Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » GMF & TENEO
GMF & TENEO [message #490110] Wed, 07 October 2009 08:10 Go to next message
I tried to repeat this tutorial. http://www.elver.org/hibernate/gmftutorial/tutorial1.html. I thought everything works good, but when I tried to run the example & the new workbench opened, I couldn't see the mindmap diagram which I made before the tutorial, there is an error:
Could not open the editor: The editor class could not be instantiated. This usually indicates a missing no-arg constructor or that the editor's class name was mistyped in plugin.xml.
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.gmf.examples.mindmap.rcp.diagram (766).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:381)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:457)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:398)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:326)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:231)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1193)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:267)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:263)
at org.eclipse.ui.internal.registry.EditorDescriptor.createEdit or(EditorDescriptor.java:235)
at org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:845)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:606)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1417)
at org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:942)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.gmf.examples.mindmap.rcp.diagram.part.MindmapDia gramEditorPlugin.start() of bundle org.eclipse.gmf.examples.mindmap.rcp.diagram.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:806)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
... 58 more
Caused by: java.lang.NoClassDefFoundError: org/hibernate/EntityNameResolver
at org.eclipse.gmf.examples.mindmap.rcp.diagram.db.StoreControl ler.initializeDataStore(StoreController.java:81)
at org.eclipse.gmf.examples.mindmap.rcp.diagram.part.MindmapDia gramEditorPlugin.start(MindmapDiagramEditorPlugin.java:71)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:774)
... 63 more
Caused by: java.lang.ClassNotFoundException: org.hibernate.EntityNameResolver
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:494)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 68 more
When I try: File - New - Mindmap Diagram then I read: The chosen operation is not currently available, the same if I press the Mindmap DB button.
If I delete the StoreController.getInstance().initializeDataStore(); in the stop method of MindmapDiagramEditorPlugin.java (Initialize Teneo when plugin starts - http://www.elver.org/hibernate/gmftutorial/tutorial2.html - down on the side) than it works, but without DB.
I use a empty SQL Server 2005 database and I think the jdbc driver and all the packeges are correct.
What can I do - hope you can help me.
Re: GMF & TENEO [message #490122 is a reply to message #490110] Wed, 07 October 2009 08:53 Go to previous messageGo to next message
Hi Rafnixx,
Which version of Hibernate are you using? With Teneo 1.1.1/1.1.2 you need to use Hibernate 3.3.2 (and not 3.3.1 or earlier).
Btw, support for Teneo is given on the main EMF newsgroup which I added in the cc.
gr. Martin
rafnixx@hushmail.com wrote:
> leLoader.java:410)
> leLoader.java:398)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> leLoader.java:326)
> n.java:267)
> .java:70)
> er.java:845)
> erence.java:462)
> rManager.java:1417)
> onizer.java:134)
> a:3855)
> nch.java:1384)
> onizer.java:134)
> a:3855)
> (Realm.java:332)
> bench.java:493)
> ava:149)
> tarter.java:368)
> tarter.java:179)
> ion.java:408)
> ... 58 more
> at java.security.AccessController.doPrivileged(Native Method)
> ... 63 more
> leLoader.java:410)
> leLoader.java:398)
> ... 68 more
> button.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: GMF & TENEO [message #490131 is a reply to message #490110] Wed, 07 October 2009 09:36 Go to previous messageGo to next message
Hi Martin,
I'm using Teneo 1.1.2 and Hibernate 3.3.2.GA in a seperate Plugin.
Some minutes ago I tried mapping with Hibernate Tools for Eclipse and its works.
Any idea why it doesn't works like in the tutorial?
Re: GMF & TENEO [message #490139 is a reply to message #490131] Wed, 07 October 2009 09:47 Go to previous messageGo to next message
Hi Rafnixx,
I then think it is a plugin classpath issue. Can you give a summary of the plugins (the EMF model, GMF plugins and the
plugin containing the hibernate jars) and their dependencies and export relations?
The reason that I mentioned the hibernate version before is that the class mentioned in the CCE is a new class
introduced in Hibernate 3.3.2, so it is not present in 3.3.1.
gr. Martin
> Hi Martin,
> I'm using Teneo 1.1.2 and Hibernate 3.3.2.GA in a seperate Plugin. Some
The Netherlands
Re: GMF & TENEO [message #490140 is a reply to message #490131] Wed, 07 October 2009 09:47 Go to previous message
Btw, forgot to add :-), support for Teneo is really given on the main emf newsgroup. Can you answer there?
gr. Martin
> Hi Martin,
The Netherlands
Re: GMF & TENEO [message #621440 is a reply to message #490131] Wed, 07 October 2009 09:47 Go to previous message
Hi Rafnixx,
gr. Martin
> Hi Martin,
The Netherlands
Re: GMF & TENEO [message #621441 is a reply to message #490131] Wed, 07 October 2009 09:47 Go to previous message
gr. Martin
> Hi Martin,
The Netherlands
Previous Topic:GMF & TENEO
Next Topic:EEF code generation failed
Current Time: Tue Nov 04 12:39:12 EST 2025
Powered by FUDForum. Page generated in 0.03940 seconds
