Home » Archived » DSDP - Mobile Tools for Java (MTJ) » MJT or EclipseME won't uninstall
MJT or EclipseME won't uninstall [message #492987] Thu, 22 October 2009 11:28 Go to next message
I am working with eclipse 3.4 on a Vista machine and I have been looking at different tools for writing a J2ME application for college.
I initially installed EclipseME using the "Help"->"Software Update...". However, I had problems running any kind of MIDlet with the emulator (even HelloWorld!). I then discovered that EclipseME had moved to MTJ and thought I would uninstall EclipseME and install MTJ instead. I uninstalled EclipseMe through "Help"->"Software Updates...", restarted eclipse and installed MTJ, again through "Help"->"Software Update..." using the URL http://download.eclipse.org/dsdp/mtj/updates/0.9/stable/.
However, once I restarted eclipse, it looked like EclipseMe hadn't uninstalled correctly. For example, I have now entries under windows preferences for J2ME and JaveME and under "Run Configurations" I have 2 Wireless Toolkit Emulator entries.
I checked the eclipse/plugin and eclipse/features directories and the eclipseme directories are gone but when they are present in the <workspace>/.metadata/.plugin directory. I have deleted them from here but everytime I go back into eclipse they reappear.
I then tried to uninstall MTJ (through "Help"->"Software Update") but now the exact same thing has happened. The plugins appear to be gone but the functionality is still present in eclipse. I have gone through all brute force removal steps and started eclipse using "eclipse - clean" from the command line, but still MTJ and EclipseME are present.
I have even tried eclipse's "Revert Configuration" functionality but still no difference.
Both are no longer in the "Installed Software" list so I can no longer use this to try and the uninstall process again.
What is going on and how do I remove them?
Kind regards,
Garrett
Re: MJT or EclipseME won't uninstall [message #493001 is a reply to message #492987] Thu, 22 October 2009 12:18 Go to previous message
It's ok, I finally figured it out. It's all Vista's UAC fault!
The plugins were installed in my User's directory under the eclipse/org.eclipse.platform_3.4.0_... directory. I deleted them from here and J2ME and EclipseME are finally gone.
Previous Topic:Custom symbol set definitions in a team environment
Next Topic:MJT or EclipseME won't uninstall
Current Time: Sun Oct 26 07:12:11 EDT 2025
Powered by FUDForum. Page generated in 0.03615 seconds
