Re: OCLConstraintProvider customization [message #50262 is a reply to message #50201] |
Fri, 01 February 2008 14:09 |
Hi, Wong,
In my reply on that other thread, I said:
-----8<-----
If your provider is registered in the plugin.xml using cache="false" in the
<constraintProvider> element, then the framework should not be adding it to
the ConstraintCache provider that caches constraints.
If this is happening to your provider, then that is a severe bug. In that
case, a bugzilla with a reproducible test case would be much appreciated.
----->8-----
Christian
wong wrote:
> Hello,
> My question is continuing on the following:
http://www.eclipse.org/newsportal/article.php?id=1045&gr oup=eclipse.modeling.mdt.ocl#1045
> The getConstraints() of ModelValidationService seems only be called once.
> I am still not find a way to update the constraintCache inside the
> ModelValidationService.
> I tried to write a my own ModelValidationService, but it need the elements
> to configureProviders(IConfigurationElement[] elements).
> I want users can change the .ocl file to do validation again without
> restart the eclipse.
> Could you tell me is there any way to do it Or it not impossible at
> moment.
> Thank you in advance.
> wong.
Re: OCLConstraintProvider customization [message #50346 is a reply to message #50322] |
Fri, 01 February 2008 18:28 |
Hi, Wong,
Good! I'm glad it's working for you, now.
I think this problem with the initial digit is probably more of an issue in
the parser grammar than it is a violation of any naming rules in OCL/UML
(there generally aren't any). Probably not worth worrying about :-)
cW
wong wrote:
> Hello, Christian.
> I got it works. Thank you so much.
> All my bad. I set the inv name started with digit. So it did not work.
> "inv 1rule: self.courseGoals->notEmpty()"
> I really appreciate your help.
> Thank you very much.
> Wong.
FUDForum. Page generated in 0.03008 seconds
