Re: [JET] Jet editor still now working in Galileo [message #492577 is a reply to message #492562] |
Tue, 20 October 2009 19:38 |
Paul Elder Messages: 849 Registered: July 2009 |
No changes were made to the editor to fix the problem, hence, there is no change in the editor plug-in's version.
I have just tested a number of scenarios with the JET editor and Eclipse 3.5.1 and M2T JET 1.0.1
In each case, I have successfully gotten the editor to function.
So, first confirm that the org.eclipse.jet plug-in has version 1.0.1.v200909041702.
Then, if you are still experiencing the problem, please:
1) re-open the bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281554
2) attach a test case the reproduces the problem. Preferably, attach an archive of an entire project so that I can look at all project settings, etc...
Thanks for your patience,
Paul
Re: [JET] Jet editor still now working in Galileo [message #492704 is a reply to message #492577] |
Wed, 21 October 2009 13:20 |
Steven Derrien Messages: 50 Registered: July 2009 |
Member |
Thanks for the help, you were right, my updated org.eclipse.jet plugin
did not install successfully and was therefore not not visible.
I had to reinstall the whole 3.5SR1, but now JET editor works perfectly
well !
Thanks again
Steven
> 1) re-open the bug:
> etc...
> Paul
FUDForum. Page generated in 0.03874 seconds
