Home » Archived » BIRT » Fixed Bar Width(How to manually set a bar width?)
Fixed Bar Width [message #493863] Wed, 28 October 2009 06:18 Go to next message
Hi.
I am trying to draw a bar chart with "fat" bars (ie: the bars width has to be larger than it is at the moment).
I had a look at the following topic:
http://www.eclipse.org/forums/index.php?S=88ee42b4fd50eb44fd 2eab20de4a0673&t=msg&th=120940
but could not find which parameter I had to change in order to change the width of my bars.
Any help?
By the way, how could I ask for an enhancement to the chart interface, so that it will be possible to use a GUI to change the space/width of bars in a graph?
Thanks.
Michele
Re: Fixed Bar Width [message #493957 is a reply to message #493863] Wed, 28 October 2009 11:29 Go to previous messageGo to next message
Michele,
If you just want to make them wider, select the 3rd tab in the chart
wizard, then select chart area. Click on the general properties button
and set the Unit Spacing to a smaller number.
Log enhancement request through bugzilla
http://www.eclipse.org/birt/phoenix/community.php
Jason
Michele wrote:
> Hi.
> Any help?
> bars in a graph?
> Thanks.
> Michele
Re: Fixed Bar Width [message #493974 is a reply to message #493957] Wed, 28 October 2009 11:58 Go to previous messageGo to next message
Hi Jason.
I have tried to do as you suggested, but it does not work.
I wonder if I have some other settings that are interfering?
Please see the graph that I have in the preview picture, which is what I am expecting, and the actual result in my html output (but I have tried also pdf and have same results).
http://picasaweb.google.co.uk/michele.mor/BIRT?feat=directli nk
Thanks.
Michele
Re: Fixed Bar Width [message #494030 is a reply to message #493974] Wed, 28 October 2009 16:37 Go to previous messageGo to next message
Michele
can you post the report? and what version of BIRT are you using?
Jason
Michele wrote:
> Hi Jason.
> Thanks.
> Michele
Re: Fixed Bar Width [message #494090 is a reply to message #494030] Thu, 29 October 2009 04:10 Go to previous messageGo to next message
Hi Jason.
I'm using the latest version of BIRT: 2.5.1.v2009070.
Eclipse Version: 3.5.1 Build id: M20090917-0800.
I have attached the report (.rptdesign) file.
Thanks.
Michele
Attachements don't work!!
See below xml source.
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.20" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.5.1.v20090903 Build &lt;2.5.1.v20090917-1447></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.datatools.connectivity.oda.flatfile " name="KeyData" id="19">
<property name="HOME">C:\Work\Report Cabestan</property>
<property name="DELIMTYPE">TAB</property>
<property name="CHARSET">UTF-8</property>
<property name="INCLCOLUMNNAME">YES</property>
<property name="INCLTYPELINE">NO</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.datatools.connectivity.oda.flatfile.dataSet " name="Keyweek" id="150">
<list-property name="computedColumns">
<structure>
<property name="name">Week</property>
<expression name="expression">BirtDateTime.week(row["Date"])</expression >
<property name="dataType">integer</property>
</structure>
<structure>
<property name="name">ContactUnit</property>
<expression name="expression">1</expression>
</structure>
<structure>
<property name="name">Day</property>
<expression name="expression">BirtDateTime.day(row["Date"])</expression >
</structure>
<structure>
<property name="name">Hour</property>
<expression name="expression">importPackage(Packages.java.util);
cl = new GregorianCalendar();
cl.setTime(dataSetRow["Date"]);
cl.get(Calendar.HOUR_OF_DAY);</expression>
</structure>
<structure>
<property name="name">DayWeek</property>
<expression name="expression">BirtDateTime.weekDay(row["Date"],4)</expression >
<property name="dataType">string</property>
</structure>
<structure>
<property name="name">DayWeekTest</property>
<expression name="expression">if(row["DayWeek"] == "Monday"){
"1: Monday";
}else if(row["DayWeek"] == "Tuesday"){
"2: Tuesday";
}else if(row["DayWeek"] == "Wednesday"){
"3: Wednesday";
}else if(row["DayWeek"] == "Thursday"){
"4: Thursday";
}else if(row["DayWeek"] == "Friday"){
"5: Friday";
}else if(row["DayWeek"] == "Saturday"){
"6 Sarturday";
}else if(row["DayWeek"] == "Sunday"){
"7 Sunday";
}</expression>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">Mobile</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">Date</property>
<property name="dataType">date-time</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">Status</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">Keyword</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">Client</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">Email</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">Comment</property>
</structure>
<structure>
<property name="position">8</property>
</structure>
<structure>
<property name="position">9</property>
</structure>
<structure>
<property name="position">10</property>
</structure>
<structure>
<property name="position">11</property>
</structure>
<structure>
<property name="position">12</property>
</structure>
