Re: How to add a JDBC driver in Eclipse BIRT? [message #490443 is a reply to message #490204] |
Thu, 08 October 2009 16:16 |
Originally posted by: thilo.bruesshaber.gmail.com
Just create a new Data Source and use the "Manage Drivers..." button.
The Driver-JARs can be located anywhere in your file system.
Placing the drivers in
plugins/org.eclipse.birt.report.data.oda.jdbc_2.5.1 is only neccessary
when running BIRT in an application server environment and when you are
not using JNDI provided connections.
--Thilo
D G schrieb:
> I have tried this with both Eclipse BIRT 2.3.2 and 2.5.1.
> I don't see any instructions on how to add a JDBC driver to BIRT. I did
> find this: http://www.eclipse.org/birt/phoenix/build/#drivers but it
> doesn't seem to reflect what shows up in the plugin UI.
> The steps I tried:
> 1. Go into the
> eclipse/plugins/org.eclipse.birt.report.data.oda.jdbc_2.5.1. v20090821
> directory and place the JDBC driver JAR there, as per the readme in that
> directory.
> 2. Bring up Eclipse, go into the Database Development perspective, Data
> Source Expolorer view.
> 3. Click New Connection Profile. Select Generic JDBC. Observe that the
> Drivers dropdown is empty.
> 4. Another route. Double-click an existing db connection e.g. "BIRT
> Classic Models Sample Database". Select "JDBC Connection Properties". My
> driver is not in the drivers list. Click the New driver definition
> button. Select Jar List. Observe that the Add Jar/Zip button is not
> enabled.
> Can someone provide a definitive list of steps which actually work,
> either for 2.3.2 or 2.5.1?
> Thanks.
FUDForum. Page generated in 0.03860 seconds
