Home » Eclipse Projects » Riena » Java 5 Enums / Hessian / Riena
Java 5 Enums / Hessian / Riena [message #496232] |
Mon, 09 November 2009 12:28 |
Jens Mayer Messages: 19 Registered: September 2009 Location: Hamburg |
I encountered a com.caucho.hessian.io.HessianFieldException when I tried to use a DTO which owns an Enum.
This is the Enum:
public enum BelegTyp {
Lieferschein("LIEFERUNG"),
Retoure("RETOURE"),
Rechnung("REKO");
private final static Map<String,BelegTyp> map = new HashMap<String,BelegTyp>();
private final String value;
private BelegTyp (String val){
this.value = val;
public String getValue() {
return value;
public String toString() {
return value;
... this is the DTO which owns the Enum:
public class DTOBeleg {
protected BelegTyp typ;
public BelegTyp getTyp() {
return typ;
public void setTyp(BelegTyp typ) {
this.typ = typ;
... and this is the DTO which has to be transferred:
public class DTOLieferschein extends DTOBeleg {
private String lieferscheinNr;
public String getLieferscheinNr() {
return lieferscheinNr;
public void setLieferscheinNr(String lieferscheinNr) {
this.lieferscheinNr = lieferscheinNr;
On the client-side the following exception is fired during deserialization:
Caused by: com.caucho.hessian.io.HessianFieldException: de.myapp.common.we.DTOBeleg.typ: de.myapp.common.we.DTOLieferschein (DTOLieferschein [allbel_id=0, lieferscheinNr=00039023]) cannot be assigned to de.myapp.common.we.BelegTyp
at com.caucho.hessian.io.JavaDeserializer.logDeserializeError(JavaDeserializer.java:589)
at com.caucho.hessian.io.JavaDeserializer$ObjectFieldDeserializer.deserialize(JavaDeserializer.java:387)
at com.caucho.hessian.io.JavaDeserializer.readObject(JavaDeserializer.java:233)
at com.caucho.hessian.io.JavaDeserializer.readObject(JavaDeserializer.java:157)
at com.caucho.hessian.io.SerializerFactory.readObject(SerializerFactory.java:364)
at com.caucho.hessian.io.Hessian2Input.readObjectInstance(Hessian2Input.java:2017)
at com.caucho.hessian.io.Hessian2Input.readObject(Hessian2Input.java:1943)
at com.caucho.hessian.io.CollectionDeserializer.readList(CollectionDeserializer.java:78)
at com.caucho.hessian.io.Hessian2Input.readObject(Hessian2Input.java:1666)
at com.caucho.hessian.client.HessianProxy.invoke(HessianProxy.java:201)
... 36 more
I know that there were some issues with hessian and Java5-Enums in former versions of hessian (3.0.x)
Riena 1.1.0 uses Hessian 3.1.3, right ? So Enums should be supported.
Can anybody tell me how to avoid these errors?
Thanks in advance, Jens
[Updated on: Mon, 09 November 2009 12:29] Report message to a moderator
Riena RCP mit redView - events - [message #496268 is a reply to message #496232] |
Mon, 09 November 2009 14:40 |
--------------080903070108060005000003
if you're interested into Riena RCP - I'll demonstrate the next weeks
how redView (Riena EMF Dynamic Views) will enhance Riena RCP applications,
esp. if you're using a model-driven workflow.
redView (http://redview.org) will finally become open source (EPL) in
nov/dec 2009.
promised !!!
first time I presented redView together with flo at EclipseCon 2009 and
I know it took much more time as expected to reach the point where we'll
make it open source.
please notice: redView was developed by flo and me: flo does it in his
spare time beside his regular job
and I'm self-employed - so there's (till now) no company behind redView.
but there are real projects using redView.
