| Aggregator fetching from unc path does not work [message #493642] |
Tue, 27 October 2009 08:56  |
Testing the aggregator to build our internal updatesite.
We have internal plugins that are just hosted on shares with P2 metadata enabled.
I am not able to use unc paths as a location to a mapped repository. I tried file:// and \\ and //../ etc none work, in the end i had to move the files to an webserver and go towards that url, then it worked of course.
any chance unc path lookups will work in the future?
| Re: Aggregator fetching from unc path does not work [message #493848 is a reply to message #493822] |
Wed, 28 October 2009 05:41  |
Please update from http://download.eclipse.org/tools/buckminster/tools-3.5 (current version is 1.0.0.r10827).
It should fix your problem. However, there is some more work to do (as the URI format is normalized, a messed up repository view may remain among the repository resources, which in the end should not have any influence on the aggregator functionality though).
Filip
David napsal(a):
> what version are you using?
> i seem to be using:
> buckminister aggregator editor 1.0.0.r10553
> which is the latest on:
> but using Eclipse 3.5.0 though not latest.
> when i try i get ( i just edited the internal url, its a valid url
> internally):
> eclipse.buildId=I20090611-1540
> java.version=1.5.0_14
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=sv_SE
> Framework arguments: -pluginCustomization
> configuration\plugin_customization.ini
> Command-line arguments: -os win32 -ws win32 -arch x86
> -pluginCustomization configuration\plugin_customization.ini
> Warning
> Wed Oct 28 09:04:25 CET 2009
> An exception was ignored during command execution
> java.net.URISyntaxException: Illegal character in path at index 0:
> \\server.company.se\GRPskv\folder\Vershant\Eclipse\VE_Update
> _Site_libraries\lib\Galileo_Final_20090707
> at java.net.URI$Parser.fail(URI.java:2816)
> at java.net.URI$Parser.checkChars(URI.java:2989)
> at java.net.URI$Parser.parseHierarchical(URI.java:3073)
> at java.net.URI$Parser.parse(URI.java:3031)
> at java.net.URI.<init>(URI.java:578)
> at org.eclipse.buckminster.aggregator.p2.util.MetadataRepositor
> yResourceImpl.load(MetadataRepositoryResourceImpl.java:175)
> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo
> ad(ResourceSetImpl.java:255)
> adHelper(ResourceSetImpl.java:270)
> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou
> rce(ResourceSetImpl.java:397)
> yResourceImpl.loadRepository(MetadataRepositoryResourceImpl. java:141)
> yResourceImpl.loadRepository(MetadataRepositoryResourceImpl. java:135)
> at org.eclipse.buckminster.aggregator.provider.MappedRepository
> ItemProvider.onLocationChange(MappedRepositoryItemProvider.j ava:487)
> ItemProvider.notifyChanged(MappedRepositoryItemProvider.java :213)
> at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify
> (BasicNotifierImpl.java:280)
> at org.eclipse.buckminster.aggregator.impl.MappedRepositoryImpl
> .setLocation(MappedRepositoryImpl.java:708)
> .eSet(MappedRepositoryImpl.java:354)
> at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec
> tImpl.java:1073)
> at org.eclipse.emf.edit.command.SetCommand.doExecute(SetCommand
> .java:721)
> at org.eclipse.emf.edit.command.AbstractOverrideableCommand.exe
> cute(AbstractOverrideableCommand.java:131)
> at org.eclipse.emf.common.command.BasicCommandStack.execute(Bas
> icCommandStack.java:84)
> at org.eclipse.emf.edit.provider.ItemPropertyDescriptor.setProp
> ertyValue(ItemPropertyDescriptor.java:1441)
> at org.eclipse.emf.edit.ui.provider.PropertySource.setPropertyV
> alue(PropertySource.java:116)
> at org.eclipse.ui.views.properties.PropertySheetEntry.valueChan
> ged(PropertySheetEntry.java:782)
> at org.eclipse.ui.views.properties.PropertySheetEntry.setValue(
> PropertySheetEntry.java:723)
> at org.eclipse.ui.views.properties.PropertySheetEntry.applyEdit
> orValue(PropertySheetEntry.java:146)
> at org.eclipse.ui.views.properties.PropertySheetEntry$1.applyEd
> itorValue(PropertySheetEntry.java:103)
> at org.eclipse.jface.viewers.CellEditor$1.run(CellEditor.java:3 33)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.eclipse.core.runtime.Platform.run(Platform.java:888)
> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
> at org.eclipse.jface.viewers.CellEditor.fireApplyEditorValue(Ce
> llEditor.java:331)
> at org.eclipse.jface.viewers.CellEditor.focusLost(CellEditor.ja
> va:716)
> at org.eclipse.jface.viewers.TextCellEditor$5.focusLost(TextCel
> lEditor.java:186)
> at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe
> ner.java:137)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
> at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 2583)
> at org.eclipse.swt.widgets.Widget.wmKillFocus(Widget.java:1781)
> at org.eclipse.swt.widgets.Control.WM_KILLFOCUS(Control.java:42 89)
> at org.eclipse.swt.widgets.Control.windowProc(Control.java:3979 )
> at org.eclipse.swt.widgets.Text.windowProc(Text.java:2170)
> at org.eclipse.swt.widgets.Display.windowProc(Display.java:4602 )
> at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
> at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:231 2)
> at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1530)
> at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:6280)
> at org.eclipse.swt.widgets.Control.windowProc(Control.java:3981 )
> at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5821)
> at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
> at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:24 09)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3471)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav
> a:2405)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault
> (Realm.java:332)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work
> bench.java:493)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j
> ava:149)
> at org.eclipse.ui.internal.ide.application.IDEApplication.start
> (IDEApplication.java:113)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips
> eAppHandle.java:194)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher
> .runApplication(EclipseAppLauncher.java:110)
> .start(EclipseAppLauncher.java:79)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS
> tarter.java:368)
> tarter.java:179)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce
> ssorImpl.java:39)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe
> thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:585)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
FUDForum. Page generated in 0.32360 seconds
