Re: Static JS Classes not in the Outline view [message #491018 is a reply to message #490888] |
Mon, 12 October 2009 19:37 |
Jacek Pospychala wrote:
> hi Saurav,
> the best place to ask this question is WTP newsgroup (JSDT is part of
> WTP). I have added it in the To field.
> saurav wrote:
>> Hello All,
>> I have a JS file which contains few static classes as well as non
>> static ones.But the static classes are not shown in the outline
>> view.Is it the limitation with the JSTD?.
>> Please provide your inputs here.
Which version are you using, and do you have an example?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Static JS Classes not in the Outline view [message #491186 is a reply to message #490873] |
Tue, 13 October 2009 15:06 |
saurav sarkar Messages: 428 Registered: July 2009 |
Hi Nitin,
Please find the details below and the code snippet below.
Eclipse
Version: 3.4.2
Build id: M20090211-1700
JSDT core plug-in : 1.0.014
test.ui.saurav = function () {
test.ui.saurav.prototype.object = function() {
var height=20;
if you press ctrl-o on the above code outline shows the classes.But try with the below code
test.ui.saurav.object = function() {
var height=20;
Outline shows nothinh since the class is a static one.
Please let me know if i am missing something and provide your inputs here.
Thanks and Regards,
Saurav
My Blog http://codifyit.blogspot.com/
Follow me: http://twitter.com/sauravs
[Updated on: Tue, 13 October 2009 15:06] Report message to a moderator
Re: Static JS Classes not in the Outline view [message #561707 is a reply to message #490888] |
> hi Saurav,
> saurav wrote:
>> Hello All,
Nitin Dahyabhai
IBM Rational
_
Nitin Dahyabhai
FUDForum. Page generated in 0.03782 seconds
