| Mapping a file to my own protocol resource [message #491264] |
Tue, 13 October 2009 16:43  |
the usecase I'm working on is that a file should be loaded using my
org.eclipse.emf.ecore.resource.Resource.Factory implementation.
I was assuming that I can simply use the following extension points for
that:
<extension
point="org.eclipse.emf.ecore.uri_mapping">
<mapping
source="platform:/resource/JCRMDemo/my.mydomainmodel"
target="jcrm:/test/my.jcr">
</mapping>
</extension>
<extension
point="org.eclipse.emf.ecore.protocol_parser">
<parser
class="org.eclipse.emf.jcrm.repoconn.RepoconnResourceFactoryImpl "
protocolName="jcrm">
</parser>
</extension>
The first one would map the file to my protocol and the second one would
specify my resource factory for the protocol. But the resource or
ExtensibleURIConverterImpl.normalize(URI uri) or
ResourceFactoryRegistryImpl.getFactory(URI...) are never called and if I
open the file its just opened like a simple text file. Is there
something wrong with my mapping definition?
Or can somebody please tell me how to specify a mapping from an
arbitrary file to my resource using an own protocol?
I'm looking forward to your feedback!
Best,
Sandro
| Re: Mapping a file to my own protocol resource [message #491319 is a reply to message #491304] |
Wed, 14 October 2009 03:04   |
Hi Ed,
thanks for your feedback.
My comments are inline.
Ed Merks schrieb:
> Sandro,
> Comments below.
> Sandro Böhme wrote:
>> Hello,
>> for that:
>> <extension
>> <mapping
>> </mapping>
>> </extension>
> It seems odd though to have a registered mapping for something in a
> workspace...
>> <extension
>> <parser
>> </parser>
>> </extension>
>> would specify my resource factory for the protocol. But the resource
>> or ExtensibleURIConverterImpl.normalize(URI uri) or
>> I open the file its just opened like a simple text file.
> The editor does this:
> public void createModel()
> URI resourceURI = EditUIUtil.getURI(getEditorInput());
> Exception exception = null;
> Resource resource = null;
> try
> // Load the resource through the editing domain.
> resource =
> editingDomain.getResourceSet().*getResource*(resourceURI, true);
> and the resource set does this
> public Resource getResource(URI uri, boolean loadOnDemand)
> Map<URI, Resource> map = getURIResourceMap();
> if (map != null)
> Resource resource = map.get(uri);
> if (resource != null)
> if (loadOnDemand && !resource.isLoaded())
> demandLoadHelper(resource);
> return resource;
> URIConverter theURIConverter = getURIConverter();
> URI normalizedURI = theURIConverter.*normalize*(uri);
> so normalize must be getting called.
I will have a look in the ResourceSetImpl to see why my factory isn't
called.
>> Is there something wrong with my mapping definition?
> Hard coding one specific resource in the workspace doesn't seem right.
I'm working on a repository connection configuration editor that can be
used to open a repository. But most modeling tools do rely on workspace
resources for models as you know. This is why I'm working on a way that
a user can define a mapping from his file to a repository connection
configuration (an URI). This way the tools can work on the files while
behind the scenes they working on a repository.
> I think you'd be better to do that in your editor's createModel method.
> Another trick people have used is to write repository into the workspace
I'm not sure what you mean with writing repository into the workspace.
You mean something like writing the repository configuration into file,
registering the file extention to a resource and opening the repo with
the configuration in the file?
> resource so that the workspace resource works more like a link. After
> all, if you have a workspace in the resource, what's actually there?
Nothing ;-)
>> Best,
>> Sandro
Best,
Sandro
| Re: Mapping a file to my own protocol resource [message #491329 is a reply to message #491319] |
Wed, 14 October 2009 03:33   |
Sandro,
Comments below.
Sandro Böhme wrote:
> Hi Ed,
> Ed Merks schrieb:
>> Sandro,
>> Comments below.
>> Sandro Böhme wrote:
>>> Hello,
>>> for that:
>>> <extension
>>> <mapping
>>> </mapping>
>>> </extension>
>> workspace...
>>> <extension
>>> <parser
>>> </parser>
>>> </extension>
>>> if I open the file its just opened like a simple text file.
>> try
>> resource =
>> if (map != null)
>> return resource;
> called.
The debugger generally answers questions faster than me. :-P
> be used to open a repository. But most modeling tools do rely on
> workspace resources for models as you know. This is why I'm working on
> a way that a user can define a mapping from his file to a repository
> connection configuration (an URI). This way the tools can work on the
> files while behind the scenes they working on a repository.
It seems better to try to open such editors with your own URI rather
than try to divert them from opening the expected resource.
EditUIUtil.getURI is called for EMF generated editors so it's possible
to pass in a URIEditorInput.; I'm not sure if GMF editors support other
forms for IEditorInput...
>> method. Another trick people have used is to write repository into
>> the workspace
> file, registering the file extention to a resource and opening the
> repo with the configuration in the file?
Yes.
>> After all, if you have a workspace in the resource, what's actually
>> there?
> Nothing ;-)
That seems problematic. After all, the wizard create the resource so
how will redirecting to a repository still provide access to what's
initially in the resource?
