Re: problem publishing web project into tomcat installation if outputfolderis WebContent/WEB-INF/cla [message #490379 is a reply to message #490125] |
Thu, 08 October 2009 13:52 |
Ivica Loncar Messages: 41 Registered: July 2009 |
Member |
Hello Larry,
> Ivica Loncar wrote:
>> If I reorder classpath containers in Java Build Path's such that
>> classpath container that should be exported to the WEB-INF (the one
>> marked under J2EE module dependencies) comes first I get all required
>> jars exported.
>> If I reverse the ordering I do not get jars contained in bothe
>> classpath containers.
>> I'm still trying to figure out if this is related to the IVYDE
>> classpath container or the way J2EE dependencies get exported to the
>> WEB-INF/lib.
> Sounds like a bug, but where? Are you able to determine if the
> content of the classpath containers makes a difference, or just the
> order? If you can post the relevant portions of the ".classpath"
> file, I could try some experiments with some simple classpath
> container code I have.
This is .classpath entry where compile comes before runtime (#1):
<classpath>
<classpathentry kind="src" path="src"/>
<classpathentry kind="con" path="org.eclipse.jst.j2ee.internal.web.container"/>
<classpathentry kind="con" path="org.eclipse.jst.j2ee.internal.module.container"/>
<classpathentry kind="con" path=" org.eclipse.jst.server.core.container/org.eclipse.jst.server .tomcat.runtimeTarget/Apache
Tomcat v6.0">
<attributes>
<attribute name="owner.project.facets" value="jst.web"/>
</attributes>
</classpathentry>
<classpathentry kind="con" path=" org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.inte rnal.debug.ui.launcher.StandardVMType/jdk ">
<attributes>
<attribute name="owner.project.facets" value="jst.java"/>
</attributes>
</classpathentry>
<classpathentry kind="con" path=" org.apache.ivyde.eclipse.cpcontainer.IVYDE_CONTAINER/?ivyXml Path=ivy%2Fivy.xml&confs=compile "/>
<classpathentry exported="true" kind="con" path=" org.apache.ivyde.eclipse.cpcontainer.IVYDE_CONTAINER/?ivyXml Path=ivy%2Fivy.xml&confs=runtime ">
<attributes>
<attribute name="org.eclipse.jst.component.dependency" value="/WEB-INF/lib"/>
</attributes>
</classpathentry>
<classpathentry kind="output" path="build/classes"/>
</classpath>
Contents of WEB-INF/lib in tomcat directory after publishing is:
aspectjrt-1.6.5.jar
aspectjweaver-1.6.5.jar
commons-pool-1.3.jar
easymock-2.5.1.jar
spring-aop-2.5.6.jar
spring-context-support-2.5.6.jar
spring-jms-2.5.6.jar
spring-web-2.5.6.jar
spring-webmvc-2.5.6.jar
(these are the jars that are resolved by the the runtime configuration but
not by the compile configuration).
and this is classpath entry where runtime comes before compile (#2):
<classpath>
Tomcat v6.0">
<attributes>
</attributes>
</classpathentry>
<attributes>
</attributes>
</classpathentry>
<attributes>
</attributes>
</classpathentry>
</classpath>
aopalliance-1.0.jar
aspectjrt-1.6.5.jar
commons-fileupload-1.2.1.jar
commons-io-1.4.jar
commons-logging-1.1.1.jar
dom4j-1.6.1.jar
easymock-2.5.1.jar
spring-beans-2.5.6.jar
spring-context-2.5.6.jar
spring-core-2.5.6.jar
spring-tx-2.5.6.jar
(these are all of the jars resolved by the runtime configuration).
Here's the ivy.xml file I use in the "sample" project:
<ivy-module version="2.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="http://ant.apache.org/ivy/schemas/ivy.xsd">
<info organisation="net.croz" module="IntegrationWeb" status="integration">
</info>
<configurations>
<conf name="default" />
<conf name="compile" />
<conf name="runtime" />
<conf name="test" />
<conf name="sources" />
</configurations>
<publications>
<artifact name="IntegrationWeb" type="war" ext="war"></artifact>
</publications>
<dependencies>
<dependency org="com.ibm.websphere.appserver" name="runtime" rev="6.1"
conf="compile->default" />
<dependency org="com.ibm.ws" name="j2ee" rev="6.1" conf="compile->default"
<dependency org="javax.jms" name="jms" rev="1.1" conf="compile->default"
<dependency org="org.springframework" name="spring-aop" rev="2.5.6"
conf="runtime->default" />
<dependency org="org.springframework" name="spring-jms" rev="2.5.6"
<dependency org="org.springframework" name="spring-web" rev="2.5.6"
<dependency org="org.springframework" name="spring-webmvc" rev="2.5.6"
<dependency org="org.aspectj" name="aspectjrt" rev="1.6.5" conf="runtime->default"
<dependency org="org.aspectj" name="aspectjweaver" rev="1.6.5" conf="runtime->default"
<dependency org="org.springframework" name="spring-context-support"
rev="2.5.6" conf="runtime->default" />
<dependency org="org.springframework" name="spring-test" rev="2.5.6"
conf="test->default" />
<dependency org="org.springframework" name="spring-jdbc" rev="2.5.6"
conf="test,compile->default" />
<dependency org="commons-fileupload" name="commons-fileupload" rev="1.2.1"
conf="test,compile,runtime->default" />
<dependency org="commons-io" name="commons-io" rev="1.4" conf="test,compile,runtime->default"
<dependency org="dom4j" name="dom4j" rev="1.6.1" conf="test,compile,runtime->default"
