Home » Archived » BIRT » Use alias name instead of column name
Use alias name instead of column name [message #491811] Thu, 15 October 2009 18:51 Go to next message
This problem has been discussed in the following bug but I think it needs more attention:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=212387
Just to summarize the problem, if you defined query in the report that use alias for column names, it is possibly not working on the new JDBC drivers. The reason is, in newer JDBC drivers, like MySQL JConnector V5.1.5 and db2 4.x, the call to getColumnName will return the acutal database column name, not the alias name. BIRT is using this API to get the column name for binding.
There are a lot of problem using getColumnName, like the problem above, report not working across jdbc drivers. Also if you have a column named as "description" in two tables, and you want to get both in the same query, BIRT will add a suffix to the column name, and it is very unclear which is the one you want to bind. It also reduce the reusability of the query and dataset definition for similiar reports.
In the latest Java spec, getColumnLabel is described as: "
Gets the designated column's suggested title for use in printouts and displays. The suggested title is usually specified by the SQL AS clause. If a SQL AS is not specified, the value returned from getColumnLabel will be the same as the value returned by the getColumnName method. "
So this is exactly what we are expecting. Does BIRT has any plan to change the code to use getColumnLabel?
Felix
Re: Use alias name instead of column name [message #491913 is a reply to message #491811] Fri, 16 October 2009 10:22 Go to previous messageGo to next message
Felix,
Can you add your comments to the bug?
Jason
Felix Zhang wrote:
> Thanks
> Felix
Re: Use alias name instead of column name [message #492007 is a reply to message #491913] Fri, 16 October 2009 20:46 Go to previous message
Hi Jason,
I have copied my comment into this bug.
Our application need to be deployed on multiple database platforms, getColumnName will return db column name on some database, and return alias name on other databases. So we have to "cheat" the drivers to return the same name all the time, like instead of saying
select a.name aname, b.name bname
from...
we need to use something like
from ...
union
select null aname, null bname
from dummytable
where 1=0
to make the jdbc driver not able to figure out the db column name and have to return the alias name. That's a real pain for us.
Felix
Previous Topic:Report previewing OK then crashing on deploy
Next Topic:Problem opening report on Tomcat using php
Current Time: Wed Sep 24 07:50:48 EDT 2025
Powered by FUDForum. Page generated in 1.56726 seconds
