Platform hangs on adding dependency to plugin project - 1 files [1/2] [message #494436] |
Fri, 30 October 2009 15:52 |
Gerald Rosenberg Messages: 106 Registered: July 2009 |
Content-Type: multipart/mixed; boundary="(asbhujjhtt=========__1256917952)"
--(asbhujjhtt=========__1256917952)
Content-Type: text/plain; charset="iso-8859-15"
From the dependency tab of the manifest editor, the Add plugin dialog
hangs as soon as I enter a(ny) single character in the "Select a Plug-
in" field (screenshot attached/log trace below).
This is happening for all Eclipse/workspace instances on just one
development machine (WinXP SP3). Seems there was a similar sounding bug
on linux-GTK (https://bugs.eclipse.org/bugs/show_bug.cgi?id=240033), but
not sure how that might apply -- all of XPs accessibility options are
off.
To test, I installed just the current (3.5.1) standard Galileo RCP
distribution in a new empty directory, created a new empty workspace,
used the plugin wizard to create a new plugin project containing a view.
Then, clicked on the plugin.xml->dependency tab->Add->typed an 'o' in
the dialog. A Problem Occured dialog pops up, but can be dismissed.
The Add plugin selection dialog is, however, hung/modal and the only out
is to kill the Eclipse process.
All other dialogs/parts of Eclipse continue to work as expected. Just
this one dialog hangs. No new programs have been installed since well
before the problem started -- just the usual set of MS updates.
Any thoughts on how to find the root cause of the problem would be
appreciated.
Gerald
!SESSION 2009-10-29 20:49:14.687
eclipse.buildId=M20090917-0800
java.version=1.6.0_16
Framework arguments: -product org.eclipse.epp.package.rcp.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product
!ENTRY org.eclipse.ui 4 0 2009-10-29 20:52:43.218
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: 4
at org.eclipse.swt.widgets.Table._getItem(Table.java:160)
at org.eclipse.swt.widgets.Table.wmNotifyChild(Table.java:6333)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4877)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:17 57)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:4507)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4000 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4602 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native
Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:231 3)
at org.eclipse.swt.widgets.Table.callWindowProc(Table.java:334)
at org.eclipse.swt.widgets.Table.callWindowProc(Table.java:200)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4036 )
at org.eclipse.swt.widgets.Table.windowProc(Table.java:5521)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native
Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:24 10)
at org.eclipse.swt.widgets.Display.readAndDispatch
(Display.java:3471)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at
org.eclipse.pde.internal.ui.editor.plugin.RequiresSection.ha ndleAdd
(RequiresSection.java:385)
at
org.eclipse.pde.internal.ui.editor.plugin.RequiresSection.bu ttonSelected
(RequiresSection.java:175)
at org.eclipse.pde.internal.ui.editor.TableSection
$PartAdapter.buttonSelected(TableSection.java:50)
at org.eclipse.pde.internal.ui.parts.SharedPartWithButtons
$SelectionHandler.buttonSelected(SharedPartWithButtons.java: 39)
$SelectionHandler.widgetSelected(SharedPartWithButtons.java: 30)
at org.eclipse.swt.widgets.TypedListener.handleEvent
(TypedListener.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent
(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents
(Display.java:3880)
(Display.java:3473)
at org.eclipse.ui.internal.Workbench.runEventLoop
(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault
(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench
(Workbench.java:493)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench
(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start
(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run
(EclipseAppHandle.java:194)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplicat
ion(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start
(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run
(EclipseStarter.java:368)
(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke
(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework
(Main.java:559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Content-Type: Application/Octet-stream; name="plugin_selection_hang.png"
Content-Transfer-Encoding: Base64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<
Re: Platform hangs on adding dependency to plugin project - 1 files [1/2] [message #494521 is a reply to message #494486] |
Sat, 31 October 2009 02:12 |
In article <hcfh1d$oks$2@build.eclipse.org>, eclipse@cafewalter.com
says...>
> Gerald Rosenberg wrote:
> At least for me, your message contains nothing but a file attachment. I don't
> know what kind of person opens a file attachment posted by a random person with
> no return address, but I hope they don't hang out on eclipse.platform.
> Can you re-post your question as text, rather than file attachments?
Interesting. What news reader are you using?
In any event, you replied to the text-only part (part 1 of 2) of the
posting (the second part is just a standard, though old-school UUENCODEd
PNG - just about any decent news reader will decode and view the
attachment with perfect safety - and, yes I should have changed the
default encoding to MIME, though I don't know if that would have made a
difference to your reader).
Having said that, the Eclipse Web forum interface does plainly and
separately display both parts of the message, the first in full clear-
text and the second as a simple UUENCODEd text block, though with no
decoder available as might be expected.
I will post the plain PNG on my web-site (www.certiv.net) and add a link
to this thread. Very much appreciate if you could take another look
then.
FWIW, my news reader return address was set back in the Eclipse 2.0
days, before the forums were publicly searchable. As I remember, there
was an extended discussion by the webmasters as to whether they could
sufficiently scrub pre-existing message. The null return address was
simply a prudent and still not uncommon tactic. Nonetheless, while I
will remain random, the return address should now be real ;).
Best,
Gerald
FUDForum. Page generated in 0.03799 seconds
