Home » Newcomers » Newcomers » Opening file with FileDialog not working...
Opening file with FileDialog not working... [message #492051] Sat, 17 October 2009 13:39 Go to next message
Hi there,
a created a XML file from a model created with GMF. Everything works fine, the file exists after generation.
I used the following code to show a FileDialog in order to allow to the user to open the XML-file which has recently being created:
Shell shell = new Shell();
String[] filterExt = {"*.xml"};
FileDialog fd = new FileDialog(shell, SWT.OPEN);
fd.setText("Open");
fd.setFilterExtensions(filterExt);
fd.setFilterPath(file.getAbsolutePath());
fd.setFileName(fileName);
String fil = fd.open();
The FileDialog actually pops up. However, when I select the XML-file and press the open button, the file does not show up, for instance in the windows editor. Surprisingly, when I use the open function of the context menu, it works fine...
Since I prefer to use the open button, I would be very pleased if anyone could help me with this issue...
Thanks, Scholle
Re: Opening file with FileDialog not working... [message #492053 is a reply to message #492051] Sat, 17 October 2009 13:50 Go to previous messageGo to next message
> windows editor.
What do you mean? Does the open() method return null?
Remy
Re: Opening file with FileDialog not working... [message #492056 is a reply to message #492051] Sat, 17 October 2009 14:07 Go to previous messageGo to next message
The open() method returns the absolute path to the file which has been selected... o this works fine, but what I want is to open the file and to show its content in an external editor (e.g. windows standard editor)...
Re: Opening file with FileDialog not working... [message #492063 is a reply to message #492056] Sat, 17 October 2009 16:58 Go to previous messageGo to next message
> editor)...
Take a look at the API for org.eclipse.swt.program.Program.
Remy
Re: Opening file with FileDialog not working... [message #492066 is a reply to message #492051] Sat, 17 October 2009 18:45 Go to previous message
One solution is to use:
desktop.open(file)
Previous Topic:Proxy Configuration
Next Topic:eclipse 3.0 FAQ code examples
Current Time: Thu Sep 25 08:58:06 EDT 2025
Powered by FUDForum. Page generated in 0.08490 seconds
