| Updated ProjectSet connector - availability [message #490665] |
Fri, 09 October 2009 11:34  |
Does anyone know when the updated ProjectSet connector will be available?
Currently I am getting the following conflict when I try to update my
connector.
Cannot complete the install because of a conflicting dependency.
Software being installed: Subversive Integration for the CSC Project Set
Project 2.0.2.I20090116-1600
(org.polarion.eclipse.team.svn.projectset.feature.group
2.0.2.I20090116-1600)
Software currently installed: ProjectSet 3.0.0.200905051715
(com.csc.dip.projectset.feature.group 3.0.0.200905051715)
Only one of the following can be installed at once:
Projectset 3.0.0.200905051715 (com.csc.dip.projectset
3.0.0.200905051715)
com.csc.dip.projectset 2.18.0.200811141124
Cannot satisfy dependency:
(com.csc.dip.projectset.feature.group 2.18.0.200811141124)
To: com.csc.dip.projectset
To: com.csc.dip.projectset [3.0.0.200905051715]
From: Subversive Integration for the CSC Project Set Project
2.0.2.I20090116-1600 (org.polarion.eclipse.team.svn.projectset.feature.group
To: com.csc.dip.projectset.feature.group [2.18.0.200811141124,3.0.0)
| Re: Updated ProjectSet connector - availability [message #492629 is a reply to message #492265] |
Wed, 21 October 2009 03:31   |
You used old version of Subversive and you need to migrate to new one, for
more details how to migrate please see:
http://www.eclipse.org/subversive/documentation/gettingStart ed/aboutSubversive/update_polarion.php
> Thanks download now works, however, I am still getting the
> org.polarion.team.svn.core.svnnature not supported
> which plugin is that defines this, I thought it would be the PSP svn
> integration.
> "Igor Burilo" <igor.burilo@polarion.org> wrote in message
> news:hbhqkq$bla$1@build.eclipse.org...
>> Hello,
>> Thanks for the issue. I've already fixed this problem and updated 'update
>> site'. Please, try it.
>>> Thank you, I guess I could have done that but I just assumed that the
>>> connector lineup would have already been scheduled for the upgrade
>>> news:hb7bpa$bd3$1@build.eclipse.org...
>>>> Hello,
>>>> I created the corresponding bug on tracker:
>>>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=292407
>>>>> available?
>>>>> connector.
>>>>> Set Project 2.0.2.I20090116-1600
>>>>> 3.0.0.200905051715)
>>>>> From: ProjectSet 2.18.0.200811141124
>>>>> From: ProjectSet 3.0.0.200905051715
| Re: Updated ProjectSet connector - availability [message #492681 is a reply to message #492629] |
Wed, 21 October 2009 07:25   |
Igor,
Thanks, unfortunately the project set that I was trying to load was a old
project set from a previous version of Eclipse which I no longer since I
have upgraded to 3.5.
However, it was fairly easy to figure out that I had to edit the PSF file
directly and replace the line
<provider id="org.polarion.team.svn.core.svnnature">
with
<provider id="org.eclipse.team.svn.core.svnnature">
Everything seems to be okay, but just to be sure is there anything that I
may have missed.
Thanks for your help BTW.
Whatty
news:hbmdbm$1cv$1@build.eclipse.org...
> Hello,
>> integration.
>>> Hello,
>>> 'update site'. Please, try it.
>>>>> Hello,
>>>>>> available?
>>>>>> connector.
>>>>>> 3.0.0.200905051715)
| Re: Updated ProjectSet connector - availability [message #512921 is a reply to message #512786] |
Mon, 08 February 2010 06:10  |
Hello Werner,
>using Subversive lead to the asumption, commits were done for each
>WorkingSet in Eclipse
Commits atomicity doesn't depend on Working Sets, e.g. if you commit two
projects from the same repository and use SVNKit connector (JavaHL doesn't
support commit atomicity) then commit will be atomic.
> So what's this CSC Project or WorkingSet good for?
We have long ago integration for CSC Project Set project, please see
http://vpms.de.csc.com/projectset/
> Sorry, what exactly is an CSC ProjectSet (connector) ?
> As the discussion with other colleagues around the atomicity of commits
> WorkingSet in Eclipse (as it always counts "n items" in the status bar
> which is exactly the number of WorkingSets) I noticed, there's not only an
> Eclipse WorkingSet, but a second "SVN WorkingSet". At least when you use
> Subversive.
> It seems, there are more fundamental problems with Subversive at the
> moment than some fancy add-ons...
> Werner
FUDForum. Page generated in 0.06165 seconds