redView provides a WYSIWYG SWT editor and can be used for prototyping,
RCP applications with riena UI + LnF
or as a nice UI for WebServices. redView Views can be generated using
openArchitectureWare (MWE / Xpand / Xtend)
the next weeks we'll fill some gaps and create documentation and I'll
also demonstrate redView:
Munich, W-JAX, 2009-11-11, BOF, Room Barcelona, 19:30 - 20:30
"Was man mit Eclipse EMF alles machen kann: Business UIs modellgetrieben"
(What you can do with Eclipse EMF: Business UIs model-driven)
http://it-republik.de/jaxenter/wjax09/
Karlsruhe, Open Source EXPO, 2009-11-15 + 2009-11-16 at Exhibition
and 2009-11-16, 16:35 - 17:05 Open Stage
http://it-republik.de/konferenzen/openexpo/psecom,id,1.html
Eclipse Democamp Frankfurt, 2009-11-26
http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Fran kfurt
Eclipse Democamp Hamburg, 2009-12-04
http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Hamb urg
(and Flo will present redView at Eclipse Democamp, Vienna, 2009-11-30
http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Vien na)
read more about redView at http://redview.wordpress.com/
or http://ekkescorner.wordpress.com/
or follow me at @twitter http://twitter.com/ekkescorner
I'll publish the links soon after redView can be downloaded (EPL)
ekke (ekkehard gentz)
independent software-architect
senior erp-consultant
eclipse | osgi | equinox | mdsd | oaw | emf | uml
max-josefs-platz 30, D-83022 rosenheim, germany
mailto:ekke@ekkes-corner.org
homepage (de): http://gentz-software.de
blog (en): http://ekkes-corner.org
twitter: @ekkescorner
skype: ekkes-corner
Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID: DE189929490
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
applications,<br>
esp. if you're using a model-driven workflow.<br>
<br>
redView (<a class="moz-txt-link-freetext" href="http://redview.org">http://redview.org</a>) will finally become open source (EPL) in
nov/dec 2009.<br>
promised !!!<br>
<br>
first time I presented redView together with flo at EclipseCon 2009 and<br>
we'll make it open source.<br>
<br>
spare time beside his regular job<br>
and I'm self-employed - so there's (till now) no company behind redView.<br>
but there are real projects using redView.<br>
<br>
RCP applications with riena UI + LnF<br>
openArchitectureWare (MWE / Xpand / Xtend)<br>
<br>
also demonstrate redView:<br>
<br>
Munich, W-JAX, 2009-11-11, BOF, Room Barcelona, 19:30 - 20:30<br>
modellgetrieben"<br>
(What you can do with Eclipse EMF: Business UIs model-driven)<br>
<a class="moz-txt-link-freetext" href="http://it-republik.de/jaxenter/wjax09/">http://it-republik.de/jaxenter/wjax09/</a><br>
<br>
Karlsruhe, Open Source EXPO, 2009-11-15 + 2009-11-16 at Exhibition<br>
and 2009-11-16, 16:35 - 17:05 Open Stage<br>
<a class="moz-txt-link-freetext" href="http://it-republik.de/konferenzen/openexpo/psecom,id,1.html">http://it-republik.de/konferenzen/openexpo/psecom,id,1.html</a><br>
<br>
Eclipse Democamp Frankfurt, 2009-11-26<br>
<a class="moz-txt-link-freetext" href=" http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Fran kfurt"> http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Fran kfurt</a><br>
<br>
Eclipse Democamp Hamburg, 2009-12-04<br>
<a class="moz-txt-link-freetext" href=" http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Hamb urg"> http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Hamb urg</a><br>
<br>
(and Flo will present redView at Eclipse Democamp, Vienna, 2009-11-30<br>
<a class="moz-txt-link-freetext" href=" http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Vien na"> http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Vien na</a>)<br>
<br>
read more about redView at <a class="moz-txt-link-freetext" href="http://redview.wordpress.com/">http://redview.wordpress.com/</a><br>
or <a class="moz-txt-link-freetext" href="http://ekkescorner.wordpress.com/">http://ekkescorner.wordpress.com/</a><br>
or follow me at @twitter <a class="moz-txt-link-freetext" href="http://twitter.com/ekkescorner">http://twitter.com/ekkescorner</a><br>
<br>
I'll publish the links soon after redView can be downloaded (EPL)<br>
<div class="moz-signature">-- <br>
<p style="margin-bottom: 0cm;"> <font ,="" color="#808080"
face="Verdana, sans-serif"> <font size="4">ekke (ekkehard gentz)<br>
</font> <font size="3"> independent software-architect<br>
senior erp-consultant<br>
</font> <font size="2">eclipse | osgi | equinox | mdsd | oaw | emf |
uml<br>
max-josefs-platz 30, D-83022 rosenheim, germany<br>
<a class="moz-txt-link-freetext" href="mailto:ekke@ekkes-corner.org">mailto:ekke@ekkes-corner.org</a><br>
homepage (de): <a class="moz-txt-link-freetext" href="http://gentz-software.de">http://gentz-software.de</a><br>
blog (en): <a class="moz-txt-link-freetext" href="http://ekkes-corner.org">http://ekkes-corner.org</a><br>
twitter: @ekkescorner<br>
skype: ekkes-corner<br>
</font> <font size="1"> Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID:
DE189929490<br>
</font> </font> </p>
</div>
</body>
</html>
--------------080903070108060005000003--
ekke
independent software architect
blog: http://ekkes-corner.org
Re: Java 5 Enums / Hessian / Riena [message #496477 is a reply to message #496232] |
Tue, 10 November 2009 08:57 |
Stefan Liebig Messages: 124 Registered: July 2009 |
Hi Jens,
I tried to reproduce your problem. But I could not reproduce it.
