Home » Modeling » EMF » [TENEO] PersistenceOptions.CASCADE_POLICY_ON_CONTAINMENT, "FALSE" and Addition of a new Ob
[TENEO] PersistenceOptions.CASCADE_POLICY_ON_CONTAINMENT, "FALSE" and Addition of a new Ob [message #491465] Wed, 14 October 2009 13:19 Go to next message
Dear All,
I set the PersistenceOptions.CASCADE_POLICY_ON_CONTAINMENT, "FALSE",
because if I had a relation between 2 Objects (from diffrent resources)
and I delete relation, only the relation should be deleted not the
inheritance Object. Now, if I create a new Object and try to Persist it a
14372 [main] ERROR org.hibernate.event.def.AbstractFlushingEventListener
- Could not synchronize database state with session
org.hibernate.TransientObjectException: object references an unsaved
transient instance - save the transient instance before flushing: Lager
will appear.
The following Command works really fine but if i persist exception above
occur
Lager lager = ZlvpFactory.eINSTANCE.createLager();
lager.setName("Neues Lager");
Command cmd = null;
if (obj instanceof Jahr) {
cmd = AddCommand.create(service.getEditingDomain(), (Jahr)obj,
ZlvpPackage.Literals.JAHR__LAGER, lager);
if (cmd.canExecute()) {
service.getEditingDomain().getCommandStack().execute(cmd);
} else {
throw new ExecutionException("Fehler beim Anlegen des Lagers");
If I set PersistenceOptions.CASCADE_POLICY_ON_CONTAINMENT, "true" all
works fine but the inheritance Object will be deleted.
Re: [TENEO] PersistenceOptions.CASCADE_POLICY_ON_CONTAINMENT, "FALSE" and Addition of a ne [message #491515 is a reply to message #491465] Wed, 14 October 2009 16:36 Go to previous messageGo to next message
Hi Waldi,
FALSE is not a valid value for this option. But maybe you mean the SET_CASCADE_ALL_ON_CONTAINMENT option?
In this case I would set the PersistenceOptions.CASCADE_POLICY_ON_CONTAINMENT option to the following values:
REFRESH,PERSIST,MERGE
gr. Martin
Waldi Waldemar wrote:
> Dear All,
> will appear.
> occur
> Command cmd = null;
> (Jahr)obj, ZlvpPackage.Literals.JAHR__LAGER, lager);
> } else {
> Lagers");
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [TENEO] PersistenceOptions.CASCADE_POLICY_ON_CONTAINMENT, "FALSE" and Addition of a ne [message #491533 is a reply to message #491515] Wed, 14 October 2009 17:45 Go to previous message
mysterious. Hmm but i try it, why does it run?? OK thanks a lot... It
works fine
Martin Taal schrieb:
> Hi Waldi,
> values: REFRESH,PERSIST,MERGE
> gr. Martin
>> Dear All,
>> resources) and I delete relation, only the relation should be deleted
>> not the inheritance Object. Now, if I create a new Object and try to
>> Persist it a
>> 14372 [main] ERROR
>> org.hibernate.event.def.AbstractFlushingEventListener - Could not
>> will appear.
>> above occur
>> Command cmd = null;
>> } else {
>> Lagers");
Previous Topic:XMLTypeFactoryImpl fails to recreate QNames properly while "undoing change"
Next Topic:[CDO] CDO server log trace
Current Time: Tue Oct 28 20:01:42 EDT 2025
Powered by FUDForum. Page generated in 0.03023 seconds
