Home » Eclipse Projects » DSDP - Target Management » TM Terminal View -> Serial Connection Port Problem
Re: TM Terminal View -> Serial Connection Port Problem [message #4496 is a reply to message #4356] |
Fri, 19 January 2007 20:37 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
First question is, do you want / need javax.comm?
If not, better use the rxtx-2.1 implementation which is available since
I20070118-0400
http://download.eclipse.org/dsdp/tm/downloads/drops/I2007011 8-0400/index.php
It means uninstalling javax.comm and getting rxtx-2.1 as shown in the
new instructions.
Do you have Eclipse SDK? - If yes, try to import the team project set
http://www.eclipse.org/dsdp/tm/development/terminal-anonymou s.psf
(save to a file, then do File > Import > Team > Team Project Set).
You will get a few eclipse projects out of CVS, inluding
org.eclipse.tm.terminal.serial
Switch to the R1_0_1 tag if you want to work on the old version, otherwise
use HEAD for rxtx-2.1. If you installed javacomm into your JVM properly,
you should not see an error marker and you should see the comm.jar
or RXTXcomm.jar library below the "Referenced Libraries" of the project.
cheers,
Martin Oberhuber
Wind River Systems, Inc.
Target Management Project Lead, DSDP PMC Member
Re: TM Terminal View -> Serial Connection Port Problem [message #565810 is a reply to message #4356] |
I20070118-0400
new instructions.
cheers,
Martin Oberhuber
Current Time: Fri Apr 26 09:54:06 GMT 2024
Powered by FUDForum. Page generated in 0.03488 seconds
