Referencing parameter by name [message #495840] |
Fri, 06 November 2009 11:46 |
Missing name Missing name Messages: 94 Registered: November 2009 |
Member |
Im using the BIRT report designed with a query of the form
select * from myTable where col1 = ? and col2 = ?
where I have defined two input parameters
param1 and param2 which are integers.
This works fine but if I want to do something along the lines of
select * from myTable where col1 = ? and col2 = ? and col3 < ?
it complains about binding, as I assume its confused about which parameter I am comparing against col3. Is it possible to use a parameter more than once in a query, like I want to do?
Can I reference the parameters by name rather than ? such as
select * from myTable where col1 = param1 and col2 = param2 and col3 < param2
I tried various combinations of params["param2"].value and :param2 but cant get it to work
thanks
Tom
[Updated on: Fri, 06 November 2009 11:47] Report message to a moderator
Re: Referencing parameter by name [message #495949 is a reply to message #495840] |
Fri, 06 November 2009 18:18 |
Tom,
Either just create a 3rd parameter and set it to the same thing as the
second or drop the dataset parameters and do the query in the before
open script
this.queryText = "select * from myTable where col1 = " +
jsvar/reportparm + ....
Jason
TREVOR.HIGGINS@FINEOS.COM wrote:
> param2
> cant get it to work
> thanks
> Tom
Re: Referencing parameter by name [message #496336 is a reply to message #496079] |
Mon, 09 November 2009 18:04 |
Colin
What code do you want?
Jason
Colin wrote:
> Hi jason,
> This sounds like it could be very useful for me. Could you be a bit more
> explicit?
> What would the code be to pick up param1, param2 and param3?
> Regards,
> Colin
> Jason Weathersby wrote:
>> Tom,
>> open script
>> Jason
>>> Hi,
>>> < param2
>>> thanks
>>> Tom
Re: Referencing parameter by name [message #496391 is a reply to message #496336] |
Mon, 09 November 2009 20:09 |
Colin Sutton Messages: 121 Registered: July 2009 |
I have a report with two parameters which I match dozens of times in a query on multiple database
sources.
It's tedious matching all the ? and setting dataset param1, param2, ... all to the same report
parameter.
In the example below would the complete before open script be:
this.queryText = "select * from myTable where col1 = " + jsvar/reportparam1 + " and col2 = "
jsvar/reportparam2 " and col3 < " jsvar/reportparam1
Colin
> Colin
> Jason
> Colin wrote:
>> Hi jason,
>> more explicit?
>> Regards,
>> Colin
>>> Tom,
>>> the second or drop the dataset parameters and do the query in the
>>> before open script
>>> Jason
>>>> Hi,
>>>> < param2
>>>> thanks
>>>> Tom
Re: Referencing parameter by name [message #496602 is a reply to message #496391] |
Tue, 10 November 2009 16:07 |
Colin,
That is correct. Reference report parameters like
params["myreportname"].value
Jason
> query on multiple database sources.
> all to the same report parameter.
> jsvar/reportparam1 + " and col2 = " jsvar/reportparam2 " and col3 < "
> jsvar/reportparam1
> Regards,
> Colin
>> Colin
>> Jason
>> Colin wrote:
>>> Hi jason,
>>> more explicit?
>>> Regards,
>>> Colin
>>>> Tom,
>>>> before open script
>>>> Jason
>>>>> Hi,
>>>>> col3 < param2
>>>>> thanks
>>>>> Tom
FUDForum. Page generated in 0.03946 seconds