<structure>
<property name="position">13</property>
</structure>
</list-property>
</structure>
<property name="dataSource">KeyData</property>
<structure>
<property name="nativeName">Mobile</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">Date</property>
<property name="nativeDataType">93</property>
</structure>
<structure>
<property name="nativeName">status</property>
</structure>
<structure>
<property name="nativeName">Keyword</property>
</structure>
<structure>
<property name="nativeName">Client</property>
</structure>
<structure>
<property name="nativeName">Email</property>
</structure>
<structure>
<property name="nativeName">Comment</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select "number", "datetime", "status", "Keyword", "Client", "Email", "Comment" from Birt data.txt : {"Mobile","number",STRING;"Date","datetime",TIMESTAMP; "status","status",STRING;"Keyword","Keyword",STRING;"Client ","Client",STRING;"Email","Email",STRING;"Comment","Comment ",STRING}]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>Mobile</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>-1</design:precision>
<design:scale>-1</design:scale>
<design:nullability>Unknown</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>Mobile</design:label>
<design:formattingHints/>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>Date</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>93</design:nativeDataTypeCode>
<design:usageHints>
<design:label>Date</design:label>
<design:attributes>
<design:name>Status</design:name>
<design:position>3</design:position>
<design:usageHints>
<design:label>Status</design:label>
<design:attributes>
<design:name>Keyword</design:name>
<design:position>4</design:position>
<design:usageHints>
<design:label>Keyword</design:label>
<design:attributes>
<design:name>Email</design:name>
<design:position>5</design:position>
<design:usageHints>
<design:label>Email</design:label>
<design:attributes>
<design:name>Comment</design:name>
<design:position>6</design:position>
<design:usageHints>
<design:label>Comment</design:label>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<cubes>
<tabular-cube name="KeywordsbyHour" id="52">
<property name="defaultMeasureGroup">Summary Field</property>
<property name="dimensions">
<tabular-dimension name="Keyword" id="57">
<property name="defaultHierarchy">NewTabularHierarchy1</property>
<property name="hierarchies">
<tabular-hierarchy name="NewTabularHierarchy1" id="58">
<property name="levels">
<tabular-level name="Keyword" id="59">
<property name="columnName">Keyword</property>
</tabular-level>
</property>
</tabular-hierarchy>
</property>
</tabular-dimension>
<tabular-dimension name="Date" id="151">
<property name="isTimeType">false</property>
<property name="defaultHierarchy">NewTabularHierarchy</property>
<tabular-hierarchy name="NewTabularHierarchy" id="99">
<tabular-level name="Hour" id="127">
<property name="columnName">Hour</property>
</tabular-level>
</property>
</property>
</property>
<property name="measureGroups">
<tabular-measure-group name="Summary Field" id="60">
<property name="measures">
<tabular-measure name="ContactUnit" id="61">
<expression name="measureExpression">dataSetRow["ContactUnit"]</expression >
</tabular-measure>
</property>
</tabular-measure-group>
</property>
<property name="dataSet">Keyweek</property>
</tabular-cube>
<tabular-cube name="Data Cube - Keyweek" id="225">
<tabular-dimension name="Group" id="226">
<property name="defaultHierarchy">NewTabularHierarchy2</property>
<tabular-hierarchy name="NewTabularHierarchy2" id="227">
<tabular-level name="Week" id="228">
<property name="columnName">Week</property>
</tabular-level>
</property>
</property>
<tabular-dimension name="Group1" id="234">
<property name="defaultHierarchy">NewTabularHierarchy3</property>
<tabular-hierarchy name="NewTabularHierarchy3" id="235">
<tabular-level name="Keyword" id="236">
</tabular-level>
</property>
</property>
</property>
<tabular-measure-group name="Summary Field1" id="229">
<tabular-measure name="ContactUnit1" id="230">
</tabular-measure>
</property>
</property>
</tabular-cube>
</cubes>
<styles>
<style name="report" id="4">
<property name="fontFamily">"Verdana"</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="MPLandscape" id="2">
<property name="type">a4</property>
<property name="orientation">landscape</property>
<page-footer>
<text id="3">
<property name="marginTop">5pt</property>
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<text name="Title" id="22">
<property name="fontSize">14pt</property>
<property name="fontWeight">bold</property>
<property name="textAlign">center</property>
<property name="contentType">auto</property>
<text-property name="content"><![CDATA[2Enquire
Monthly Report]]></text-property>
</text>
<text-data name="Month" id="23">
<property name="fontSize">12pt</property>
