Re: how to restore my workspaces? [message #496702 is a reply to message #496625] |
Wed, 11 November 2009 04:12 |
Can you try importing your project?
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
loucat wrote:
> Hi everybody!
> i think my question is a bit stupid but i thinked the task would have
> been easier :p
> i had to format my hard disk and I obviously saved the directory of my
> eclipse workspaces, then I re-installed tha same eclipse version
> (ganymede 3.4.1) and told eclipse where to find the workspace.
> everything seems ok but when i select the workspace, i can't see
> anything in the project explorer or in the outline at the right.
> do i have to import something?
> should i have saved something else besides the workspace directory?
> thank you very much for helping...
> lou
> p.s. my OS is windows XP
Re: how to restore my workspaces? [message #496859 is a reply to message #496742] |
Wed, 11 November 2009 15:04 |
loucat wrote:
> i didn't export my previous project (I just saved the folders) and I
> don't have an archive file so I don't know how to import them...
> I go to "import existing projcet into workspace" , but if I select "root
> directory" I just can select the folder of my previous project without
> anything appearing in the box below, so I can't push the botton "finish" :(
Stab in the dark...
Have tried launching Eclipse on the workspace in question and then
re-creating the projects as if new?
For example, let's say you had a Dynamic Web Project named foo. You
create a new DWP in the workspace named foo, leave the source to be in
the same, default place and then see if it appears magically.
You may need to delete some of the configuration files such as
..settings, .project, etc. You have the workspace backed up, so give this
more radical solution a try and play around with it.
I have done this successfully for deleted projects. As I say, it's just
a stab in the dark.
Russ Bateman
Re: how to restore my workspaces? [message #496951 is a reply to message #496883] |
Wed, 11 November 2009 20:28 |
loucat wrote:
> maybe I didn't understand what you exactly mean with "a stub in the
> dark" (my English is not so good)... but IT WORKS!!!
> I've just created new java projects with the same names of the previous
> ones, without the need to delete any configuration file.
> thank you so much!! :d
> lou
English expression: a stab (of a knife) in the dark == an act of
desperation.
Glad to help!
Russ
FUDForum. Page generated in 0.08006 seconds
