Re: BIRT 2.5.1 Source Code Available? [message #491749 is a reply to message #491528] |
Thu, 15 October 2009 16:22 |
The source is already available. refresh the tags and look for
BIRT_2_5_1_Release_200909171447
Jason
al kamarauskas wrote:
> When will the source code for BIRT 2.5.1 be made available for download?
> I normally check it out from CVS "versions" / "source", but the latest
> source code is for BIRT 2.5.0.
> Thanks.
Re: BIRT 2.5.1 Source Code Available? [message #491910 is a reply to message #491770] |
Fri, 16 October 2009 13:40 |
Please log a bug for this. For a work around use check out as.. right
click option. When the Select Tag option dialog is displayed click the
refresh tags button. The release tag should then be visible.
Jason
> Hi Jason,
> Yes, I refreshed the tags but I still can't see 2.5.1.
> The top five I see listed under "source" are:
> source v20061120-1200
> source testTag
> source BIRT_2_5_0_Release_200906170630
> source BIRT_2_5_0_RC2_200905261352
> source BIRT_2_5_0_M6_200903181537
> I was expecting to see 2.5.1 here. I am looking in the usual location:
> dev.eclipse.org:/cvsroot/birt
> Is this still correct, or did something change?
> Thanks.
FUDForum. Page generated in 0.03087 seconds