<dependency org="javax.servlet" name="jstl" rev="1.2" conf="compile->default"
<dependency org="javax.servlet" name="jsp-api" rev="2.0" conf="compile->default"
<exclude org="xml-apis" module="xml-apis" />
<override org="junit" module="junit" rev="4.5" />
<override org="org.slf4j" module="slf4j-api" rev="1.5.6" />
</dependencies>
</ivy-module>
Compile configuration will resolve to the following jars:
C:\Documents and Settings\iloncar\.ivy2\cache\aopalliance\aopalliance\jars\ao palliance-1.0.jar
C:\Documents and Settings\iloncar\.ivy2\cache\commons-logging\commons-logging \jars\commons-logging-1.1.1.jar
C:\Documents and Settings\iloncar\.ivy2\cache\org.springframework\spring-bean s\jars\spring-beans-2.5.6.jar
C:\Documents and Settings\iloncar\.ivy2\cache\org.springframework\spring-core \jars\spring-core-2.5.6.jar
C:\Documents and Settings\iloncar\.ivy2\cache\org.springframework\spring-cont ext\jars\spring-context-2.5.6.jar
C:\Documents and Settings\iloncar\.ivy2\cache\org.springframework\spring-tx\j ars\spring-tx-2.5.6.jar
C:\Documents and Settings\iloncar\.ivy2\cache\commons-fileupload\commons-file upload\jars\commons-fileupload-1.2.1.jar
C:\Documents and Settings\iloncar\.ivy2\cache\commons-io\commons-io\jars\comm ons-io-1.4.jar
C:\Documents and Settings\iloncar\.ivy2\cache\dom4j\dom4j\jars\dom4j-1.6.1.ja r
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\bootstrap\jars\boots trap-6.1.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\com.ibm.mq\jars\com. ibm.mq-6.1.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\com.ibm.mqjms\jars\c om.ibm.mqjms-6.1.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\com.ibm.ws.ejbportab le\jars\com.ibm.ws.ejbportable-6.1.0.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\com.ibm.ws.emf\jars\ com.ibm.ws.emf-2.1.0.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\com.ibm.ws.portletco ntainer\jars\com.ibm.ws.portletcontainer-2.0.0.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\com.ibm.ws.runtime.d ist\jars\com.ibm.ws.runtime.dist-6.1.0.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\com.ibm.ws.runtime\j ars\com.ibm.ws.runtime-6.1.0.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\com.ibm.ws.sib.serve r\jars\com.ibm.ws.sib.server-2.0.0.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\com.ibm.ws.sip.conta iner\jars\com.ibm.ws.sip.container-6.1.0.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\com.ibm.ws.wccm\jars \com.ibm.ws.wccm-6.1.0.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\com.ibm.ws.webcontai ner\jars\com.ibm.ws.webcontainer-2.0.0.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\dhbcore\jars\dhbcore -6.1.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\j2ee\jars\j2ee-6.1.j ar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\mail-impl\jars\mail- impl-6.1.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\marshall\jars\marsha ll-6.1.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\org.eclipse.emf.comm on\jars\org.eclipse.emf.common-2.2.1.v200609210005.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\org.eclipse.emf.comm onj.sdo\jars\org.eclipse.emf.commonj.sdo-2.1.0.v200609210005 .jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\org.eclipse.emf.ecor e.change\jars\org.eclipse.emf.ecore.change-2.2.0.v2006092100 05.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\org.eclipse.emf.ecor e.sdo\jars\org.eclipse.emf.ecore.sdo-2.2.0.v200609210005.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\org.eclipse.emf.ecor e.xmi\jars\org.eclipse.emf.ecore.xmi-2.2.1.v200609210005.jar
C:\Documents and Settings\iloncar\.ivy2\cache\com.ibm.ws\org.eclipse.emf.ecor e\jars\org.eclipse.emf.ecore-2.2.1.v200609210005.jar
C:\Documents and Settings\iloncar\.ivy2\cache\javax.jms\jms\jars\jms-1.1.jar
C:\Documents and Settings\iloncar\.ivy2\cache\org.springframework\spring-jdbc \jars\spring-jdbc-2.5.6.jar
C:\Documents and Settings\iloncar\.ivy2\cache\javax.servlet\jstl\jars\jstl-1. 2.jar
C:\Documents and Settings\iloncar\.ivy2\cache\javax.servlet\jsp-api\jars\jsp- api-2.0.jar
C:\Documents and Settings\iloncar\.ivy2\cache\javax.servlet\servlet-api\jars\ servlet-api-2.4.jar
Runtime configuration will resolve to the following jars:
C:\Documents and Settings\iloncar\.ivy2\cache\org.springframework\spring-aop\ jars\spring-aop-2.5.6.jar
C:\Documents and Settings\iloncar\.ivy2\cache\org.springframework\spring-jms\ jars\spring-jms-2.5.6.jar
C:\Documents and Settings\iloncar\.ivy2\cache\commons-pool\commons-pool\jars\ commons-pool-1.3.jar
C:\Documents and Settings\iloncar\.ivy2\cache\org.springframework\spring-cont ext-support\jars\spring-context-support-2.5.6.jar
C:\Documents and Settings\iloncar\.ivy2\cache\org.springframework\spring-web\ jars\spring-web-2.5.6.jar
C:\Documents and Settings\iloncar\.ivy2\cache\org.springframework\spring-webm vc\jars\spring-webmvc-2.5.6.jar
C:\Documents and Settings\iloncar\.ivy2\cache\org.aspectj\aspectjrt\jars\aspe ctjrt-1.6.5.jar
C:\Documents and Settings\iloncar\.ivy2\cache\org.aspectj\aspectjweaver\jars\ aspectjweaver-1.6.5.jar
Ivica Loncar
FUDForum. Page generated in 0.04224 seconds
