ePTnCWoAARAAARCwDwE4
q32OhemekLNu2FUluPmcjRXMcRPprIJ9jV0xE87KzIwlHZkV8WQey7+qxS7c eqpKM3kp399w24o7q0Jh
xbsnIojyMka7Kt9W7axcuOVTdUW6pOgGV+3YnUWoGQRAAARAIJ4E4KzxpB2j tshBG5pbZ64teX9+wSvT
8ydNyxk/ddeEL7PHfZlDQcssnp+W9/68ovoWL5w1eFzvPep7ddE3EHUSwORA ZE78m+wiCchwpiWfV6Av
cGrRtNBZRUQw1mXUzkpraKYvtTtu3LiI2q3uHlde/ldEjK46VAsCIAACIBBn AhrOSnfo/F2EO3TGuZNo
Tp8AOWhrc30bRWuju+2Ax93k9bZ2tLd1dHh9vnafr4MiEOjs6vKxSLyzGpob EIvDb9RZ2afk6n+0nrpn
KM+q+NZ8OGc1mrzUlD995TXahI6Ca6aZRXw3XLfZFFueyRapSr47sThnUCcI gAAIgEBiCcBZE8vfktad
56yW7HY0lRh1VpIn0iaaZMkbZRMumVTxCZ2KLzNprqdN5PWEc9ZwdVqYZ9Wf hyqe4o2mHh3V5t94ozIs
yU1/IWh+XYxVwruhmIYbzXmCbUEABEAABOxDAM5qn2NhuifOc1ZDedYtr5/H wzQjxYZGnZU7E69HIUbs
i/Oa9w1QrKeq5LfKV+dueROadcqdlTUn/wxdLZq0Rkdz9W9NoLOtQrUN1SPY baanbFYru4kBoWPTBjTT
ulxb2VYsBY5/IAACIAACSUMAzpoEh9J5zioOfeGjp8sLK56K1xOls5puyCkb hkv3Gu2/VfUYbRflQQAE
QAAEkp4AnDUJDjE5K01XFd8Rx8xnpfRqZ80XFJ79H9ZnvV62bnzBgsfkaVda Ft9teUmjeVZzrdh8K8pc
slkKLGcc8Uenwu2OVfXYHBe6BwIgAAIgkFgCcNbE8rekdeaglY3+zP3+bfkd G7O9azOlWLXTu3KHm2LZ
ds/CLe65m9oKKzuoZFVVGWs3YfdnFdxtSUnd6fqhqa0RvzwOZ6VDQPeXZXMe ovww3ap6BM8KFAMBEAAB
EEhNAnDWJDjuzFlJWEtqu/ZUdu0q8WcVBygyi/w79wYothUE1uf46cex6IcG qOTmrMIEO6vgfFbJR5vX
87j9r+9QsKd8OZyz8uPK5z7KjzScNQnOe+wCCIAACIBAShGAsybB4WbOunSb Oy3Pl5bvo8fNeQGKDbmS
qlKsyPIv2Sn9juvy7ZKzfrm4+9dP7Z5n3fDqucG6hSy6JfXgU75GKqP6J/dU xTJLK8JZk+C8xy6AAAiA
AAikFAE4axIcbuasi9I8m3L9krbm+Tbl+aXI9a8PxYoc/8IM/+IdnYtDedbE OyvLs+o/UoHVL/QOVkxj
0e2sB5/yNasm9RZ0Vrm8wlmT4LzHLoAACIAACKQUAThrEhxu5qw0aXVrPs1n DVCqdXNugGJDTmBdjo9i
RaZ/6Q7/8h2+FdvbbOGsgtCXje8V3P8hi25nPfiUr1k2oZems/IprfxV+SRX OKvgIUAxEAABEAABELAJ
ATirTQ5ENN1wnrMKzmdd+PQ5wT2vUkjTWEMLh8crwT0vSy+p/snv3yl3Vr4M Z43mhMO2IAACIAACIBB/
