| Debug JSP in Galileo broken? [message #497067] |
Thu, 12 November 2009 07:34  |
I can set a BP in the JSP code and the debug session stops at the line of code in the JSP, and I can view the variables. I can even step through, watching the JSP line numbers and variables change.
However, even though I have the specific JSP file open in the editor, Eclipse will open a new tab with the error message "Source not found." and I have tried all of the options on "Edit Source Lookup Path", from Java project to project folder to external file. Nothing works. I have to continually click over from the empty source window to the open one to manually scroll through the code as the debugger is running.
Why is this, and can I get around it?
java 1.6.0_07
WinXP sp3
Thank you!
FUDForum. Page generated in 0.04009 seconds
