Home » Eclipse Projects » Eclipse 4 » [XWT] TreeViewer
[XWT] TreeViewer [message #491178] Tue, 13 October 2009 10:48 Go to next message
I could not find an example on how to create/configure/use a tree viewer (nothing in tests)...
Could you provide an example? - If possible, using emf data binding...
Re: [XWT] TreeViewer [message #491518 is a reply to message #491178] Wed, 14 October 2009 17:16 Go to previous messageGo to next message
You can find some examples about JFace in org.eclipse.e4.xwt.tests plugins. It is in eclipse CVS repository.
Tree structure relies on ContentProvider. You can define your ContentProvider to determine the Tree structure. We may provide a DefaultEMFContentProvider, which create the tree through the containment.
[Updated on: Wed, 14 October 2009 17:23] by Moderator
Re: [XWT] TreeViewer [message #563907 is a reply to message #491178] Wed, 14 October 2009 17:16 Go to previous message
Previous Topic:[XWT] change input when viewer's selection changes
Next Topic:Architecture Documentation of e4 ?
Current Time: Wed Sep 24 20:03:09 EDT 2025
Powered by FUDForum. Page generated in 0.03468 seconds