AnDW+DO3vEXnOasggrlj/hbMGsOiO8968ClfI5UJ76z0iqa/6jgrXRIIEAAB EAABEAABGxKor8mXh6tP
oet3U13HTxb0ChRLOAHnOatgnpXIkpKyYM7Kn/I1mvQV9wpQ/GySznewEn4s 0QEQAAEQAAEQAIFwBOCs
Tj83nOesJoh351llW6rXiFcbLs+quBjwFARAAARAAARAwLYEkGcVNx+blHSe s4rnWeWI5ZIajbBSnXBW
2w5A6BgIgAAIgAAICBKAs9rERMW74TxnFd+3GJWEswoOBygGAiAAAiAAArYl AGeNkSbFrlrn/aaAuTyr
hQThrLYdgNAxEAABEAABEBAkAGe1UI3iU1UCnPXYnvknjGzsMbhIflbxm1BE 3O2EO2uPngXq/gteISgG
AiAAAiAAAiBgBwJw1ojGZbcCVjprnyLXyV/p3zXC5TopI0pnTThBOKsdxhr0 AQRAAARAAASiIQBnTbhQ
Ge2A85xVPM+65fXzeBjlolMezhrNGIFtQQAEQAAEQMAOBOCsFqpRfKpynrMK cln46OnykoqngpVoFoOz
2mGsQR9AAARAAARAIBoCcNZoXCgh2zrPWUXyrJRe7az5gsKz/8P6rNfL1o0v WPCYPO1Ky6Zxw1mjGSOw
LQiAAAiAAAjYgQCc1bQIJWpD5zmrCClJSd3ph0XzesWacNpKv3TF/yHPaodh BX0AARAAARAAAcsJwFlF
hMpWZZznrIJ51iBJqiz+8+Tqc3p/To98pY6z8iOk+B1Xth55VssHDlQIAiAA AiAAAnEmAGe1lY+KdMZ5
ziqyVxtePTdYt5BHz96fvre6ggUtNxzIp5ekMlr/FJ7Kn/LkK5w1zsMKmgMB EAABEAABywnAWUWEylZl
nOesLM+q/7j6hd7Bimks5MLKtZXWr5rU25Cz8sJwVssHDlQIAiAAAiAAAnEm AGe1lY+KdMZ5ziqyV8vG
9wru/5DF2TdMV+RZaU1w/wfLJvQy5KzIs8Z5NEFzIAACIAACIBA7AnBWEaGy VZnkdNaFT58T3PNqcM/L
FGSo+2s9NJOVzJUeaVly1j0vL6AywnMD5BMGkGeN3QiCmkEABEAABEAgPgTg rLbyUZHOJKezzh3zt2DW
GBZkqLkVbbsq2shZ6ZFCctbs0VKZSM4qn8yKuQHxGUTQCgiAAAiAAAjEgQCc VUQTbVUmOZ2VEJOSsiBV
3VTUsnFfC1ugoIVwwkobhrvXFeYGxGEEQRMgAAIgAAIgEB8CcFZb+ahIZ5iz LkrzbMr1p+X5KDbl+aXI
9a8PxYoc/8IM/+IdnYu3tlLJLxdns2rpS1Dyk8rVr9nVp8h18leu4yfrtOty nZRxbM/8E0Y29hhcJN+e
VyfSaaNlSFIX7jrAH41uriiPuQHxGU3QCgiAAAiAAAjEjgCcNUodiv/mKeGs hHX0m9vIWekxesTROytL
2SquQ82VrAwrrN4kdleyuZrt30Nz+4WtQAAEQAAEko8AnDV6I4pzDanirBZi NeGsfF5BOPXUtz1zzhp/
g5T3U966iZ6IAEm+ARR7BAIgAAIgEDcCcFYL1Sg+VcFZDXM24axyVdW0MRFF M2F+cbvy5flg9bLl3bA/
Cst3GRWCAAiAAAhYSwDOaliAEr0BnNXwEdCcjxvxQuKaJc+58q0UK9VPFdYr n0ggr1nuizzrqW5R/j0z