Within our test bundle we have a AbstractSerializerFactoryTestCase
class. With that I wrote a test case (see below) trying to reproduce
your problem. I added equals/hashCode for comparing the expected and
result objects. Could you please run the test in your environment?
(Yes, we use Hessian 3.1.3)
public class EnumProblemOnNG extends AbstractSerializerFactoryTestCase {
public void testEnumGiven() {
DTOLieferschein lieferschein = new DTOLieferschein();
lieferschein.setLieferscheinNr("0815");
lieferschein.setTyp(BelegTyp.Lieferschein);
assertTrue(isBackAndForthOk(lieferschein,
HessianSerializerVersion.Two, null));
public void testEnumNotGiven() {
private static enum BelegTyp {
Lieferschein("LIEFERUNG"), Retoure("RETOURE"), Rechnung("REKO");
private final static Map<String, BelegTyp> map = new HashMap<String,
BelegTyp>();
private BelegTyp(String val) {
this.value = val;
return value;
return value;
// ... this is the DTO which owns the Enum:
private static class DTOBeleg {
public int hashCode() {
final int prime = 31;
int result = 1;
result = prime * result + ((typ == null) ? 0 : typ.hashCode());
return result;
public boolean equals(Object obj) {
if (this == obj) {
return true;
if (obj == null) {
return false;
if (getClass() != obj.getClass()) {
return false;
DTOBeleg other = (DTOBeleg) obj;
if (typ == null) {
if (other.typ != null) {
return false;
} else if (!typ.equals(other.typ)) {
return false;
return true;
return typ;
this.typ = typ;
//... and this is the DTO which has to be transferred:
public static class DTOLieferschein extends DTOBeleg {
int result = super.hashCode();
result = prime * result + ((lieferscheinNr == null) ? 0 :
lieferscheinNr.hashCode());
return result;
if (this == obj) {
return true;
if (!super.equals(obj)) {
return false;
return false;
DTOLieferschein other = (DTOLieferschein) obj;
if (lieferscheinNr == null) {
if (other.lieferscheinNr != null) {
return false;
} else if (!lieferscheinNr.equals(other.lieferscheinNr)) {
return false;
return true;
return "DTOLieferschein [lieferscheinNr=" + lieferscheinNr + ", typ="
+ typ + "]";
jens.mayer1@gmx.de wrote:
> This is the Enum:
> Retoure("RETOURE"),
> Rechnung("REKO");
> this.value = val;
> return value;
> @Override
> return value;
> return typ;
> this.typ = typ;
> at
> com.caucho.hessian.io.JavaDeserializer.logDeserializeError(J avaDeserializer.java:589)
> at
> com.caucho.hessian.io.JavaDeserializer$ObjectFieldDeserializ er.deserialize(JavaDeserializer.java:387)
> at
> com.caucho.hessian.io.JavaDeserializer.readObject(JavaDeseri alizer.java:233)
> at
> com.caucho.hessian.io.JavaDeserializer.readObject(JavaDeseri alizer.java:157)
> at
> com.caucho.hessian.io.SerializerFactory.readObject(Serialize rFactory.java:364)
> at
> com.caucho.hessian.io.Hessian2Input.readObjectInstance(Hessi an2Input.java:2017)
> at
> com.caucho.hessian.io.Hessian2Input.readObject(Hessian2Input .java:1943)
> at
> com.caucho.hessian.io.CollectionDeserializer.readList(Collec tionDeserializer.java:78)
> at
> com.caucho.hessian.io.Hessian2Input.readObject(Hessian2Input .java:1666)
> at com.caucho.hessian.client.HessianProxy.invoke(HessianProxy.j ava:201)
> ... 36 more
Riena RCP mit redView - events - [message #584071 is a reply to message #496232] |
nov/dec 2009.
promised !!!
skype: ekkes-corner
<html>
<head>
</head>
applications,<br>
<br>
nov/dec 2009.<br>
promised !!!<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
uml<br>
DE189929490<br>
</div>
</body>
</html>
ekke
Re: Java 5 Enums / Hessian / Riena [message #584078 is a reply to message #496232] |
Hi Jens,
BelegTyp>();
this.value = val;
return value;
return value;
int result = 1;
return result;
if (this == obj) {
return true;
if (obj == null) {
return false;
return false;
if (typ == null) {
return false;
return false;
return true;
return typ;
this.typ = typ;
return result;
if (this == obj) {
return true;
return false;
return false;
return false;
return false;
return true;
+ typ + "]";
> This is the Enum:
> Retoure("RETOURE"),
> Rechnung("REKO");
> this.value = val;
> return value;
> @Override
> return value;
> return typ;
> this.typ = typ;
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 36 more
Current Time: Fri Apr 26 13:30:08 GMT 2024
Powered by FUDForum. Page generated in 0.03959 seconds
