UnsupportedOperationException on WTP [message #494086] |
Thu, 29 October 2009 03:42  |
I am new to WTP. I am trying to create a webservice for my java class using option "Generate default services.xml" in Eclipse WTP, Axis2 server. My java class is having four methods in which two has return type String, and other two are void, and all the four methods throws Exception.
I am following the tutorial http://www.eclipse.org/webtools/community/tutorials/BottomUp Axis2WebService/bu_tutorial.html for creating my project and the web service client.
Now when i am running my client class it throws exception as java.lang.UnsupportedOperationException: An access occurred that is not valid.
The exception trace is :
[ERROR] An access occurred that is not valid.
at org.apache.axis2.description.InOnlyAxisOperation.getMessage( InOnlyAxisOperation.java:117)
at org.apache.axis2.util.MessageContextBuilder.createOutMessage Context(MessageContextBuilder.java:183)
at org.apache.axis2.receivers.AbstractInOutMessageReceiver.invo keBusinessLogic(AbstractInOutMessageReceiver.java:37)
at org.apache.axis2.receivers.AbstractMessageReceiver.receive(A bstractMessageReceiver.java:114)
at org.apache.axis2.engine.AxisEngine.receive(AxisEngine.java:1 73)
at org.apache.axis2.transport.http.HTTPTransportUtils.processHT TPPostRequest(HTTPTransportUtils.java:167)
at org.apache.axis2.transport.http.AxisServlet.doPost(AxisServl et.java:142)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:188)
at org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:172)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:174)
at org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:873)
at org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:689)
at java.lang.Thread.run(Unknown Source)
I have also noticed that this problem occurs only when my java class contains methods void and non-void type that throws exception.
Can anybody tell me how to resolve this?
The versions i am using are Axis2-1.5, JDK 1.6.0_16, tomcat 5.5
Girish B.
Re: UnsupportedOperationException on WTP [message #497140 is a reply to message #494086] |
Thu, 12 November 2009 10:45  |
Hey Girish,
This sounds a lot like this axis2 bug:
http://issues.apache.org/jira/browse/AXIS2-4408
Girish wrote:
> Exception. I am following the tutorial
> valid.
> valid.
> et.java:142)
> stValve.java:127)
> rtValve.java:117)
> apter.java:174)
> ssor.java:873)
> Girish B.
FUDForum. Page generated in 0.05786 seconds