Rc8j9iRibYp29XuuSUNnE76DnEDE5K5mhyMeLxQAARAAARBIbgKSs548Vf9b OIYVARvEkgCc1TDd6J1V
PQqE+yRdLWTqkhGdVW7Gch1ULOs/Vc9P0F+j00/ekM78AXXlcmiKDdUE9JtA mja534ewdyAAAiAgQgDO
aliAEr0Bc9Zl2z1b8/3b8gNp+b7NuQGKDTmBdTk+ihWZ/qU7/Mt3+FZsb3Pq fQOshWxPZw1ntyLuqJBa
zaeJclZNv9RXfEWyWSepLDKooQwIgAAIgEBSEoCzWmtHcagNzmoYMpxVIYWa eVwRV46YZ+UNKczVkLMm
5VCLnQIBEAABEIiSAJzVsAAlegM4q+EjYDdnDfdxv3hm1LZ5VvGOyTVaX6kV uKIc8rA5CIAACICAQwnA
WQ0LUKI3SICz9oj7bwpYC9mEs8q/BhTxw24mVfw7Rtyx5LM25a8adVZ5/erO qJtW90QhiIoP3xX9lHdP
c7/UuinfZcWeyi1Wc86reiaAolE4q0PfXdBtEAABELCWAJzVWjuKQ22WOmuh 63cRvoEn/Q5WCjqrtZeZ
hbXh20gWwkRVIAACIAACDiIAZ42DZVrbBJzVME8TeVa7XcPq1KPdeoj+gAAI gAAIgEBMCcBZDQtQojeA
sxo+AkngrDEdBVA5CIAACIAACNifAJzVsAAlegPmrEu3udPyfHSjK3rcnBeg 2JAbWJ/jp1iR5V+y07dk
h2/59tZI97rC3ICafPtfpeghCIAACIAACIAAnDXRCmq4fTirYWTIs2KkAwEQ AAEQAAGnE4CzGhagRG8A
ZzV8BOCsTh+n0H8QAAEQAAEQgLMaFqBEb6Bw1sa2LkVgboDyEMFZMdKBAAiA AAiAgNMJwFkTraCG21fn
WSfPa1cE5rMehhXO6vRxCv0HARAAARAAATirYWdM9AbIsxo+AnBWjHQgAAIg AAIg4HQCcFbDApToDZBn
NXwE4KxOH6fQfxAAARAAARCAsxoWoERvwJx1UZpnU66fbnSlMZ81x78ww794 R+firbjXVehowVkx0oEA
CIAACICA0wnAWROtoIbbVzgraat6PiucFfNZcd9ZEAABEAABEEgqAnBWw86Y 6A2QZzV8BJBndfrf1ug/
CIAACIAACMBZDQtQojdAntXwEYCzYqQDARAAARAAAacTgLMaFqBEb6B21k15 fily/etDsQLzWRXHKHpn
nfj5ckRiCSiG2qqK7MK8jfnZq/OyflTHzi3zWfCXqGTBrrW0CW2oqCqx+4XW 9Qk4/S0W/QeB5CNg4fBr
FA6cNdEKarh9OKthZJY4q+FWsYF1BEhrFEMb2WdlSebYD2acdvMk14WjI8YJ Aybc98rU6vLs8v3pame1
rqeoyUoC6uMOxQcBEIg/gdgNv3BWK0dMW9YFZzV8WOCshpHFeIPKRn9WcWBb fsfGHO+azHaKVTu9K9Lb
lm33LN3mplic5l24xT13U1thZQf1Re0ulDQlYR08/uu1GUUinc3dX02Fn/ng e808q0gNKBM9geiPO50J
0XcDNYAACIgTiOnwC2cVPxAOLcmcld7ct+
FUDForum. Page generated in 0.03494 seconds