>>> Best,
>>> Sandro
> Best,
> Sandro
| Re: Mapping a file to my own protocol resource [message #491367 is a reply to message #491329] |
Wed, 14 October 2009 07:02   |
Ed Merks schrieb:
> Sandro,
> Comments below.
> Sandro Böhme wrote:
>> Hi Ed,
>> Ed Merks schrieb:
>>> Sandro,
>>> Comments below.
>>> Sandro Böhme wrote:
>>>> Hello,
>>>> for that:
>>>> <extension
>>>> <mapping
>>>> </mapping>
>>>> </extension>
>>> workspace...
>>>> <extension
>>>> <parser
>>>> </parser>
>>>> </extension>
>>> try
>>> resource =
>>> if (map != null)
>>> return resource;
>> called.
I wouldn't bet on it ;-)
I didn't expect an answer. Right now I have a break at work and will
dive into it after work. (as always)
The editor of the connection configuration (concon) model already uses
the URIEditorInput to pass on the connection configuration URI (concon
URI) to the repo-editor to be opened. This way the user can open a
repo-editor without depending on a file that redirects to the repo.
I have seen for example an Eclipse model to model transformation tool
where you can choose a file as a source and as a target. It should be
able with JCRM to create a source and a target file of your choice and
map it to a repository. This way the model to model transformation tool
and other tools can work on those files while they are actually
redirected to a java content repository.
>>> the workspace
> Yes.
>>> there?
>> Nothing ;-)
It depends on what the user want. If he first wants to save an instance
of the model in the file he can set the redirect to the repo later on.
In case he immediately wants to work on the repo he can first define the
mapping with the file name he plans to use. If the user decides to
switch back from the repo to the real file content he can remove the
mapping (assuming I get the mapping to work ;-) ).
BTW: The whole JCRM resource framework including the tools is not yet
checked in. I'm working hard on getting it presentable in a blog entry
until the Eclipse Summit.
Best,
Sandro
| Re: Mapping a file to my own protocol resource [message #491397 is a reply to message #491372] |
Wed, 14 October 2009 08:18  |
Hi Ed,
Ed Merks schrieb:
> Sandro,
> Perhaps you'd like to have a slot at the symposium to present your progress?
> <http://wp.kolbware.de/2009/10/modeling-symposium-cfp/>
puh. At the one hand I avoided presenting something at the Eclipse
Summit this year in favor of coding the resource framework and tools for
JCRM and showing it in my blog. We also have a tight deadline at work
for the 30'th of october and I'm not even sure, if I can attend the
Eclipse Summit. Preparing my progress would mean even more work.
At the other hand I think this is an interesting issue whose solutions
and workarounds are probably relevant to other Eclipse modeling people.
And it would be interesting to discuss that.
I haven't seen a deadline in the cfp. If there isn't one, I will try to
get something ready. But I cannot promise to have it ready for a certain
deadline. I will do my best and there are two weekends in between. My
wife will beat me, but we all have to make our sacrifices right? ;-)
BTW: Do you personally think it makes sense to have a redirection of
files for compatibility? Or do I miss an other way of implementing that
use case?
Best,
Sandro
> Sandro Böhme wrote:
>> Ed Merks schrieb:
>>> Sandro,
>>> Comments below.
>>> Sandro Böhme wrote:
>>>> Hi Ed,
>>>> Ed Merks schrieb:
>>>>> Sandro,
>>>>> Comments below.
>>>>> Sandro Böhme wrote:
>>>>>> Hello,
>>>>>> my org.eclipse.emf.ecore.resource.Resource.Factory implementation.
>>>>>> points for that:
>>>>>> <extension
>>>>>> <mapping
>>>>>> </mapping>
>>>>>> </extension>
>>>>> workspace...
>>>>>> <extension
>>>>>> <parser
>>>>>> </parser>
>>>>>> </extension>
>>>>>> resource or ExtensibleURIConverterImpl.normalize(URI uri) or
>>>>>> and if I open the file its just opened like a simple text file.
>>>>> try
>>>>> resource =
>>>>> if (map != null)
>>>>> return resource;
>>>> isn't called.
>>>> on a way that a user can define a mapping from his file to a
>>>> repository connection configuration (an URI). This way the tools can
>>>> work on the files while behind the scenes they working on a repository.
>>> possible to pass in a URIEditorInput.; I'm not sure if GMF editors
>>> support other forms for IEditorInput...
>> tool and other tools can work on those files while they are actually
>>>>> the workspace
>>>> workspace. You mean something like writing the repository
>>>> configuration into file, registering the file extention to a
>>>> resource and opening the repo with the configuration in the file?
>>> Yes.
>>>>> there?
>>>> Nothing ;-)
>> instance of the model in the file he can set the redirect to the repo
>> later on. In case he immediately wants to work on the repo he can
>> first define the mapping with the file name he plans to use. If the
>> user decides to switch back from the repo to the real file content he
>> can remove the mapping (assuming I get the mapping to work ;-) ).
>> Best,
>> Sandro
FUDForum. Page generated in 0.05257 seconds