<property name="fontStyle">italic</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression">dataSetRow["Mobile"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Date"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Status"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Keyword"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Client"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Email"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Comment"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Week"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["ContactUnit"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["Day"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Hour"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["DayWeek"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["DayWeekTest"]</expression >
</structure>
</list-property>
<expression name="valueExpr">BirtDateTime.month(BirtDateTime.today(),2)+ " "+BirtDateTime.year(BirtDateTime.today())</expression>
</text-data>
<extended-item extensionName="Chart" name="Total Contacts" id="21">
<xml-property name="xmlRepresentation"><![CDATA[<model:ChartWithAxes xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute" xmlns:data="http://www.birt.eclipse.org/ChartModelData" xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout" xmlns:model="http://www.birt.eclipse.org/ChartModel" xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Version>2.5.1</Version>
<Type>Bar Chart</Type>
<SubType>Side-by-side</SubType>
<Description>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Description>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Anchor>North</Anchor>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>true</Visible>
</Outline>
<Label>
<Caption>
<Value>Total Contacts</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<ItemType>Categories</ItemType>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>688.8</Width>
<Height>259.2</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Thickness>2</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Red>153</Red>
<Green>204</Green>
<Blue>254</Blue>
</Background>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Script>
* Called before rendering Series.
* @param series
* Series
* @param isr
* ISeriesRenderer
* @param icsc
* IChartScriptContext
function beforeDrawSeries( series, seriesRenderer, context )
if( seriesRenderer.getClass() == &quot;classorg.eclipse.birt.chart.render.Bar&quot;){
srh = seriesRenderer.getSeriesRenderingHints();
dph1 = srh.getDataPoints();
//size of precalced bar
var sz = dph1[100].getSize();
//number of points
var ln = dph1.length;
var nus = sz/3;
context.getChartInstance().setUnitSpacing(nus);
</Script>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<ExtendedProperties>
<Name>enable.area.alt</Name>
<Value>false</Value>
</ExtendedProperties>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>A, B, C</DataSetRepresentation>
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>5,4,12</DataSetRepresentation>
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
<AncillarySampleData>
<DataSetRepresentation>Series 1</DataSetRepresentation>
</AncillarySampleData>
</SampleData>
<Interactivity>
<Enable>false</Enable>
</Interactivity>
<EmptyMessage>
<Caption>
<Value>This chart contains no data.</Value>
<Font>
<Alignment>
</Alignment>
</Font>
</Caption>
<Transparency>64</Transparency>
<Red>127</Red>
<Green>127</Green>
<Blue>127</Blue>
</Background>
<Outline>
<Color>
<Transparency>128</Transparency>
<Red>127</Red>
<Green>127</Green>
<Blue>127</Blue>
</Color>
</Outline>
<Insets>
<Top>10.0</Top>
<Left>10.0</Left>
<Bottom>10.0</Bottom>
<Right>10.0</Right>
</Insets>
</EmptyMessage>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Value>X-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>Y-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition>row[&quot;Keyword&quot;]</Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:Gradient">
<StartColor>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</StartColor>
<EndColor>
<Red>108</Red>
<Green>222</Green>
<Blue>228</Blue>
</EndColor>
<Direction>90.0</Direction>
</Entries>
<StartColor>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</StartColor>
<EndColor>
<Red>255</Red>
<Green>149</Green>
<Blue>117</Blue>
</EndColor>
</Entries>
<StartColor>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</StartColor>
<EndColor>
<Red>250</Red>
<Green>209</Green>
<Blue>63</Blue>
</EndColor>
</Entries>
<StartColor>
<Red>98</Red>
<Green>196</Green>
<Blue>117</Blue>
</StartColor>
<EndColor>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</EndColor>
</Entries>
<StartColor>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</StartColor>
<EndColor>
<Red>103</Red>
<Green>205</Green>
<Blue>142</Blue>
</EndColor>
</Entries>
<StartColor>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</StartColor>
<EndColor>
<Red>159</Red>
<Green>189</Green>
<Blue>203</Blue>
</EndColor>
</Entries>
<Entries xsi:type="attribute:ColorDefinition">
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Transparency
[Updated on: Thu, 29 October 2009 04:11] by Moderator
Re: Fixed Bar Width [message #494182 is a reply to message #494090] Thu, 29 October 2009 09:41 Go to previous messageGo to next message
Michele,
I do not see the report attached. Switch to the xml view of the report
and cut and paste to message.
