Home » Modeling » EMF » Trying to call Generated Ecore Model Code from Java Application
Trying to call Generated Ecore Model Code from Java Application [message #490038] Tue, 06 October 2009 22:22 Go to next message
I created an Ecore model and used the Generator to generate the Model,
Edit, and Editor. I create an instance of the Ecore Model in the Editor
and persisted it to the default XMI format. I exported the model package.
I need to access this Model code and XMI instance from a Webservice. I
have created a Java class which creates a ResourceSet and tries to load
the XMI instance. I get this error:
Here is the code in the Java method:
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap()
.put("sizing", new XMIResourceFactoryImpl());
URI uri = URI.createFileURI("c:/Applications.sizing");
Resource resource = resourceSet.getResource(uri, true);
When I debug it throws a error at this line:
The first two lines of the XMI file are:
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:sizing="http://www.oracle.com/esg/sizing.ecore/1.0.0">
Error:
Exception in thread "main"
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri
'http://www.oracle.com/esg/sizing.ecore/1.0.0' not found.
(file:/c:/Applications.sizing, 3, 346)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at SizingStandAlone.main(SizingStandAlone.java:23)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package
with uri 'http://www.oracle.com/esg/sizing.ecore/1.0.0' not found.
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2590)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2421)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1299)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1468)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:169)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
... 2 more
Thanks for any help.
Richard
Re: Trying to call Generated Ecore Model Code from Java Application [message #490068 is a reply to message #490038] Wed, 07 October 2009 03:20 Go to previous message
Richard,
Comments below.
> Editor and persisted it to the default XMI format. I exported the
> model package.
> I have created a Java class which creates a ResourceSet and tries to
> load the XMI instance. I get this error:
Did you look the XyzExample.java that's generated in the *.tests project
if you invoke "Generate Test Code"?
> Error:
Yes, the package isn't registered automatically when you're not running
in OSGi, so an idiom to use is to invoke XyzPackage.eINSTANCE.eClass()
which registers the package as a side effect.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> ... 2 more
> Richard
Previous Topic:CDO - my experience
Next Topic:[CDO] Possibilities and constraints of using CDO
Current Time: Fri Sep 26 21:06:19 EDT 2025
Powered by FUDForum. Page generated in 0.04101 seconds
