Home » Modeling » EMF » Teneo: Storing null in EAV schema
Teneo: Storing null in EAV schema [message #496955] Wed, 11 November 2009 15:46 Go to next message
When using Teneo with EAV schema, I seem to be unable to store an EObject if the value for one of its EStructuralFeature's is null. I get the following exception:
org.hibernate.PropertyValueException: not-null property references a null or transient value: EAVSingleEAttributeValueHolder.mandatoryValue
I tried to make the property nullable by adding an annotation to the XSD from which the ecore model is created, eg.
<xsd:element name="Number" type="xsd:integer">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Column(name="Number",nullable="true ")</xsd:appinfo>
</xsd:annotation>
</xsd:element>
However, this does not fix the problem. Does anyone know how to make this work?
Re: Teneo: Storing null in EAV schema [message #496956 is a reply to message #496955] Wed, 11 November 2009 16:01 Go to previous messageGo to next message
Hi Andrew,
With an EAV mapping most (I would even say all) jpa annotations are ignored. In this case (afaics) the xsd element has
minOccurs=1 (the default). This means that for ecore (and Teneo) it is a mandatory feature which must have a value. The
EAVSingleEAttributeValueHolder.mandatoryValue field is used to enforce required/mandatory constraints.
So in this case it can be solved by adding minOccurs="0" to the xsd element.
gr. Martin
> <xsd:annotation>
> ")</xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> this work?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo: Storing null in EAV schema [message #496964 is a reply to message #496956] Wed, 11 November 2009 17:19 Go to previous message
Yes, that fixes it. Thanks!
Previous Topic:Re: [Teneo] how to supress Teneo-Output to console
Next Topic:[CDO] Re: Slide ESE 2009
Current Time: Fri Nov 07 07:59:51 EST 2025
Powered by FUDForum. Page generated in 0.03215 seconds
