frequent StructuredDocumentRegionManagementException errors [message #495990] |
Fri, 06 November 2009 22:27 |
No real name Messages: 2 Registered: November 2009 |
I am new to the forums and I hope this is the right place for this. If not, I apologize:
So I am creating a JEE/xforms app using Eclipse Galileo. I never had these problems in Ganymede, but I encountered this particular error about 24 times today alone and ever since I started using the software with increasing frequency.
I will be typing and then all of a sudden, the editor will just freeze up and will type maybe 1 character/5 seconds, sometimes finishing the whole word, most of the time not. I only have a few files in this project, and the page that it happens on is only like 1000 lines. I looked in the logs and found that:
!ENTRY org.eclipse.wst.xml.core 4 4 2009-11-06 12:58:37.998
!MESSAGE IStructuredDocumentRegion management failed.
!STACK 0
org.eclipse.wst.xml.core.internal.document.StructuredDocumen tRegionManagementException: IStructuredDocumentRegion management failed.
was showing up each time. Can anyone tell me what I can do to fix this? It is making Eclipse nigh unusable. It is also consuming a lot of my CPU when this happens (around 50% usually).
Thanks!
I am using WinXP SP2
Eclipse IDE for Java EE Developers
Version 1.2.1.20090918-0703
-Eclipse Platform -> 3.5.1.M20090917-800
-Java EE IDE Feature 1.2.1.20090918-0703
Also, I am not getting any kind of heap space or OOM errors.
Full Stack Trace:
!STACK 0
at org.eclipse.wst.xml.core.internal.document.XMLModelParser.re moveStructuredDocumentRegion(XMLModelParser.java:2191)
at org.eclipse.wst.xml.core.internal.document.XMLModelParser.re moveStructuredDocumentRegion(XMLModelParser.java:2221)
at org.eclipse.wst.xml.core.internal.document.XMLModelParser.re placeStructuredDocumentRegions(XMLModelParser.java:2272)
at org.eclipse.wst.xml.core.internal.document.DOMModelImpl.node sReplaced(DOMModelImpl.java:671)
at org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt._fireEvent(BasicStructuredDocument.java:596)
at org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.fireStructuredDocumentEvent(BasicStructuredDocument.java: 1194)
at org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.internalReplaceText(BasicStructuredDocument.java:1975)
at org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.replaceText(BasicStructuredDocument.java:2415)
at org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.replaceText(BasicStructuredDocument.java:2400)
at org.eclipse.wst.sse.core.internal.text.JobSafeStructuredDocu ment.access$2(JobSafeStructuredDocument.java:1)
at org.eclipse.wst.sse.core.internal.text.JobSafeStructuredDocu ment$3.run(JobSafeStructuredDocument.java:137)
at org.eclipse.wst.sse.ui.EditorExecutionContext.execute(Editor ExecutionContext.java:147)
at org.eclipse.wst.sse.core.internal.text.JobSafeStructuredDocu ment.replaceText(JobSafeStructuredDocument.java:144)
at org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.replace(BasicStructuredDocument.java:2360)
at org.eclipse.wst.sse.core.internal.text.JobSafeStructuredDocu ment.access$0(JobSafeStructuredDocument.java:1)
at org.eclipse.wst.sse.core.internal.text.JobSafeStructuredDocu ment$1.run(JobSafeStructuredDocument.java:88)
at org.eclipse.wst.sse.core.internal.text.JobSafeStructuredDocu ment.replace(JobSafeStructuredDocument.java:95)
at org.eclipse.jface.text.DefaultDocumentAdapter.replaceTextRan ge(DefaultDocumentAdapter.java:248)
at org.eclipse.swt.custom.StyledText.modifyContent(StyledText.j ava:6634)
at org.eclipse.swt.custom.StyledText.sendKeyEvent(StyledText.ja va:7442)
at org.eclipse.swt.custom.StyledText.doContent(StyledText.java: 2441)
at org.eclipse.swt.custom.StyledText.handleKey(StyledText.java: 5814)
at org.eclipse.swt.custom.StyledText.handleKeyDown(StyledText.j ava:5839)
at org.eclipse.swt.custom.StyledText$7.handleEvent(StyledText.j ava:5541)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1040 )
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1036 )
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1368)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4053)
at org.eclipse.swt.widgets.Canvas.WM_CHAR(Canvas.java:346)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3946 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:342)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4589 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:24 10)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3471)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
[Updated on: Fri, 06 November 2009 22:29] Report message to a moderator
Re: frequent StructuredDocumentRegionManagementException errors [message #496276 is a reply to message #496275] |
Mon, 09 November 2009 15:17 |
OK, I will open up the defect at that link.
It happened again this morning shortly after I opened the editor, so I don't think closing and re-opening does much. The next time it occurs, I will close and re-open to try it again though.
Looking further at the logs, I am also seeing the following error along with the StructuredDocumentRegion management failed issues (neither errors are visible from the editor)
org.w3c.dom.DOMException:
at org.eclipse.wst.xml.core.internal.document.ElementImpl.inser tBefore(ElementImpl.java:696)
at org.eclipse.wst.xml.core.internal.document.XMLModelParser.in sertNode(XMLModelParser.java:1309)
at org.eclipse.wst.xml.core.internal.document.XMLModelParser.in sertNode(XMLModelParser.java:1283)
at org.eclipse.wst.xml.core.internal.document.XMLModelParser.in sertStartTag(XMLModelParser.java:1351)
at org.eclipse.wst.xml.core.internal.document.XMLModelParser.in sertStartTag(XMLModelParser.java:1443)
at org.eclipse.wst.xml.core.internal.document.XMLModelParser.in sertStructuredDocumentRegion(XMLModelParser.java:1453)
at org.eclipse.wst.xml.core.internal.document.XMLModelParser.re placeStructuredDocumentRegions(XMLModelParser.java:2287)
at org.eclipse.wst.xml.core.internal.document.DOMModelImpl.inte rnalSetNewDocument(DOMModelImpl.java:595)
at org.eclipse.wst.xml.core.internal.document.DOMModelImpl.setS tructuredDocument(DOMModelImpl.java:870)
at org.eclipse.wst.sse.core.internal.model.AbstractModelLoader. createModel(AbstractModelLoader.java:127)
at org.eclipse.wst.sse.core.internal.FileBufferModelManager.get Model(FileBufferModelManager.java:721)
at org.eclipse.wst.sse.core.internal.model.ModelManagerImpl._ge tModelFor(ModelManagerImpl.java:658)
at org.eclipse.wst.sse.core.internal.model.ModelManagerImpl.get ModelForEdit(ModelManagerImpl.java:1390)
at org.eclipse.wst.sse.ui.StructuredTextEditor.doSetInput(Struc turedTextEditor.java:1731)
at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3115)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
at org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:759)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2579)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3133)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3160)
at org.eclipse.wst.sse.ui.StructuredTextEditor.init(StructuredT extEditor.java:2321)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:798)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:644)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1417)
at org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:942)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
[Updated on: Mon, 09 November 2009 15:17] Report message to a moderator
FUDForum. Page generated in 0.03080 seconds
