Home » Eclipse Projects » Eclipse Platform » IPageLayout.ID_RES_NAV in 3.5
IPageLayout.ID_RES_NAV in 3.5 [message #493039] Thu, 22 October 2009 15:56 Go to next message
Originally posted by: runzhou.li.gmail.com
I've noticed that IPageLayout.ID_RES_NAV is deprecated in 3.5, noted to use
Common Navigator Framework.
What should I do to migrate?
Thank you.
Re: IPageLayout.ID_RES_NAV in 3.5 [message #493067 is a reply to message #493039] Thu, 22 October 2009 19:29 Go to previous messageGo to next message
Look in the Common Navigator section in the Platform Plugin Guide in the help, there is a section in there that talks about the migration issues.
Re: IPageLayout.ID_RES_NAV in 3.5 [message #493553 is a reply to message #493067] Mon, 26 October 2009 15:35 Go to previous messageGo to next message
So is there a given standard resource navigator to replace this old one now?
I just want to add it into the perspective and go.
If it's for sure cannot be done without using an extension point, then it's
all fine.
"Francis Upton" <francisu@ieee.org> 写入消息
news:hbqpsq$ojl$1@build.eclipse.org...
Re: IPageLayout.ID_RES_NAV in 3.5 [message #493591 is a reply to message #493553] Tue, 27 October 2009 01:44 Go to previous messageGo to next message
> now? I just want to add it into the perspective and go.
Use Project Explorer.
- Prakash
Platform UI Team, IBM
http://blog.eclipse-tips.com
Re: IPageLayout.ID_RES_NAV in 3.5 [message #493592 is a reply to message #493067] Tue, 27 October 2009 01:50 Go to previous messageGo to next message
Francis,
Would it be better if we update the JavaDoc of the
IPageLayout.ID_RES_NAV to use IPageLayout.ID_PROJECT_EXPLORER instead of
that?
- Prakash
Re: IPageLayout.ID_RES_NAV in 3.5 [message #494257 is a reply to message #493592] Thu, 29 October 2009 15:32 Go to previous messageGo to next message
In fact, Resource Navigator and Project Explorer have differences, and these
differences are the reasons why I want to user resource navigator.
"Prakash G.R." <grprakash@gmail.com> 写入消息
news:hc61n4$8pu$1@build.eclipse.org...
> Francis,
> Would it be better if we update the JavaDoc of the IPageLayout.ID_RES_NAV
> to use IPageLayout.ID_PROJECT_EXPLORER instead of that?
> - Prakash
Re: IPageLayout.ID_RES_NAV in 3.5 [message #494272 is a reply to message #494257] Thu, 29 October 2009 17:08 Go to previous messageGo to next message
> these differences are the reasons why I want to user resource navigator.
Well, you're more than welcome to continue to use the RN if it satisfies
your use cases. :)
Remy
Re: IPageLayout.ID_RES_NAV in 3.5 [message #494277 is a reply to message #494272] Thu, 29 October 2009 18:00 Go to previous messageGo to next message
So it's not as "deprecated" as it sounds? ;)
"Remy Suen" <remysuen@ca.ibm.com> 写入消息
news:hcd08r$79q$1@build.eclipse.org...
> your use cases. :)
> Remy
Re: IPageLayout.ID_RES_NAV in 3.5 [message #494278 is a reply to message #494277] Thu, 29 October 2009 18:04 Go to previous messageGo to next message
Depends how you interpret the term "deprecated". If it works for you keep
using it. Just don't expect new enhancements or speedy fixes for bugs
that are reported.
I use a few outdated/unmaintained programs even though there are other
programs that do the same thing and are maintained. The ones I use now do
what I need it to do so I just keep using it.
Remy
Re: IPageLayout.ID_RES_NAV in 3.5 [message #494423 is a reply to message #494278] Fri, 30 October 2009 10:46 Go to previous message
I see.
Thank you so much :)
news:hcd3h8$79q$3@build.eclipse.org...
> that are reported.
> Remy
Previous Topic:Opening CHM help files
Next Topic:Platform hangs on adding dependency to plugin project - 1 files [2/2]
Current Time: Wed Jul 30 13:31:44 EDT 2025
Powered by FUDForum. Page generated in 0.04569 seconds