Jason
Michele wrote:
> Hi Jason.
> Thanks.
> Michele
Re: Fixed Bar Width [message #494188 is a reply to message #494182] Thu, 29 October 2009 10:04 Go to previous messageGo to next message
Hi Jason, here the xml source:
<data-sources>
</oda-data-source>
</data-sources>
<data-sets>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
"1: Monday";
"2: Tuesday";
"3: Wednesday";
"4: Thursday";
"5: Friday";
"6 Sarturday";
"7 Sunday";
}</expression>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<design:attributes>
<design:usageHints>
<design:attributes>
<design:usageHints>
<design:attributes>
<design:usageHints>
<design:attributes>
<design:usageHints>
<design:attributes>
<design:usageHints>
<design:attributes>
<design:usageHints>
</oda-data-set>
</data-sets>
<cubes>
</tabular-level>
</property>
</property>
</tabular-level>
</property>
</property>
</property>
</tabular-measure>
</property>
</property>
</tabular-cube>
</tabular-level>
</property>
</property>
</tabular-level>
</property>
</property>
</property>
</tabular-measure>
</property>
</property>
</tabular-cube>
</cubes>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
</text>
</page-footer>
</page-setup>
<body>
</text>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</text-data>
<Description>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Description>
<Block>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Label>
<Caption>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Red>153</Red>
<Green>204</Green>
<Blue>254</Blue>
</Background>
</Block>
<Script>
* @param series
* Series
* @param isr
* ISeriesRenderer
* @param icsc
//number of points
var nus = sz/3;
</Script>
<SampleData>
<BaseSampleData>
</BaseSampleData>
</SampleData>
<Interactivity>
</Interactivity>
<EmptyMessage>
<Caption>
<Font>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>127</Red>
<Green>127</Green>
<Blue>127</Blue>
</Background>
<Outline>
<Color>
<Red>127</Red>
<Green>127</Green>
<Blue>127</Blue>
</Color>
</Outline>
<Insets>
<Top>10.0</Top>
<Left>10.0</Left>
<Right>10.0</Right>
</Insets>
</EmptyMessage>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<StartColor>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</StartColor>
<EndColor>
<Red>108</Red>
<Green>222</Green>
<Blue>228</Blue>
</EndColor>
</Entries>
<StartColor>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</StartColor>
<EndColor>
<Red>255</Red>
<Green>149</Green>
<Blue>117</Blue>
</EndColor>
</Entries>
<StartColor>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</StartColor>
<EndColor>
<Red>250</Red>
<Green>209</Green>
<Blue>63</Blue>
</EndColor>
</Entries>
<StartColor>
<Red>98</Red>
<Green>196</Green>
<Blue>117</Blue>
</StartColor>
<EndColor>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</EndColor>
</Entries>
<StartColor>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</StartColor>
<EndColor>
<Red>103</Red>
<Green>205</Green>
<Blue>142</Blue>
</EndColor>
</Entries>
<StartColor>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</StartColor>
<EndColor>
<Red>159</Red>
<Green>189</Green>
<Blue>203</Blue>
</EndColor>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Tra
Re: Fixed Bar Width [message #494211 is a reply to message #494188] Thu, 29 October 2009 11:13 Go to previous message
Seems to not have come through all the way can you zip the report with
some sample data file and email to me at jasonweathersby at windsteam.net
Jason
> id="1">
> 2.5.1.v20090903 Build <2.5.1.v20090917-1447></property>
> <data-sources>
> <oda-data-source
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> <expression
> </structure>
> <structure>
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> "Monday"){
> "1: Monday";
> "2: Tuesday";
> "3: Wednesday";
> "4: Thursday";
