Home » Modeling » OCL » Identical model elements
Identical model elements [message #497105] |
Thu, 12 November 2009 14:20 |
I am a beginner and playing with the OCL, and trying to identify identical model elements using following query.
context uml::Model
inv: Actor.allInstances()->exists(a1,a2:Actor| a1<>a2 and a1.name= a2.name)
It returns me true result, this means that two actor with same name are present in the model.
now the next step , I want output that query should also show me the name of the identical actors, for this if I apply select operation on exists but it complains, any suggestion how can I get the value of those identical elements.
Thanks in advance,
pokojo
Re: Identical model elements [message #497788 is a reply to message #497105] |
Fri, 13 November 2009 12:24 |
--=-gJOW+6Xp9aobY2+HYucM
Content-Type: text/plain
Hi, pokojo,
Try something like this:
context uml::Model
def: findSimilarActors() : Set(Actor) =
Actor.allInstances()->select(a |
Actor.allInstances()->exists(b | a <> b and a.name =
b.name))
Then if you need the names, do:
getModel().findSimilarActors().name->asSet()
HTH,
Christian
On Thu, 2009-11-12 at 09:20 -0500, pkojo wrote:
> context uml::Model
> Thanks in advance,
> pokojo
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
Try something like this:<BR>
<BR>
context uml::Model<BR>
def: findSimilarActors() : Set(Actor) =<BR>
Actor.allInstances()->select(a |<BR>
Actor.allInstances()->exists(b | a <> b and a.name = b.name))<BR>
<BR>
Then if you need the names, do:<BR>
<BR>
getModel().findSimilarActors().name->asSet()<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-gJOW+6Xp9aobY2+HYucM--
Re: Identical model elements [message #497805 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497809 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497810 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497825 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497826 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497832 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497839 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497849 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497852 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497857 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497860 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497864 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497865 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497885 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497906 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497912 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497925 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Identical model elements [message #497941 is a reply to message #497105] |
Hi, pokojo,
context uml::Model
b.name))
HTH,
Christian
> context uml::Model
> Thanks in advance,
> pokojo
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, pokojo,<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
context uml::Model
Thanks in advance,
pokojo
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Current Time: Fri Apr 26 17:22:45 GMT 2024
Powered by FUDForum. Page generated in 0.04575 seconds
