Home » Archived » Java WorkFlow Tooling (JWT) » Possible to use the JWT editor but for a different model?
Possible to use the JWT editor but for a different model? [message #494812] Mon, 02 November 2009 12:55 Go to next message
I am currently developing a custom workflow and that effort has led me to discover this project. All the functionality that the JWT editor has seems to be exactly what I would like to use for my development efforts, except that I need to back it with a custom model, essentially replacing most to the model components with ones specific to our needs.
For example, the activity component is analogous to our "Flow" component, but we also have many more "Action" types that would need to be part of the flow. Perhaps I could get away with renaming Activity to our Flow component name, but then I also need to modify the model to incorporate the additional Action types, eventually removing the generic Action altogether.
Any ideas on the best way to achieve this?
Re: Possible to use the JWT editor but for a different model? [message #494988 is a reply to message #494812] Tue, 03 November 2009 08:32 Go to previous messageGo to next message
Hi Josh
Have a look at the EPC plugin (by the University of Augsburg) :
in the CVS, at org.eclipse.jwt/we/jwt-we-plugins/jwt-we-view-epc
In addition to providing a customized view with custom figures and icons
that have a completely different outlook from the default one, it
provides an additional "EPCEvent" workflow model element that should
show you how to add your own.
I wouldn't advise you to change the existing model for fear of breaking
things, but you can change the text that is displayed for a given model
element in the plugin.properties (ex. Action -> Flow). As shown in the
EPC View sample, you can also change and extend a lot of other things
(1), including adding new model elements by subclassing or using EMF
Aspect-like extensions that we provide :
(1) http://wiki.eclipse.org/JWT_Extensions
(2) http://wiki.eclipse.org/JWT_Metamodel_Extension
Marc Dutoo
Open Wide
Eclipse JWT co-lead
> Action altogether.
Re: Possible to use the JWT editor but for a different model? [message #495150 is a reply to message #494988] Tue, 03 November 2009 17:25 Go to previous messageGo to next message
Thanks for the reply! I will take a look!
Re: Possible to use the JWT editor but for a different model? [message #495277 is a reply to message #495150] Wed, 04 November 2009 08:22 Go to previous message
BTW I urge you to rather or also ask your questions on the mailing list,
that core developers are more likely to monitor and be ready to answer
questions on : jwt-dev@eclipse.org
Marc
Previous Topic:Eclipse Summit Europe 2009 - Aspect Oriented Modeling presentation
Next Topic:Restricting nodes as children of the main Activity
Current Time: Tue Oct 28 01:57:34 EDT 2025
Powered by FUDForum. Page generated in 0.10251 seconds