> "5: Friday";
> "6 Sarturday";
> "7 Sunday";
> }</expression>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <model:DesignValues
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> </oda-data-set>
> </data-sets>
> <cubes>
> <property
> id="58">
> <property
> <property
> </tabular-level>
> </property>
> </property>
> <property
> id="99">
> <property
> <property
> </tabular-level>
> </property>
> </property>
> </property>
> <expression
> </tabular-measure>
> </property>
> </property>
> </tabular-cube>
> <property
> id="227">
> <property
> <property
> </tabular-level>
> </property>
> </property>
> <property
> id="235">
> <property
> <property
> </tabular-level>
> </property>
> </property>
> </property>
> <expression
> </tabular-measure>
> </property>
> </property>
> </tabular-cube>
> </cubes>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> </text>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <expression
> </text-data>
> <xml-property
> <Description>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Description>
> <Block>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Label>
> <Caption>
> <Font>
> <Size>16.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>0.0</Left>
> <Right>0.0</Right>
> </Insets>
> </ClientArea>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>2.0</Top>
> <Left>2.0</Left>
> <Right>2.0</Right>
> </Insets>
> </ClientArea>
> <Text>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Text>
> <Separator>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Separator>
> <Title>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Red>153</Red>
> <Green>204</Green>
> <Blue>254</Blue>
> </Background>
> </Block>
> <Script>
> * * @param series
> * Series
> * @param isr
> * ISeriesRenderer
> * @param icsc
> "classorg.eclipse.birt.chart.render.Bar"){
> //number of points
> var nus = sz/3;
> </Script>
> <SampleData>
> <BaseSampleData>
> </BaseSampleData>
> </SampleData>
> <Interactivity>
> </Interactivity>
> <EmptyMessage>
> <Caption>
> <Font>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>127</Red>
> <Green>127</Green>
> <Blue>127</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>127</Red>
> <Green>127</Green>
> <Blue>127</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>10.0</Top>
> <Left>10.0</Left>
> <Right>10.0</Right>
> </Insets>
> </EmptyMessage>
> <Axes>
> <Type>Text</Type>
> <Title>
> <Caption>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <AssociatedAxes>
> <Type>Linear</Type>
> <Title>
> <Caption>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <SeriesDefinitions>
> <Query>
> <Definition>row["Keyword"]</Definition>
> </Query>
> <SeriesPalette>
> <StartColor>
> <Red>80</Red>
> <Green>166</Green>
> <Blue>218</Blue>
> </StartColor>
> <EndColor>
> <Red>108</Red>
> <Green>222</Green>
> <Blue>228</Blue>
> </EndColor>
> </Entries>
> <StartColor>
> <Red>242</Red>
> <Green>88</Green>
> <Blue>106</Blue>
> </StartColor>
> <EndColor>
> <Red>255</Red>
> <Green>149</Green>
> <Blue>117</Blue>
> </EndColor>
> </Entries>
> <StartColor>
> <Red>232</Red>
> <Green>172</Green>
> <Blue>57</Blue>
> </StartColor>
> <EndColor>
> <Red>250</Red>
> <Green>209</Green>
> <Blue>63</Blue>
> </EndColor>
> </Entries>
> <StartColor>
> <Red>98</Red>
> <Green>196</Green>
> <Blue>117</Blue>
> </StartColor>
> <EndColor>
> <Red>128</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </EndColor>
> </Entries>
> <StartColor>
> <Red>64</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </StartColor>
> <EndColor>
> <Red>103</Red>
> <Green>205</Green>
Previous Topic:Birt exports and OpenOffice
Next Topic:New report element DerivedDataSet in BIRT 2.5.1
Current Time: Wed Nov 05 07:47:08 EST 2025
Powered by FUDForum. Page generated in 0.04373 seconds
