Home » Eclipse Projects » Remote Application Platform (RAP) » Popup behaviour for composite
Popup behaviour for composite [message #493439] Mon, 26 October 2009 05:26 Go to next message
Originally posted by: nlippke.t-online.de
Hi all,
I want my composite behave like a popup:
As long as the user interacts within this composite it should still be
visible. But this first time, the user clicks somewhere else it should
disappear.
I played a bit with the focus listener, but that does not do the trick.
The menu is a good example for this behaviour, but it uses a qooxdoo popup
class and I assume, that the logic is put somewhere in there.
Is it possible to simulated this behaviour in plain SWT? Or do I need a
popup on JS site? And if so can I put a composite within a popup?
Any advice?
Niels
Re: Popup behaviour for composite [message #493441 is a reply to message #493439] Mon, 26 October 2009 05:32 Go to previous messageGo to next message
Hi Niels,
did you try to use Shell instead of Composite?
Best,
Ivan
Niels Lippke wrote:
> Hi all,
> disappear.
> popup class and I assume, that the logic is put somewhere in there.
> a popup on JS site? And if so can I put a composite within a popup?
> Any advice?
> Niels
Re: Popup behaviour for composite [message #493452 is a reply to message #493441] Mon, 26 October 2009 06:50 Go to previous messageGo to next message
Yes,
I opened a shell, put the composite inside. Furthermore I attached a
focuslistener on the shell to catch "focus lost events". Problem with this
approach:
The focus lost event is even fired, if a button inside the composite (in the
shell) is clicked. So I coded a check to see if any child control has the
focus and kept the shell visible. But once the shell looses its focus no
more events of those are fired. So if you click afterwards somewhere else in
the app, the shell doesn't notice hat and is still visible.
Niels
"Ivan Furnadjiev" <ivan@eclipsesource.com> schrieb im Newsbeitrag
news:hc3qb9$lb9$1@build.eclipse.org...
> Hi Niels,
> Best,
> Ivan
> Niels Lippke wrote:
>> Hi all,
>> disappear.
>> Any advice?
>> Thanks,
>> Niels
Re: Popup behaviour for composite [message #493497 is a reply to message #493452] Mon, 26 October 2009 10:04 Go to previous messageGo to next message
Hi Niels,
you can do this with ShellListener instead of FocusListener.
HTH,
Ivan
Niels Lippke wrote:
> Yes,
> this approach:
> (in the shell) is clicked. So I coded a check to see if any child
> control has the focus and kept the shell visible. But once the shell
> looses its focus no more events of those are fired. So if you click
> afterwards somewhere else in the app, the shell doesn't notice hat and
> is still visible.
> Niels
>> Hi Niels,
>> Best,
>> Ivan
>> Niels Lippke wrote:
>>> Hi all,
>>> be visible. But this first time, the user clicks somewhere else it
>>> should disappear.
>>> need a popup on JS site? And if so can I put a composite within a
>>> popup?
>>> Any advice?
>>> Thanks,
>>> Niels
Re: Popup behaviour for composite [message #493515 is a reply to message #493497] Mon, 26 October 2009 11:14 Go to previous message
:) Now that was easy.
TAL,
Niels
news:hc4a9h$pe1$1@build.eclipse.org...
> Hi Niels,
> HTH,
> Ivan
> Niels Lippke wrote:
>> Yes,
>> this approach:
>> the shell) is clicked. So I coded a check to see if any child control has
>> the focus and kept the shell visible. But once the shell looses its focus
>> no more events of those are fired. So if you click afterwards somewhere
>> else in the app, the shell doesn't notice hat and is still visible.
>> Niels
>>> Hi Niels,
>>> Best,
>>> Ivan
>>> Niels Lippke wrote:
>>>> Hi all,
>>>> disappear.
>>>> Any advice?
>>>> Thanks,
>>>> Niels
Previous Topic:deploying rap in tomcat: bundle not found and missing constraint
Next Topic:Design question
Current Time: Thu Sep 25 16:31:30 EDT 2025
Powered by FUDForum. Page generated in 0.04439 seconds
